Home » Archived » DSDP - Real-Time Software Components (RTSC) » correct way to set profile for executable
correct way to set profile for executable [message #1272] Fri, 20 February 2009 15:58 Go to next message
What is the correct way to set the profile for an executable? I have seen
two different ways, one using cfgArgs (see 1 below) and the other using
profile (see 2 below). I do not see option 1 clearly explained in
http://rtsc.eclipse.org/cdoc-tip/index.html#xdc/bld/Library. html#.Attrs
but it occurs in examples.
Pkg.addExecutable( serverName, targ, targ.platform,
tcopts: "-Dxdc.cfg.check.fatal=false",
cfgScript: "server.tcf",
---> (1) cfgArgs: '{profile: "' + arguments[0] + '"}',
---> (2) profile: arguments[0],
lopts: "-l link.cmd",
addObjects( [
"main.c",
Katie
Re: correct way to set profile for executable [message #1494 is a reply to message #1272] Mon, 23 February 2009 10:36 Go to previous message
Katie Roberts-Hoffman wrote:
> Hello,
> seen two different ways, one using cfgArgs (see 1 below) and the other
> using profile (see 2 below). I do not see option 1 clearly explained in
> addObjects( [
> "main.c",
> Katie
cfgArgs is unrelated to profiles; it is only used to pass arguments
specified in your build script to a program's configuration script. If
a configuration script does not look at these arguments, they have no
affect. Moreover, _anything_ can be passed in cfgArgs.
Setting profile, on the other hand, affects the compiler options used to
build any sources associated with the profile. In the example above
main.c will be compiled with options defined by the profile named by
arguments[0].
Previous Topic:ModA changing ModB's module parameters
Next Topic:How to use @opts-file with xs command
Current Time: Mon Jul 21 21:15:18 EDT 2025
Powered by FUDForum. Page generated in 0.44600 seconds
