Home » Eclipse Projects » DTP » NoClassDefFoundError though plugin is loaded
NoClassDefFoundError though plugin is loaded [message #15463] Mon, 29 May 2006 22:45 Go to next message
I have 2 plugins - oracle.dbtools.connectivity and
oracle.dbtools.modelbase. When a class in oracle.dbtools.connectivity
that inherits from oracle.dbtools.modelbase class it is resulting
NoClassDefFoundError during its instantiation.
I checked the plugins to make sure that the classes are in there. Also
the Help->About Eclipse->Plug-in Details lists both plugins. This error
message is found in the .metadata/.plugins/org.eclipse.ui.workbench/log.
Any suggestions ?
Anthos
!ENTRY org.eclipse.ui.navigator 4 0 2006-05-30 12:30:58.421
!MESSAGE Could not acquire children from extension: org.eclipse.datatools.connectivity.db.sqlModelContent
!STACK 0
java.lang.NoClassDefFoundError: oracle/dbtools/modelbase/oracle/impl/MaterializedViewImpl
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:160)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:498)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:468)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:427)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:339)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:391)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:352)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at oracle.dbtools.connectivity.catalog.OracleSchema.loadTables( OracleSchema.java:68)
at oracle.dbtools.connectivity.catalog.OracleSchema.getTables(O racleSchema.java:179)
at org.eclipse.datatools.connectivity.sqm.server.internal.ui.ex plorer.providers.content.layout.vnode.ServerExplorerVNodeCon tentProviderNav.displayTableNodeChildren(ServerExplorerVNode ContentProviderNav.java:143)
Re: [dtp-dev] NoClassDefFoundError though plugin is loaded [message #15496 is a reply to message #15463] Tue, 30 May 2006 00:47 Go to previous messageGo to next message
I have exported the package using the MANIFEST.MF as shown below
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Oracle Modelbase Plug-in
Bundle-SymbolicName: oracle.dbtools.modelbase;singleton:=true
Bundle-Version: 1.0.0
Bundle-Localization: plugin
Bundle-Vendor: http://www.oracle.com
Require-Bundle: org.eclipse.datatools.modelbase.sql
Export-Package:
oracle.dbtools.modelbase;x-friends:="oracle.dbtools.connectivity "
Anthos
Anil T Samuel wrote:
> Hi
> error message is found in the
> Any suggestions ?
> Regards
> Anthos
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> _______________________________________________
> dtp-dev mailing list
> dtp-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/dtp-dev
Re: [dtp-dev] NoClassDefFoundError though plugin is loaded [message #15529 is a reply to message #15496] Tue, 30 May 2006 01:26 Go to previous messageGo to next message
Uff ..
This is fixed by using following line in MANIFEST.MF
Export-Package: oracle.dbtools.modelbase.oracle,
oracle.dbtools.modelbase.oracle.impl;x-friends:="oracle.dbtools.connectivity "
Anthos
> Export-Package:
> Regards
> Anthos
>> Hi
>> Also the Help->About Eclipse->Plug-in Details lists both plugins.
>> This error message is found in the
>> Any suggestions ?
>> Regards
>> Anthos
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> dtp-dev@eclipse.org
> dtp-dev@eclipse.org
Re: [dtp-dev] NoClassDefFoundError though plugin is loaded [message #15562 is a reply to message #15529] Tue, 30 May 2006 07:28 Go to previous messageGo to next message
Anil,
Shouldn't your package names be com.oracle...?
> Uff ..
> Regards
> Anthos
>> Export-Package:
>> Regards
>> Anthos
>>> Hi
>>> oracle.dbtools.connectivity that inherits from
>>> oracle.dbtools.modelbase class it is resulting NoClassDefFoundError
>>> Any suggestions ?
