Home » Language IDEs » ServerTools (WTP) » Adding item to JSP popup Menu - what TargetId?
Adding item to JSP popup Menu - what TargetId? [message #164132] Thu, 16 March 2006 15:57 Go to next message
Originally posted by: Ed.Batutis.sas.com
I'm trying to add a popup menu to the JSP editor (and the other sse
editors). Back in mid-October the targetID for viewerContributions for the
jsp editor was rumored to be
org.eclipse.jst.jsp.core.jspsource.source.EditorContext
Is that correct for wst 1.0.0 (it doesn't seem to work for me)?
Previously I was using
org.eclipse.wst.sse.ui.StructuredTextEditor.context
but that doesn't work in 1.0.0 either.
Will the targetID change in 1.5?
If you don't know the answer, but can tell me where to look for the answer
in the code I'd be grateful for that as well.
=Ed
Re: Adding item to JSP popup Menu - what TargetId? [message #164146 is a reply to message #164132] Thu, 16 March 2006 18:00 Go to previous messageGo to next message
Originally posted by: amywu.us.DELETETHIS.ibm.com
By WST 1.0, do you really mean WTP 1.0? WST would not have any JSP in
it. But yes,
targetID="org.eclipse.jst.jsp.core.jspsource.source.EditorContext "
should be working.
What does your definition look like? For example, the following worked
for me:
<extension point="org.eclipse.ui.popupMenus">
<viewerContribution
id="org.eclipse.jst.jsp.examples.tld.context.actions">
<action
label="Convert To Entities"
class=" org.eclipse.jst.jsp.examples.tld.ConvertToEntitiesActionDele gate "
menubarPath="additions"
id=" org.eclipse.jst.jsp.examples.tld.ConvertToEntitiesActionDele gate ">
</action>
</viewerContribution>
</extension>
> Thanks
> =Ed
Re: Adding item to JSP popup Menu - what TargetId? [message #164234 is a reply to message #164146] Fri, 17 March 2006 10:59 Go to previous message
Thanks, your example made me look at my menu path and I realized I simply
got it wrong. The targetID was OK.
A related rant: I have a generic text-processing plugin that works in any
text-oriented editor. Every time someone adds a new such editor or changes
the target IDs I need to chase down this info in random locations and then
update my plugin.xml. This isn't much fun. I'm sure any general solution to
this problem would be complicated, but I would be happy to see one!
Thanks for your help!
=Ed
Previous Topic:WTP with JRun
Next Topic:Breakpoint provider additional prefix
Current Time: Sat Aug 30 06:20:31 EDT 2025
Powered by FUDForum. Page generated in 0.03952 seconds
