TPTP piAgent [message #163466] |
Wed, 02 August 2006 13:59 |
Originally posted by: lukeivers.gmail.com
I'm trying to run the TPTP profiler on Eclipse 3.2 (installed via the web
tools package), OS=Ubuntu 6.06, TPTP release=4.2.
Any time I try to profile an application, it errors out with:
Error occurred during initialization of VM
Could not find agent library on the library path or in the local
directory: piAgent.
The only thing I've found to try to resolve this is adding the directory
with libPiAgent.so to the library path via
-Djava.library.path=/opt/eclipse/plugins/org.eclipse.hyades. execution.linux.x86_4.2.0.v200606131519
That didn't work, and I have no idea what else to do.
Re: TPTP piAgent [message #163492 is a reply to message #163466] |
Wed, 02 August 2006 15:03 |
> directory: piAgent.
You need to add a couple of libraries that aren't part of the standard
Ubuntu install. The libraries are libstdc++6 and libstc++glibc2.10.
There is a thread about the problem in the TPTP news group titled Agent
controller problem
http://www.eclipse.org/newsportal/article.php?id=2539&gr oup=eclipse.tptp#2539
Re: TPTP piAgent [message #163516 is a reply to message #163492] |
Wed, 02 August 2006 15:27 |
I have the first installed, and can't seem to find a package containing
the second one... this is kind of a question that should be more aimed at
the Ubuntu newsgroups, but since I was told about the libraries here, I
thought I'd ask anyway: where do I find that second library?
Re: TPTP piAgent [message #163581 is a reply to message #163516] |
Wed, 02 August 2006 19:18 |
I was able to install it with Synaptic. I remember that searching for
glibc in Synaptic didn't return the actual library. However, selecting
the libxxxglibc that was found automatically selected the 2.10 library as
a dependency. I removed the installation request on the library I had
originally selected and only installed the libstc++-glibc2.10 package.
You may need to enable some of the optional repositories in order for it
to show up.
FUDForum. Page generated in 0.09212 seconds