>>> Regards
>>> Anthos
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> dtp-dev@eclipse.org
>> dtp-dev@eclipse.org
Re: [dtp-dev] NoClassDefFoundError though plugin is loaded [message #15658 is a reply to message #15562] Tue, 30 May 2006 18:06 Go to previous messageGo to next message
Originally posted by: anil.samuel.gmail.com
Isn't com. like www. ??
most oracle packages starts with oracle. eg. oracle.jdbc.OracleDriver
Ed Merks wrote:
> Anil,
>> Uff ..
>> Regards
>> Anthos
>>> Export-Package:
>>> Regards
>>> Anthos
>>>> Hi
>>>> Any suggestions ?
>>>> Regards
>>>> Anthos
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> dtp-dev@eclipse.org
>>> dtp-dev@eclipse.org
Re: [dtp-dev] NoClassDefFoundError though plugin is loaded [message #15686 is a reply to message #15658] Tue, 30 May 2006 18:31 Go to previous messageGo to next message
--------------060905050507020001000006
Anil,
I'm very surprised given that I've always seen com.ibm.* and absolutely
never just ibm.*. After all, if www.eclipse.org becomes org.eclipse.*
then www.abc.xyz becomes xyz.abc.*. That's basically what this excerpt
in the JLS, which specifically gives "com" as an example, say:
Names of packages that are to be made widely available should be
formed as described in 7.7. Such names are always qualified names
whose first identifier consists of two or three lowercase letters
that name an Internet domain, such as *|com|, *|edu|, |gov|, |mil|,
|net|, |org|, or a two-letter ISO country code such as |uk| or |jp|.
Here are examples of hypothetical unique names that might be formed
under this convention:
com.JavaSoft.jag.Oak
org.npr.pledge.driver
uk.ac.city.rugby.game
> Ed Merks wrote:
>> Anil,
>>> Uff ..
>>> Regards
>>> Anthos
>>>> Export-Package:
>>>> Regards
>>>> Anthos
>>>>> Hi
>>>>> Any suggestions ?
>>>>> Regards
>>>>> Anthos
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> dtp-dev@eclipse.org
>>>> dtp-dev@eclipse.org
<html>
<head>
</head>
Anil,<br>
<br>
never just ibm.*.&nbsp; After all, if <a class="moz-txt-link-abbreviated" href="http://www.eclipse.org">www.eclipse.org</a> becomes org.eclipse.*
then <a class="moz-txt-link-abbreviated" href="http://www.abc.xyz">www.abc.xyz</a> becomes xyz.abc.*.&nbsp; That's basically what this excerpt
in the JLS, which specifically gives <font color="#009900">"</font><font
color="#009900">com" </font>as an example, say:<br>
<blockquote>Names of packages that are to be made widely available
should be formed as described in 7.7.
Such names are always qualified names whose first identifier consists
of two or three lowercase letters that name an Internet domain, such as
<font color="#009900"><b><code>com</code>, </b></font><code>edu</code>,
<code>gov</code>, <code>mil</code>, <code>net</code>, <code>org</code>,
or a two-letter ISO country code such as <code>uk</code> or <code>jp</code>.
<p></p>
com.JavaSoft.jag.Oak<br>
org.npr.pledge.driver<br>
<br>
uk.ac.city.rugby.game<br>
</blockquote>
<br>
Anil Samuel wrote:
<blockquote cite="mide5ifla$gae$1@utils.eclipse.org" type="cite">Isn't
com. like www. ??
<br>
<br>
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Anil,
<br>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Uff ..
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Anthos
<br>
<br>
<blockquote type="cite">I have exported the package using the
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Bundle-Vendor: <a class="moz-txt-link-freetext" href="http://www.oracle.com">http://www.oracle.com</a>
<br>
<br>
Export-Package:
<br>
<br>
<br>
Anthos
<br>
<br>
<br>
<blockquote type="cite">Hi
<br>
<br>
<br>
<br>
the Help-&gt;About Eclipse-&gt;Plug-in Details lists both plugins. This
..metadata/.plugins/org.eclipse.ui.workbench/log.
<br>
<br>
Any suggestions ?
