Re: Search for calls to specific constructor in class? [message #164385 is a reply to message #164370] |
Mon, 07 August 2006 18:49 |
Originally posted by: wegener.cboenospam.com
David Karr wrote:
> Using Eclipse 3.1.2 and JDK 1.4.2.
> In the Java Search options, I can search for calls to a constructor
> matching the search string. This will find references to any constructor
> for the class matching the search string.
> Is it possible to limit the search so that it only finds references to
> specific constructors of the class? I don't see a way to do that, unless
> it's some magic in the entered search string. I tried entering
> "ClassName(String,String)", to indicate that I wanted to find references
> to the constructor that takes 2 strings, but the "Search" button greyed
> out when I entered the ",".
Select the constructor in the Outline view, right click, and select
References. You can specify the scope of the search on the popup menu.
You can also do the same thing if you right click on the definition of the
constructor in your source code.
You may also want to try the Open Call Hierarchy from the popup menu.
This allows you to trace back the path used to get to calling the
constructor.
FUDForum. Page generated in 0.07777 seconds
