CDT + GLUT [message #162850] |
Tue, 31 January 2006 19:48  |
Originally posted by: radu.solomon.gmail.com
for one of my courses I need to writte an OpenGL C++ project based on
glut. I am using an iBook G4 with Tiger 10.4.3, Java 1.5 and g++ and gcc.
I got Eclipse and installed CDT project and it all works fine as long as i
do not try to import the GLUT framework. As soon as I do, i can see the
framework in my list of packages but when i try to import with
#include <GLUT/glut.h>
I get the following:
1. /usr/bin/ld Undefined symbols:
2. C/C++ Indexer Problem: Preprocessor Inclusion not found: GLUT/glut.h in
file: /Users/radu/Documents/workspace/TestGLUT/animate_skel.cpp on line:
35. animate_skel.cpp
Any help how to get over this will be appreciate as I do not like to run
VS.Net in the Windows on VirtualPC on my iBook.
Re: CDT + GLUT [message #163545 is a reply to message #162935] |
Thu, 09 February 2006 13:12  |
I guess there is no way to use CDT + GLUT on a Mac which is dissapointing
because I like eclipse and I used it for my Java development. I guess I
will have to look at different development IDE's. The thing that
dissapoints me is that there is no tutorial on how to set up it on a Mac
but rather only on Windows.
Radu wrote:
> - I tried both managed and un managed projects
> - The GLUT is installed in the default location on Mac OSX Tiger which is
> /System/Library/Frameworks/GLUT.framework
> /System/Library/Frameworks/OpenGL.framework
> In the linker in my project, I specifically included this two paths but
> with no luck. The thing is that any other application compiles as long as
> I do not use GLUT. However, i tried codewarriro and my program compiled
> without any problems and it found the GLUT libraries.
> Thanks
> Radu
> Norbert Ploett wrote:
>> Radu,
>> some path settings appear to be missing. Look through the project
properties
>> for places where include and library paths may be specified. I think we
need
>> more information about your setup to be able to give good answers.
>> - Are you using managed or standard make projects
>> - Where are the GLUT headers relative to your sources and relative to
>> standard include directories?
>> - Where are the libraries?
>> Norbert
FUDForum. Page generated in 0.05239 seconds