<br>
<br>
<br>
Anthos
<br>
<br>
<br>
<br>
!STACK 0
<br>
<br>
&nbsp;&nbsp;&nbsp; at java.lang.ClassLoader.defineClass1(Native Method)
<br>
&nbsp;&nbsp;&nbsp; at java.lang.ClassLoader.defineClass(Unknown Source)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
&nbsp;&nbsp;&nbsp; at java.lang.ClassLoader.loadClass(Unknown Source)
<br>
&nbsp;&nbsp;&nbsp; at java.lang.ClassLoader.loadClassInternal(Unknown Source)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<a class="moz-txt-link-abbreviated" href="mailto:dtp-dev@eclipse.org">dtp-dev@eclipse.org</a>
<br>
<a class="moz-txt-link-freetext" href="https://dev.eclipse.org/mailman/listinfo/dtp-dev">https://dev.eclipse.org/mailman/listinfo/dtp-dev</a>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------060905050507020001000006--
Re: [dtp-dev] NoClassDefFoundError though plugin is loaded [message #578565 is a reply to message #15463] Tue, 30 May 2006 00:47 Go to previous messageGo to next message
Export-Package:
Anthos
> Hi
> Any suggestions ?
> Regards
> Anthos
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> dtp-dev@eclipse.org
Re: [dtp-dev] NoClassDefFoundError though plugin is loaded [message #578590 is a reply to message #15496] Tue, 30 May 2006 01:26 Go to previous messageGo to next message
Uff ..
Anthos
> Export-Package:
> Regards
> Anthos
>> Hi
>> Any suggestions ?
>> Regards
>> Anthos
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> dtp-dev@eclipse.org
> dtp-dev@eclipse.org
Re: [dtp-dev] NoClassDefFoundError though plugin is loaded [message #578606 is a reply to message #15529] Tue, 30 May 2006 07:28 Go to previous messageGo to next message
Anil,
> Uff ..
> Regards
> Anthos
>> Export-Package:
>> Regards
>> Anthos
>>> Hi
>>> Any suggestions ?
>>> Regards
>>> Anthos
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> dtp-dev@eclipse.org
>> dtp-dev@eclipse.org
Re: [dtp-dev] NoClassDefFoundError though plugin is loaded [message #578806 is a reply to message #15562] Tue, 30 May 2006 18:06 Go to previous messageGo to next message
Ed Merks wrote:
> Anil,
>> Uff ..
>> Regards
>> Anthos
>>> Export-Package:
>>> Regards
>>> Anthos
>>>> Hi
>>>> Any suggestions ?
>>>> Regards
>>>> Anthos
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> dtp-dev@eclipse.org
>>> dtp-dev@eclipse.org
Re: [dtp-dev] NoClassDefFoundError though plugin is loaded [message #578855 is a reply to message #15658] Tue, 30 May 2006 18:31 Go to previous messageGo to next message
Anil,
> Ed Merks wrote:
>> Anil,
>>> Uff ..
>>> Regards
>>> Anthos
>>>> Export-Package:
>>>> Regards
>>>> Anthos
>>>>> Hi
>>>>> Any suggestions ?
>>>>> Regards
>>>>> Anthos
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> dtp-dev@eclipse.org
>>>> dtp-dev@eclipse.org
<html>
<head>
</head>
Anil,<br>
<br>
<p></p>
<br>
</blockquote>
<br>
com. like www. ??
<br>
<br>
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Anthos
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Export-Package:
<br>
<br>
<br>
Anthos
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Any suggestions ?
