Home » Language IDEs » C / C++ IDE (CDT) » C++ auto completion on amd64 hangs
C++ auto completion on amd64 hangs [message #164315] Thu, 23 February 2006 05:20 Go to next message
Originally posted by: karol.mikronika.com.pl
Hi!
I've installed 3.1.2 version of Eclipse (gtk) on my amd64 box and when I am
trying to use source autocompletion IDE hangs... :( This happens always
not incidentally.
I have Java 1.5.0. What I have to do? Reinstall 32-bit version of Eclipse
and
reinstall Java to 1.4.2?
What is the status of Eclipse on amd64? I read in release notes that
Eclipse
3.1.2 is in early stage on amd64 is it true now?
Karol
ps.
Lately I also tried 3.2M5 without success. Also hangs...
Re: C++ auto completion on amd64 hangs [message #164347 is a reply to message #164315] Thu, 23 February 2006 11:11 Go to previous messageGo to next message
Originally posted by: berend.chalmers.se
Hi Karol,
I guess this is a useless message; but I have been using eclipse for
quite some time now on AMD64 without any problems; autocompletion works
fine. I am running 3.1.2 with CDT 3.0.2
and java:
$ java -version
java version "1.5.0_04"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_04-b05)
Java HotSpot(TM) 64-Bit Server VM (build 1.5.0_04-b05, mixed mode)
Again, sorry, it probably doesn't help you. But it should be able to work.
Berend.
> Hi!
> not incidentally.
> Eclipse and
> Eclipse
> Karol
> ps.
Re: C++ auto completion on amd64 hangs [message #164405 is a reply to message #164315] Fri, 24 February 2006 02:02 Go to previous messageGo to next message
Karol Szkudlarek wrote:
> Hi!
> am trying to use source autocompletion IDE hangs... :( This happens always
> not incidentally.
> and
> Eclipse
> Karol
> ps.
I run eclipse (the 32bit build) on Linux on AMD64. Here autocompletion
works, but (probably due to the size of the project I am working on) is
very slow (up to multiple tenth of seconds). This makes the UI unresponsive
and looks like the IDE hangs. If you kill Eclipse too early, you may never
find out that it may come back - some day :-)
The lockup is so bad that I changed the autocompletion delay to be 3
seconds, so that I basically work without it. But sometimes I pause too
long while typing and then it bites me again :-(
Lothar
Re: C++ auto completion on amd64 hangs [message #164831 is a reply to message #164405] Tue, 28 February 2006 07:01 Go to previous message
I am very patient user.. :) But...
I am waiting very long time for Eclipse Wake Up..... Once I left Eclipse
for a whole night and back to work at the morning and Eclipse was still
unreponsive.. :(
For me Eclipse is completly useless now.. :(
ps.
I attached via jdb to eclipse java process and there are:
~> /usr/local/java/jdk/bin/jdb -connect
sun.jvm.hotspot.jdi.SAPIDAttachingConnector:pid=4561
Initializing jdb ...
> where all
AutoAssist Delay:
[1] java.lang.Object.wait (native method)
[2] java.lang.Object.wait (Object.java:474)
[3] org.eclipse.swt.widgets.Synchronizer.syncExec (Synchronizer.java:169)
[4] org.eclipse.ui.internal.UISynchronizer.syncExec
(UISynchronizer.java:28)
[5] org.eclipse.swt.widgets.Display.syncExec (Display.java:3 366)
[6]
org.eclipse.jface.text.contentassist.ContentAssistant$AutoAs sistListener.showAssist
(ContentAssistant.java:324)
[7]
org.eclipse.jface.text.contentassist.ContentAssistant$AutoAs sistListener.run
(ContentAssistant.java:246)
[8] java.lang.Thread.run (Thread.java:595)
org.eclipse.cdt.internal.ui.text.CSourceViewerConfiguration$ 1:
[2]
org.eclipse.jface.text.reconciler.AbstractReconciler$Backgro undThread.run
(AbstractReconciler.java:176)
Worker-3:
[2] org.eclipse.core.internal.jobs.WorkerPool.sleep (WorkerPool.java:173)
[3] org.eclipse.core.internal.jobs.WorkerPool.startJob
(WorkerPool.java:205)
[4] org.eclipse.core.internal.jobs.Worker.run (Worker.java:69)
Worker-2:
[2]
C/C++ Indexer:
[1] java.lang.Thread.sleep (native method)
[2] org.eclipse.cdt.internal.core.search.processing.JobManager.r un
(JobManager.java:455)
[3] java.lang.Thread.run (Thread.java:595)
Worker-0:
Start Level Event Dispatcher:
[3]
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .getNextEvent
(EventManager.java:349)
[4] org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run
(EventManager.java:287)
Framework Event Dispatcher:
[3]
State Data Manager:
[2] org.eclipse.osgi.framework.adaptor.core.StateManager.run
(StateManager.java:293)
Signal Dispatcher:
Finalizer:
[2] java.lang.ref.ReferenceQueue.remove (ReferenceQueue.java:116)
[3] java.lang.ref.ReferenceQueue.remove (ReferenceQueue.java:132)
[4] java.lang.ref.Finalizer$FinalizerThread.run (Finalizer.java:159)
Reference Handler:
[3] java.lang.ref.Reference$ReferenceHandler.run (Reference.java:116)
main:
> threads
Group system:
(java.lang.ref.Reference$ReferenceHandler)0xc
Reference Handler unknown
(java.lang.ref.Finalizer$FinalizerThread)0xb
Finalizer unknown
(java.lang.Thread)0xa
Signal Dispatcher running
Group main:
(java.lang.Thread)0xd
main running
(java.lang.Thread)0x9
State Data Manager sleeping
(org.eclipse.osgi.framework.eventmgr.EventManager$EventThrea d)0x8
Framework Event Dispatcher unknown
(org.eclipse.osgi.framework.eventmgr.EventManager$EventThrea d)0x7
Start Level Event Dispatcher unknown
(org.eclipse.core.internal.jobs.Worker)0x6
Worker-0 unknown
(java.lang.Thread)0x5
C/C++ Indexer sleeping
(org.eclipse.jface.text.reconciler.AbstractReconciler$Backgr oundThread)0x4
org.eclipse.cdt.internal.ui.text.CSourceViewerConfiguration$ 1 unknown
(org.eclipse.core.internal.jobs.Worker)0x3
Worker-2 unknown
(org.eclipse.core.internal.jobs.Worker)0x2
Worker-3 unknown
(org.eclipse.jface.text.reconciler.AbstractReconciler$Backgr oundThread)0x1
(java.lang.Thread)0x0
AutoAssist Delay unknown
Maybe I can better diagnose my issue.... Any ideas??
Karol
Previous Topic:Makefile and default associated editor
Next Topic:Red error crosses when using my own makefiles?
Current Time: Sun Jul 27 03:12:02 EDT 2025
Powered by FUDForum. Page generated in 0.12480 seconds
