Home » Language IDEs » ServerTools (WTP) » web.xml special viewer in WTP?
web.xml special viewer in WTP? [message #163290] Wed, 08 March 2006 09:44 Go to next message
Originally posted by: kst.tipas.at
I have installed Eclipse Version 3.2 and WTP 1.5M5 shouldn't be there a new
XML editor?
Re: web.xml special viewer in WTP? [message #163399 is a reply to message #163290] Thu, 09 March 2006 08:04 Go to previous messageGo to next message
> XML editor?
Same problem here. I think M5 is broken in some way.
Look at <workspace>/.metadata/.log
I think you will see many error at start-up.
Also, the update site is broken. Error 403 for
http://download.eclipse.org/webtools/milestones/features/
Assume someone is working on this problem. ?????
Re: web.xml special viewer in WTP? [message #163733 is a reply to message #163399] Mon, 13 March 2006 20:16 Go to previous message
>> a new XML editor?
Can you be more specific about the errors you're seeing? Did you
remember to install the correct versions of GEF, JEM, and
EMF/SDO/XSD as well?
- Nitin
Previous Topic:How to migrate to WTP.
Next Topic:adding sun java system application server to wtp
Current Time: Sat Jul 26 06:01:34 EDT 2025
Powered by FUDForum. Page generated in 0.07388 seconds