<br>
<br>
<br>
Anthos
<br>
<br>
<br>
<br>
!STACK 0
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
Re: NoClassDefFoundError though plugin is loaded [message #1811338] Sat, 31 August 2019 11:41 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811339] Sat, 31 August 2019 11:41 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811340] Sat, 31 August 2019 11:42 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811351] Sat, 31 August 2019 14:21 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811352] Sat, 31 August 2019 14:21 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811353] Sat, 31 August 2019 14:21 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811354] Sat, 31 August 2019 14:21 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811355] Sat, 31 August 2019 14:22 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811356] Sat, 31 August 2019 14:22 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811357] Sat, 31 August 2019 14:22 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811366] Sat, 31 August 2019 14:23 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811369] Sat, 31 August 2019 14:23 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811370] Sat, 31 August 2019 14:23 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811371] Sat, 31 August 2019 14:23 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811372] Sat, 31 August 2019 14:23 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811373] Sat, 31 August 2019 14:23 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811374] Sat, 31 August 2019 14:23 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811375] Sat, 31 August 2019 14:23 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811376] Sat, 31 August 2019 14:23 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811377] Sat, 31 August 2019 14:23 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811379] Sat, 31 August 2019 14:24 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811382] Sat, 31 August 2019 14:24 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811383] Sat, 31 August 2019 14:24 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811385] Sat, 31 August 2019 14:24 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811390] Sat, 31 August 2019 14:25 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811400] Sat, 31 August 2019 14:25 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811401] Sat, 31 August 2019 14:26 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811402] Sat, 31 August 2019 14:26 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811403] Sat, 31 August 2019 14:26 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811404] Sat, 31 August 2019 14:26 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811405] Sat, 31 August 2019 14:26 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811407] Sat, 31 August 2019 14:26 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811408] Sat, 31 August 2019 14:26 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811410] Sat, 31 August 2019 14:26 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811411] Sat, 31 August 2019 14:26 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811412] Sat, 31 August 2019 14:27 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811415] Sat, 31 August 2019 14:27 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811417] Sat, 31 August 2019 14:27 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811419] Sat, 31 August 2019 14:27 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811421] Sat, 31 August 2019 14:27 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811423] Sat, 31 August 2019 14:28 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811424] Sat, 31 August 2019 14:28 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811425] Sat, 31 August 2019 14:28 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811426] Sat, 31 August 2019 14:28 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811428] Sat, 31 August 2019 14:28 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811433] Sat, 31 August 2019 14:28 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811435] Sat, 31 August 2019 14:29 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811440] Sat, 31 August 2019 14:29 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811445] Sat, 31 August 2019 14:30 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811448] Sat, 31 August 2019 14:30 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811452] Sat, 31 August 2019 14:30 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811456] Sat, 31 August 2019 14:30 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811457] Sat, 31 August 2019 14:31 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811464] Sat, 31 August 2019 14:31 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811466] Sat, 31 August 2019 14:31 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811468] Sat, 31 August 2019 14:31 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811478] Sat, 31 August 2019 14:32 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811480] Sat, 31 August 2019 14:32 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811481] Sat, 31 August 2019 14:33 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811482] Sat, 31 August 2019 14:33 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811483] Sat, 31 August 2019 14:33 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811484] Sat, 31 August 2019 14:33 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811485] Sat, 31 August 2019 14:33 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811486] Sat, 31 August 2019 14:33 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811487] Sat, 31 August 2019 14:33 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811488] Sat, 31 August 2019 14:33 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811489] Sat, 31 August 2019 14:33 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811490] Sat, 31 August 2019 14:33 