Home » Language IDEs » C / C++ IDE (CDT) » CDT + GLUT
CDT + GLUT [message #162850] Tue, 31 January 2006 19:48 Go to next message
Originally posted by: radu.solomon.gmail.com
for one of my courses I need to writte an OpenGL C++ project based on
glut. I am using an iBook G4 with Tiger 10.4.3, Java 1.5 and g++ and gcc.
I got Eclipse and installed CDT project and it all works fine as long as i
do not try to import the GLUT framework. As soon as I do, i can see the
framework in my list of packages but when i try to import with
#include <GLUT/glut.h>
I get the following:
1. /usr/bin/ld Undefined symbols:
2. C/C++ Indexer Problem: Preprocessor Inclusion not found: GLUT/glut.h in
file: /Users/radu/Documents/workspace/TestGLUT/animate_skel.cpp on line:
35. animate_skel.cpp
Any help how to get over this will be appreciate as I do not like to run
VS.Net in the Windows on VirtualPC on my iBook.
Re: CDT + GLUT [message #162865 is a reply to message #162850] Wed, 01 February 2006 02:38 Go to previous messageGo to next message
Radu,
some path settings appear to be missing. Look through the project properties
for places where include and library paths may be specified. I think we need
more information about your setup to be able to give good answers.
- Are you using managed or standard make projects
- Where are the GLUT headers relative to your sources and relative to
standard include directories?
- Where are the libraries?
Norbert
Re: CDT + GLUT [message #162935 is a reply to message #162865] Wed, 01 February 2006 13:21 Go to previous messageGo to next message
- I tried both managed and un managed projects
- The GLUT is installed in the default location on Mac OSX Tiger which is
/System/Library/Frameworks/GLUT.framework
/System/Library/Frameworks/OpenGL.framework
In the linker in my project, I specifically included this two paths but
with no luck. The thing is that any other application compiles as long as
I do not use GLUT. However, i tried codewarriro and my program compiled
without any problems and it found the GLUT libraries.
Radu
Norbert Ploett wrote:
> Radu,
> Norbert
Re: CDT + GLUT [message #163545 is a reply to message #162935] Thu, 09 February 2006 13:12 Go to previous message
I guess there is no way to use CDT + GLUT on a Mac which is dissapointing
because I like eclipse and I used it for my Java development. I guess I
will have to look at different development IDE's. The thing that
dissapoints me is that there is no tutorial on how to set up it on a Mac
but rather only on Windows.
Radu wrote:
> Thanks
> Radu
>> Radu,
properties
need
>> Norbert
Previous Topic:Build All command does not work
Next Topic:Autocreating Managed Make Files?
Current Time: Tue Nov 25 11:24:59 EST 2025
Powered by FUDForum. Page generated in 0.06065 seconds
