drag from parent to parent [message #163701] |
Wed, 12 January 2005 09:53  |
Originally posted by: mmaercker.tripper-bullet.com
I have an editor where each element can have subelements that can be dragged
around within their parent (hierarchy of IFigures).
The parents, like the content root grandparent, all have derivates of
XYLayoutEditPolicy installed as policies for the layout role. This works
well as far as moving the children around within the parent is concerned.
I would like to be able to drag the children from one parent to another,
though. When I do this, the layout policy appears to cancel the drag (circle
with diagonal line icon). How can I change this behaviour?
In general, is there a commonly accepted way of dragging hierarchically
organized elements from one parent to another in a GEF editor? Does anyone
have any recommendations or ideas on the best way to do this?
Any help greatly appreciated,
Martin Maercker
Re: drag from parent to parent [message #163752 is a reply to message #163701] |
Wed, 12 January 2005 16:08   |
When you're dragging from one parent to the other, in essence, you're
removing a child from the old parent (REQ_ORPHAN_CHILDREN) and adding it to
the new parent (REQ_ADD). The container that supports children being
dragged out of it, needs a policy that can provide a command to orphan
children, and the container that supports children being added to it needs a
policy that can provide a command to add children. So, your
XYLayoutEditPolicies would have to override getOrphanChildrenCommand() and
getAddCommand() as needed.
The logic example already does this. Look at
LogicXYLayoutEditPolicy#getAddCommand() and
LogicContainerEditPolicy#getOrphanChildrenCommand().
"Martin Maercker" <mmaercker@tripper-bullet.com> wrote in message
news:cs3dio$510$1@www.eclipse.org...
dragged
(circle
> Martin Maercker
Re: drag from parent to parent [message #163759 is a reply to message #163752] |
Wed, 12 January 2005 16:15  |
OK, I'll give the logic example's edit policies another look.
Thanks a lot!
Martin
"Pratik Shah" <ppshah@us.ibm.com> schrieb im Newsbeitrag
news:cs43ke$sub$1@www.eclipse.org...
to
a
> > Hi,
> dragged
works
concerned.
> (circle
anyone
> > Martin Maercker
FUDForum. Page generated in 0.03483 seconds