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811491] Sat, 31 August 2019 14:33 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811492] Sat, 31 August 2019 14:34 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811493] Sat, 31 August 2019 14:34 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811494] Sat, 31 August 2019 14:34 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811495] Sat, 31 August 2019 14:34 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811496] Sat, 31 August 2019 14:34 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811497] Sat, 31 August 2019 14:34 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811498] Sat, 31 August 2019 14:34 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811499] Sat, 31 August 2019 14:34 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811500] Sat, 31 August 2019 14:34 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811501] Sat, 31 August 2019 14:34 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811502] Sat, 31 August 2019 14:34 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811503] Sat, 31 August 2019 14:35 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811504] Sat, 31 August 2019 14:35 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811505] Sat, 31 August 2019 14:35 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811506] Sat, 31 August 2019 14:35 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811507] Sat, 31 August 2019 14:35 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811508] Sat, 31 August 2019 14:35 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811509] Sat, 31 August 2019 14:35 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811510] Sat, 31 August 2019 14:35 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811511] Sat, 31 August 2019 14:35 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811512] Sat, 31 August 2019 14:35 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811513] Sat, 31 August 2019 14:35 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811514] Sat, 31 August 2019 14:36 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811515] Sat, 31 August 2019 14:36 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811516] Sat, 31 August 2019 14:36 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811517] Sat, 31 August 2019 14:36 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811523] Sat, 31 August 2019 14:36 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811525] Sat, 31 August 2019 14:36 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811571] Sat, 31 August 2019 14:40 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811572] Sat, 31 August 2019 14:41 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811574] Sat, 31 August 2019 14:41 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811575] Sat, 31 August 2019 14:41 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811577] Sat, 31 August 2019 14:41 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811580] Sat, 31 August 2019 14:41 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811581] Sat, 31 August 2019 14:41 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811583] Sat, 31 August 2019 14:41 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811585] Sat, 31 August 2019 14:42 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811587] Sat, 31 August 2019 14:42 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811588] Sat, 31 August 2019 14:42 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811590] Sat, 31 August 2019 14:42 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811591] Sat, 31 August 2019 14:42 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811592] Sat, 31 August 2019 14:42 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811593] Sat, 31 August 2019 14:42 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811595] Sat, 31 August 2019 14:43 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811596] Sat, 31 August 2019 14:43 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811598] Sat, 31 August 2019 14:43 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811601] Sat, 31 August 2019 14:43 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811603] Sat, 31 August 2019 14:43 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811605] Sat, 31 August 2019 14:44 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811606] Sat, 31 August 2019 14:44 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811607] Sat, 31 August 2019 14:44 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811608] Sat, 31 August 2019 14:44 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811610] Sat, 31 August 2019 14:44 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811656] Sat, 31 August 2019 14:48 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811659] Sat, 31 August 2019 14:48 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811662] Sat, 31 August 2019 14:49 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811663] Sat, 31 August 2019 14:49 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811664] Sat, 31 August 2019 14:49 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811665] Sat, 31 August 2019 14:49 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811668] Sat, 31 August 2019 14:49 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811669] Sat, 31 August 2019 14:49 Go to previous messageGo to next message
1'"
Re: NoClassDefFoundError though plugin is loaded [message #1811670] Sat, 31 August 2019 14:49 Go to previous messageGo to next message
No Message Body
Re: NoClassDefFoundError though plugin is loaded [message #1811671] Sat, 31 August 2019 14:49 Go to previous messageGo to next message
No Message Body
Re: NoClassDefFoundError though plugin is loaded [message #1811672] Sat, 31 August 2019 14:50 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811673] Sat, 31 August 2019 14:50 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811674] Sat, 31 August 2019 14:50 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811675] Sat, 31 August 2019 14:50 Go to previous messageGo to next message
