Home » Eclipse Projects » Eclipse Website » Add some indentation inside the <div id="midcolumn"> section
Add some indentation inside the <div id="midcolumn"> section [message #15431] Thu, 12 January 2006 11:13 Go to next message
Originally posted by: olivier_thomann.NOca.ibm.comSPAM
I believe it would be nice to have a little indentation between the
border of the box and its contents. On the Eclipse web page, this
doesn't look too bad, because there is a list inside the box. But when a
text is added without being in a list, it would be nice to add a little
indentation on the left side.
Is it possible to do this in the Eclipse style?
If this is not possible in the global settings, I'll do it locally.
Olivier
Re: Add some indentation inside the <div id="midcolumn"> section [message #15563 is a reply to message #15431] Fri, 13 January 2006 08:44 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
I think if you wrap your text with <p> that will add the margin you need.
<div class="homeitem3col">
<h3>Box title</h3>
<p>This is some text</p>
</div>
D.
Olivier Thomann wrote:
> Olivier
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the WebMaster FAQ at
http://wiki.eclipse.org/index.php/Webmaster_FAQ
View my status at http://wiki.eclipse.org/index.php/WebMaster
Re: Add some indentation inside the <div id="midcolumn"> section [message #15660 is a reply to message #15563] Fri, 13 January 2006 09:28 Go to previous messageGo to next message
> <h3>Box title</h3>
> </div>
This is what I tried.
And it doesn't work. There is no indentation on the left.
Olivier
Re: Add some indentation inside the <div id="midcolumn"> section [message #15713 is a reply to message #15563] Fri, 13 January 2006 13:25 Go to previous messageGo to next message
> <h3>Box title</h3>
> </div>
If I do this and I add the following line in the css file layout.css (in
the phoenix theme):
..homeitem3col p {
padding-left: 5px;
I can then get the expected padding.
Could this be changed? I think it looks better with an additional
padding on the left.
Any thought?
Olivier
Re: Add some indentation inside the <div id="midcolumn"> section [message #16129 is a reply to message #15713] Fri, 13 January 2006 13:37 Go to previous message
Please file a bug against technology/Phoenix, and we'll test it out.
Thanks!
>> <h3>Box title</h3>
>> </div>
> the phoenix theme):
> .homeitem3col p {
> padding-left: 5px;
> Any thought?
> Olivier
Re: Add some indentation inside the <div id="midcolumn"> section [message #568091 is a reply to message #15431] Fri, 13 January 2006 08:44 Go to previous message
<h3>Box title</h3>
</div>
D.
> Olivier
Re: Add some indentation inside the <div id="midcolumn"> section [message #568188 is a reply to message #15563] Fri, 13 January 2006 09:28 Go to previous message
> <h3>Box title</h3>
> </div>
Olivier
Re: Add some indentation inside the <div id="midcolumn"> section [message #568334 is a reply to message #15563] Fri, 13 January 2006 13:25 Go to previous message
> <h3>Box title</h3>
> </div>
the phoenix theme):
..homeitem3col p {
padding-left: 5px;
Any thought?
Olivier
Re: Add some indentation inside the <div id="midcolumn"> section [message #568384 is a reply to message #15713] Fri, 13 January 2006 13:37 Go to previous message
Thanks!
>> <h3>Box title</h3>
>> </div>
> the phoenix theme):
> .homeitem3col p {
> padding-left: 5px;
> Any thought?
> Olivier
Previous Topic:local style sheet file
Next Topic:Welcome Newbies
Current Time: Mon Jul 14 22:12:58 EDT 2025
Powered by FUDForum. Page generated in 0.04765 seconds
