Home » Eclipse Projects » Eclipse Platform » how to install a plug-in?
how to install a plug-in? [message #163614] Sun, 30 November 2003 07:21 Go to next message
Originally posted by: manchi.singnet.com.sg
hi,
sorry, I am new to Eclipse, it seems that it is quite a stupid question.
I downloaded a gef plug-in, after unzipped it, I got 2 directories:
-features
- org.eclipse.gef_2.1.2
-plugins
-org.eclipse.draw2d_2.1.2
-org.eclipse.gef_2.1.2
very logically, I copied the 2 directories under plugins to
C:\Program Files\eclipse\plugins
but how about the features/org.eclipse.gef_2.1.2 directory ?
do I need to copy to C:\Program Files\eclipse\features as well?
Pls advise.
btw, where is the documentation on how to install a plug-in in Eclipse
website???
~louis
Re: how to install a plug-in? [message #163646 is a reply to message #163614] Sun, 30 November 2003 08:34 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
Features go in the features folder. If you had unzipped it directly into the
root eclipse folder, things would have gone where they should have.
Bob Foster
"Louis Leung" <manchi@singnet.com.sg> wrote in message
news:bqcn54$dir$1@eclipse.org...
> hi,
> -features
> -plugins
> Pls advise.
> website???
> ~louis
Re: how to install a plug-in? [message #163689 is a reply to message #163646] Sun, 30 November 2003 11:16 Go to previous messageGo to next message
Originally posted by: eclipse-news.forritan.net
You could also do this:
Keep eclipse in
Make another folder for eclipse extensions, e.g.:
C:\Program Files\eclipse-extensions
where you make a subfolder for each extension, e.g.:
C:\Program Files\eclipse-extensions\GEF-runtime-I20031015
(I use the name of the zip-file). After unzipping
GEF-runtime-I20031015.zip into a subfolder eclipse (very important!),
you should have something like this:
C:\Program Files\eclipse-extensions\GEF-runtime-I20031015\
-eclipse
-features
-plugins
Now you make a subfolder links in C:\Program Files\eclipse. And in this
folder you should put .link files.
E.g.: make a file named GEF-runtime-I20031015.link in which you write
this (NB! - '\\' on windows):
path=C:\\Program Files\\eclipse-extensions\\GEF-runtime-I20031015
So you now have:
C:\Program Files\eclipse\links with one file
- GEF-runtime-I20031015.link
And voila - (re-)start eclipse.
Oh btw - I will also recommend to backup the links folder.
This way you can experiment with newer versions of eclipse and use the
same extensions - just copy the links folder. And to upgrade to newer
version of eclipse - delete the old one, unzip the new one and copy back
the links folder...
-eyðun
> Bob Foster
>>hi,
>>-features
>>-plugins
>>Pls advise.
>>website???
>>~louis
Re: how to install a plug-in? [message #163698 is a reply to message #163689] Sun, 30 November 2003 12:12 Go to previous messageGo to next message
In what way would that be better? It sure isn't simpler!
Bob
"Ey
Re: how to install a plug-in? [message #163705 is a reply to message #163698] Sun, 30 November 2003 12:21 Go to previous messageGo to next message
Well, you don't have to do it this way - if you feel more comfortable by
the more simple way, that's probably better.... for you.
-eyðun
> Bob
> "Eyðun Nielsen" <eclipse-news@forritan.net> wrote in message
> news:bqd509$q6b$1@eclipse.org...
>>Keep eclipse in
>>-eclipse
>>-features
>>-plugins
>>So you now have:
>>the links folder...
>>Regards,
>>-eyðun
> the
>>>Bob Foster
>>>>hi,
>>>>-features
>>>>-plugins
>>>>Pls advise.
>>>>website???
>>>>~louis
Re: how to install a plug-in? [message #163862 is a reply to message #163698] Sun, 30 November 2003 22:21 Go to previous messageGo to next message
"Bob Foster" <bob@objfac.com> wrote in message
news:bqd7bk$tv0$1@eclipse.org...
While not simpler, it does give you the ability to install a plugin once and
link it into multiple Eclipse (or WSAD) installations.
BTW, this linking approach is *required* for plugins desiring IBM's Ready
for WebSphere Studio (RFWS) certification.
-Eric Clayberg
Sr. Vice President of Product Development
Instantiations, Inc.
mailto:cpsws-support@instantiations.com
http://www.instantiations.com
http://www.instantiations.com/codepro/ws
http://www.swt-designer.com
Re: how to install a plug-in? [message #163920 is a reply to message #163862] Mon, 01 December 2003 09:24 Go to previous messageGo to next message
thanks so much for you guys!
~louis
> -Eric Clayberg
Re: how to install a plug-in? [message #164044 is a reply to message #163862] Mon, 01 December 2003 12:19 Go to previous messageGo to next message
"Eric Clayberg" <clayberg@instantiations.com> wrote in message
news:bqebv6$v48$1@eclipse.org...
and
Good gawd, uh, I mean, good to know. ;-}
Thanks.
Bob
Re: how to install a plug-in? [message #164070 is a reply to message #163689] Mon, 01 December 2003 12:44 Go to previous messageGo to next message
Originally posted by: flippolis.freemail.it
Il Sun, 30 Nov 2003 16:16:25 +0000, Eyðun Nielsen ha scritto:
[SNIP]
Could it be possible to let eclipse know to look for plugins in another
directory, for example in the users' home directory? This would be useful
to make one installation of eclipse and let users run their own favourite
plugins (and features eventually). I looked for something like this and it
seems it is possible by the -configuration switch but I didn't understand
very well how to use it. Anybody can help?
Fabrizio
Re: how to install a plug-in? [message #164109 is a reply to message #164070] Mon, 01 December 2003 13:42 Go to previous messageGo to next message
Originally posted by: manahan.NOSPAM.ca.ibm.com
The links topic is currently under discussion in this bugzilla.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=35037
Peter
> [SNIP]
> Fabrizio
Re: how to install a plug-in? [message #164419 is a reply to message #164070] Tue, 02 December 2003 05:31 Go to previous message
Originally posted by: mark.nowhere.com
wouldn't it be possible to use the above example and just not put each
plugin into their own working folder. have a ~/eclipse-plugins folder
and under that have exlipse/plugins eclipse/features. then the
eclipse-plugins.link file would have:
path:/home/mark/eclipse-plugins
from what i gather, this should allow you to give eclipse a separate
folder to use for plugins. copy your link file to a new install folder
and there's the same plugins. of course, i haven't tried this yet...
> [SNIP]
> Fabrizio
Previous Topic:plugin for remote file access
Next Topic:What happened to eclipse-plugins.2y.net?
Current Time: Sat Jul 26 06:06:44 EDT 2025
Powered by FUDForum. Page generated in 0.62918 seconds
