Change default file name in the "Save as image dialog" [message #163239] |
Thu, 29 November 2007 06:29  |
Originally posted by: andreas.behnke1.gmx.de
I want to change the behavior of the command "Save as Image File" in the
context menu of my diagram in this way: Give the default file name based
on a feature of my diagrams model element. I can not find the extension
point of this context menu, where can I find it? Is this extension part
of the generated code?
Thanks in advance,
Andreas
Re: Change default file name in the "Save as image dialog" [message #163732 is a reply to message #163591] |
Mon, 03 December 2007 09:42   |
Andreas,
> Where can I find the correct ID of this contribution?
If you search for references of CopyToImageAction you will find it
contributed by DiagramUIRenderContributionItemProvider with the id
"CopyToImageAction".
> What is the path to this contribution?
In the org.eclipse.gmf.runtime.diagram.ui.render plugin's plugin.xml
file you will see where it is contributed.
> Are the default contributions documented in the GMF reference
> documentation?
Not that I am aware of.
> Is it possible to start without any default contributions?
No, but it has been requested before:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=111221
The Contribution Item Service schema provides documentation on removing
predefined items. See "popupPredefinedItem". I am almost certain you
will find examples of this in some of the generated examples, but I
could be wrong.
Regardless of all this, you are still going to have the problem that the
CopyToImageDialog class is internal.
In my opinion, if you are doing any significant customizations of the
GMF Runtime that are not covered by the examples, it is easiest to learn
by looking at the GMF code itself.
- Cherie
Andreas Behnke wrote:
> Hi Cherie,
> I could not find any example code which could help for my problem. I
> have only one extension point
> org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders
> in my plugin.xml which makes a popup contribution for a special diagram
> element. You wrote I should remove the default "CopyToImageAction"
> contribution. The following questions arise when trying to do this:
> documentation?
> Please give me a hint for a good example or documentation.
> Andreas
> The generated extension point:
> <extension
> point=" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ">
> <?gmfgen generated="false"?>
> <contributionItemProvider
> class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContribu tionItemProvider "
> checkPluginLoaded="false">
> <Priority name="Low"/>
> <popupContribution
> class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContextM enuProvider ">
> <popupStructuredContributionCriteria
> objectClass=" com.behnke.ebpm.businessusecase.edit.parts.BusinessUseCaseRe latedScenariosEditPart "/>
> <popupAction path="/editGroup" id="deleteFromModelAction"/>
> <popupPredefinedItem id="deleteFromDiagramAction"
> remove="true"/>
> </popupContribution>
> </contributionItemProvider>
> </extension>
> Cherie Revells schrieb:
>> Andreas,
>> Yes. You can look at some of the examples code to see how it is used.
>> - Cherie
>>> Hi Cherie,
>>> I can only find the extension point
>>> " org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ".
>>> Is this the correct extension?
>>>> Andreas,
>>>> The CopyToImageDialog class constructor takes a default filename,
>>>> but this class is internal. You can request to make it public if
>>>> you want. The CopyToImageAction constructs the dialog. You could
>>>> remove the default CopyToImageAction contribution and add your own
>>>> subclass. You would accomplish this with the Contribution Item
>>>> Service.
>>>> - Cherie
>>>>> Hello,
>>>>> in the context menu of my diagram in this way: Give the default
>>>>> file name based
>>>>> extension point of this context menu, where can I find it? Is this
>>>>> extension part
>>>>> Thanks in advance,
>>>>> Andreas
Re: Change default file name in the "Save as image dialog" [message #164032 is a reply to message #163732] |
Tue, 04 December 2007 05:12  |
Hi Cherie,
I will take your advice. At the moment I only managed to add a new
action to the popup menu with the org.eclipse.ui.popupmenus extension
point. Any contributions to
were without any effect, don't know what I am missing. I will report
back if I have a working solution.
Andreas
FUDForum. Page generated in 0.07285 seconds
