Home » Language IDEs » C / C++ IDE (CDT) » Eclipse crashes easily
Eclipse crashes easily [message #163079] Fri, 03 February 2006 00:35 Go to next message
Originally posted by: bongo.silvertine.net
Hi all,
I was really hoping I had found an IDE to settle with, but it seems that Eclipse
crashes if you sneeze. So far, it has crashed 3 times, and I've only been using
it for a week or so. By crash, I mean the whole thing closes and I get a dialog
with something like:
JVM terminated. Exit code=1
/usr/bin/java
-Xms40m
-Xmx256m
-jar /usr/local/eclipse/startup.jar
-os linux
-ws gtk
-arch x86
-launcher /usr/local/eclipse/eclipse
-name Eclipse
-showsplash 600
-exitdata 1370010
-vm /usr/bin/java
-vmargs
-Xms40m
-Xmx256m
Once, it crashed when I was scrolling through a file to go to a compile error.
The other 2 were while running in the debugger. The only thing that changes in
the dialog is the -exitdata #, but that doesn't mean anything to me. I've heard
Java programs are prone to crashes - I wonder if this is a result. Does anyone
else experience this? If not, any ideas what the problem might be?
thanks,
Jason
Re: Eclipse crashes easily [message #163095 is a reply to message #163079] Fri, 03 February 2006 02:53 Go to previous message
Hi Jason,
eclipse has been pretty nice and stable for me both on WinXP and Linux.
Though a colleague of mine experienced a reproducable crash of the kind you
are describing and we finally agreed that it was probably his peculiar
combination of Java VM, GTK version and graphics adapter ...
Maybe it would be helpful if you could post your OS, Java VM and eclipse
versions?
Bye
Norbert Ploett
Previous Topic:How to tell if CDT installed? Nothing when compiling.
Next Topic:MBS: Options of Type "lib" don't work
Current Time: Tue Jul 22 12:07:55 EDT 2025
Powered by FUDForum. Page generated in 0.04201 seconds
