How generic is DSF? [message #15365] |
Thu, 28 May 2009 14:34  |
Originally posted by: martin1120.hotmail.com
I was at EclipseCon and went to a session about DSF (reverse debugging -
really cool)
Now a couple of months later I'm in the position where I would like to add
debug support to
our own IDE and I thought that DSF perhaps is the solution.
Here is the situation:
The debugger and compiler is propritary to my company and cannot produce any
standard symbol formats (like ELF)
Besides the hard work is it possibile to use DSF to bridge between the
Eclipse UI and the remote debugger?
Any comments or suggestions appreciated.
BR
M
Re: How generic is DSF? [message #15398 is a reply to message #15365] |
Fri, 29 May 2009 04:25  |
Martin wrote:
> really cool)
> debug support to
Yes, definitely. In your case, you will need to define a new content
type for your output format. If you want to be able to explore symbols
etc. in the binary you will need to provide a binary parser as well.
However, you will find that also DSF tries to be as generic and flexible
as possible, there are quite a few places where the GNU/GCC/GDB bias has
snuck in.
We're working on a DSF integration with our compiler/debugger which has
all sorts of non-GNU-ish behaviors, and its actually turning out pretty ok.
/Jesper
Re: How generic is DSF? [message #572634 is a reply to message #15365] |
Martin wrote:
> really cool)
> debug support to
snuck in.
/Jesper
FUDForum. Page generated in 0.07013 seconds
