Home » Eclipse Projects » eRCP » Re: Java vm running eRCP
Re: Java vm running eRCP [message #1277] Sat, 20 June 2009 18:47 Go to next message
Hi.
How is your application configured? Do you use eWorkbench or your own workbench?
Is there an error when you try to start your application?
> Might it even be possible to run eRCP using a Midlet setup? Right now
> I'm struggeling with EclispeME and eRCP, since there are some
> unavailable classes like NoSuchMethodException etc.
> Is it simply impossible to run eRCP with midlets?
Please read this wiki article: http://wiki.eclipse.org/How_to_use_eSWT_with_Midlets
P.S.: The eRCP newsgroup has moved to eclipse.ercp.
Re: In AGR While Creating Datapool, "Link to Datapool" is not visible [message #1788237] Wed, 30 May 2018 12:24 Go to previous message
Previous Topic:Eclipse e4 application does not start in Java Web start
Next Topic:Eclipse RCP application requires JDK 1.6 on Mac
Current Time: Sun Aug 31 15:29:14 EDT 2025
Powered by FUDForum. Page generated in 0.03455 seconds