No Message Body
Re: NoClassDefFoundError though plugin is loaded [message #1811676] Sat, 31 August 2019 14:50 Go to previous messageGo to next message
@@wKoal
Re: NoClassDefFoundError though plugin is loaded [message #1811677] Sat, 31 August 2019 14:50 Go to previous messageGo to next message
JyI=
Re: NoClassDefFoundError though plugin is loaded [message #1811678] Sat, 31 August 2019 14:50 Go to previous messageGo to next message
@@THdcw
Re: NoClassDefFoundError though plugin is loaded [message #1811679] Sat, 31 August 2019 14:50 Go to previous messageGo to next message
No Message Body
Re: NoClassDefFoundError though plugin is loaded [message #1811680] Sat, 31 August 2019 14:50 Go to previous messageGo to next message
No Message Body
Re: NoClassDefFoundError though plugin is loaded [message #1811681] Sat, 31 August 2019 14:50 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811682] Sat, 31 August 2019 14:50 Go to previous messageGo to next message
(select convert(int,CHAR(65)))
Re: NoClassDefFoundError though plugin is loaded [message #1811683] Sat, 31 August 2019 14:50 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811684] Sat, 31 August 2019 14:51 Go to previous messageGo to next message
No Message Body
Re: NoClassDefFoundError though plugin is loaded [message #1811685] Sat, 31 August 2019 14:51 Go to previous messageGo to next message
No Message Body
Re: NoClassDefFoundError though plugin is loaded [message #1811686] Sat, 31 August 2019 14:51 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811687] Sat, 31 August 2019 14:51 Go to previous messageGo to next message
No Message Body
Re: NoClassDefFoundError though plugin is loaded [message #1811688] Sat, 31 August 2019 14:51 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811689] Sat, 31 August 2019 14:51 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811690] Sat, 31 August 2019 14:51 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811691] Sat, 31 August 2019 14:51 Go to previous messageGo to next message
No Message Body
Re: NoClassDefFoundError though plugin is loaded [message #1811692] Sat, 31 August 2019 14:52 Go to previous messageGo to next message
No Message Body
Re: NoClassDefFoundError though plugin is loaded [message #1811693] Sat, 31 August 2019 14:52 Go to previous messageGo to next message
1'"
Re: NoClassDefFoundError though plugin is loaded [message #1811694] Sat, 31 August 2019 14:52 Go to previous messageGo to next message
1'"
Re: NoClassDefFoundError though plugin is loaded [message #1811695] Sat, 31 August 2019 14:52 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811696] Sat, 31 August 2019 14:52 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811697] Sat, 31 August 2019 14:52 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811698] Sat, 31 August 2019 14:52 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811699] Sat, 31 August 2019 14:52 Go to previous messageGo to next message
@@8FqQt
Re: NoClassDefFoundError though plugin is loaded [message #1811700] Sat, 31 August 2019 14:52 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811701] Sat, 31 August 2019 14:52 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811702] Sat, 31 August 2019 14:52 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811703] Sat, 31 August 2019 14:53 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811704] Sat, 31 August 2019 14:53 Go to previous messageGo to next message
1'"
Re: NoClassDefFoundError though plugin is loaded [message #1811705] Sat, 31 August 2019 14:53 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811706] Sat, 31 August 2019 14:53 Go to previous messageGo to next message
No Message Body
Re: NoClassDefFoundError though plugin is loaded [message #1811707] Sat, 31 August 2019 14:53 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811708] Sat, 31 August 2019 14:53 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811709] Sat, 31 August 2019 14:53 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811710] Sat, 31 August 2019 14:53 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811711] Sat, 31 August 2019 14:53 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811712] Sat, 31 August 2019 14:53 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811713] Sat, 31 August 2019 14:54 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811714] Sat, 31 August 2019 14:54 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811715] Sat, 31 August 2019 14:54 Go to previous messageGo to next message
JyI=
Re: NoClassDefFoundError though plugin is loaded [message #1811716] Sat, 31 August 2019 14:54 Go to previous messageGo to next message
1'"
Re: NoClassDefFoundError though plugin is loaded [message #1811717] Sat, 31 August 2019 14:54 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811718] Sat, 31 August 2019 14:54 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811719] Sat, 31 August 2019 14:54 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811720] Sat, 31 August 2019 14:54 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811722] Sat, 31 August 2019 14:54 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811723] Sat, 31 August 2019 14:54 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811725] Sat, 31 August 2019 14:55 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811728] Sat, 31 August 2019 14:55 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811730] Sat, 31 August 2019 14:56 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811731] Sat, 31 August 2019 14:56 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811734] Sat, 31 August 2019 14:56 Go to previous messageGo to next message
Re: NoClassDefFoundError though plugin is loaded [message #1811735] Sat, 31 August 2019 14:56 Go to previous messageGo to previous message
Previous Topic:Consolidation Task Force
Next Topic:Current status of the Proposal
Current Time: Wed Jun 04 20:09:56 EDT 2025
Powered by FUDForum. Page generated in 0.19938 seconds
