Problems after upgrade [message #163036] |
Tue, 07 March 2006 06:01  |
I was running WTP (I think 1.0) under Eclipse 3.1 and in order to try to
fix another problem I upgraded yesterday.
Most of my projects were fine, but one or two are throwing up odd errors
which I do not understand.
My web.xml file is being rejected although it has not changed. It starts:-
<web-app id="WebApp_ID"
version="2.4"
xmlns="http://java.sun.com/xml/ns/j2ee"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://java.sun.com/xml/ns/j2ee
http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd">
<servlet>
<description>TrackTrans XML servlet</description>
<display-name>TrackTrans</display-name>
<servlet-name>TrackTrans</servlet-name>
<servlet-class>uk.co.dga.xml.TrackTrans</servlet-class>
<load-on-startup>1</load-on-startup>
</servlet>
But WTP tags the first line, the description line and the servlet-name line
as errors:-
Severity Description Resource In Folder Location Creation Time Id
2 Referenced file contains errors
(http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd). For more information,
right click on the message and select "Show Details..." web.xml
TrackTrans/WebContent/WEB-INF line 1 07 March 2006 10:25:12 3499
2 cvc-complex-type.2.4.a: Invalid content was found starting with element
'description'. One of '{"http://java.sun.com/xml/ns/j2ee":servlet-name}' is
expected. web.xml TrackTrans/WebContent/WEB-INF line 8 07 March 2006
10:25:12 3500
2 cvc-id.3: A field of identity constraint 'web-app-servlet-name-uniqueness'
matched element 'web-app', but this element does not have a simple type.
web.xml TrackTrans/WebContent/WEB-INF line 10 07 March 2006 10:25:12 3501
Anyone got any ideas as to what it might be going on about.
It also seems only to be able to find the level 2 DOM definitions of
org.w3c.dom.Text and org.w3c.dom.DOMImplementation. And yet the language
level is set to 5.0, and it is accepting Generics (which obviously did not
exist in 1.4. This however is probably not a WTP error, but a JDT error.
David
Re: Problems after upgrade [message #163109 is a reply to message #163085] |
Tue, 07 March 2006 11:24  |
>> The versions I am running are Eclipse 3.1.2 and WST 1.0.1.v200602130105.
>>> starts:-
>>> <?xml version="1.0" encoding="UTF-8"?>
>>> version="2.4"
>>> <servlet>
>>> </servlet>
> I notice in all the sample web-apps in the tomcat5.5 directory that the
> description and display name tags should be outside the servlet tag. So
> I moved them but to no avail. WTP still complains.
> David
>>> line as errors:-
>>> Creation Time Id
>>> information, right click on the message and select "Show Details..."
>>> web.xml
>>> Creation Time Id
>>> element 'description'. One of
>>> 2006
>>> 10:25:12 3500
>>> Creation Time Id
>>> 'web-app-servlet-name-uniqueness' matched element 'web-app', but this
>>> 3501
>>> language level is set to 5.0, and it is accepting Generics (which
>>> obviously did not
>>> error.
>> One further point on this one, which suggests that it might be a WTP
>> problem is that there is another project in the same workspace but it is
>> an "Other Project" which has identical code (I cut and pasted it to
>> check) and does
>> not have this problem. I have checked that the workspace default is Java
>> 5.0 and that neither project overrides that default.
>>> David
Well it turned out that the first problem (with web.xml) was a corrupt copy
of the xsd file in the cache. I turned off the cache and suddenly it
worked. Perhaps as a suggestion the quick-fix for this kind of error should
suggest clearing the cache and reloading it (if it is turned on). This
would be in the case where there were parsing errors in a file in the
cache. In the Show-Details response it just gave mountains of errors.
That just leaves the Java problem.
Dav id
FUDForum. Page generated in 0.04052 seconds
