Home » Eclipse Projects » Eclipse Platform » Error on Startup
Error on Startup [message #163094] Thu, 27 November 2003 16:06
Originally posted by: esacchi.ksasociados.com
I've been working with Eclipse since May, but today when I tried to startup
(Eclipse 2.1.2) a little window with then next message
Problems during startup. Check the ".log" file
in the ".metadata" directory of your workspace.
Thanks for your help
Emiliano
My .log file....
!SESSION nov 27, 2003 18:02:40.882 ---------------------------------------------
java.version=1.4.2
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=es_ES
Command-line arguments: -os linux -ws gtk -arch x86 -data
/net/homes/emiliano/eclipse -install
file:/net/local/eclipse/eclipse-SDK-2.1.2-linux-gtk/
!ENTRY org.eclipse.core.runtime 4 2 nov 27, 2003 18:02:40.888
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
org.eclipse.core.internal.dtree.ObjectNotFoundException: Tree element
/ADPT-X/java/com/ksit/gw/MailBoxHandler.java not found.
org.eclipse.core.internal.dtree.AbstractDataTree.handleNotFo und(AbstractDataTree.java:243)
org.eclipse.core.internal.dtree.DeltaDataTree.getData(DeltaD ataTree.java:608)
org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelt a(DataDeltaNode.java:54)
org.eclipse.core.internal.dtree.NoDataDeltaNode.asBackwardDe lta(NoDataDeltaNode.java:56)
org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelt a(DataDeltaNode.java:51)
org.eclipse.core.internal.dtree.DeltaDataTree.asBackwardDelt a(DeltaDataTree.java:95)
org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDa taTree.java:819)
org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDa taTree.java:818)
org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDa taTree.java:794)
org.eclipse.core.internal.watson.ElementTree.immutable(Eleme ntTree.java:698)
org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.java:511)
org.eclipse.core.internal.resources.SaveManager.startup(Save Manager.java:1033)
!ENTRY org.eclipse.core.runtime 4 2 nov 27, 2003 18:02:40.931
!MESSAGE Plug-in "org.eclipse.ui" was unable to instantiate class
"org.eclipse.ui.internal.Workbench".
!STACK 0
org.eclipse.core.internal.boot.DelegatingLoaderException:
org.eclipse.core.runtime.CoreException: Problems encountered starting up
plug-in: "org.eclipse.core
..resources".
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:754)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:188)
org.eclipse.core.internal.plugins.PluginClassLoader.activate Plugin(PluginClassLoader.java:112)
org.eclipse.core.internal.plugins.PluginClassLoader.internal FindClassParentsSelf(PluginClassLoader.java:185)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassParentsSelf(DelegatingURLClassLoader.java:490)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:882)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.acce ss$0(DelegatingURLClassLoader.java:876)
org.eclipse.core.internal.boot.DelegatingURLClassLoader$Dele gateLoader.loadClass(DelegatingURLClassLoader.java:90)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassPrerequisites(DelegatingURLClassLoader.java:554)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:890)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(DelegatingURLClassLoader.java:862)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:16 10)
at java.lang.Class.getConstructor0(Class.java:1922)
at java.lang.Class.newInstance0(Class.java:278)
at java.lang.Class.newInstance(Class.java:261)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:138)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:167)
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExtension(ConfigurationElement.java:103)
org.eclipse.core.internal.runtime.InternalPlatform.loaderGet Runnable(InternalPlatform.java:578)
!ENTRY org.eclipse.core.runtime 4 2 nov 27, 2003 18:02:40.937
!STACK 0
..resources".
!SESSION ------------------------------------------------------------ ----------
!ENTRY org.eclipse.core.launcher 4 0 nov 27, 2003 18:02:41.18
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.reflect.InvocationTargetException
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Caused by: java.lang.IllegalArgumentException: Application not found:
org.eclipse.ui.workbench.
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:856)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
... 7 more
Previous Topic:I don't found BasicTextEditorActionContributor.java
Next Topic:Problem starting M5
Current Time: Thu Jul 17 20:16:05 EDT 2025
Powered by FUDForum. Page generated in 0.03740 seconds
