Home » Eclipse Projects » GEF » Draw2d Figures with transparency
Draw2d Figures with transparency [message #162833] Tue, 28 December 2004 08:31 Go to next message
Originally posted by: kardo.mail.pt
How can I make a
Draw2d
RectanguleFigure
(extends Figure)
with transparency?
Thks in advanced.
Ricardo Marques
Re: Draw2d Figures with transparency [message #162880 is a reply to message #162833] Tue, 28 December 2004 10:36 Go to previous messageGo to next message
Don't fill in the figure's bounds, and it is transparent.
"Ricardo Marques" <kardo@mail.pt> wrote in message
news:cqrn7d$kqp$1@www.eclipse.org...
> How can I make a
> Draw2d
> RectanguleFigure
> (extends Figure)
> with transparency?
> Thks in advanced.
> Ricardo Marques
Re: Draw2d Figures with transparency [message #162887 is a reply to message #162880] Tue, 28 December 2004 10:49 Go to previous messageGo to next message
But I don't want transparent, I want with transparency. For example I want 50%
opaque or transparent. An Image has an alpha value.
Re: Draw2d Figures with transparency [message #162956 is a reply to message #162887] Wed, 29 December 2004 01:38 Go to previous messageGo to next message
Originally posted by: eostroukhov.hotmail.com
There's no support for alpha values (at least I haven't seen any), but you
could try setXORFill(true). In the case you need trasparency for the
feedback painting, take a look at FigureUtilities::makeGhostShape.
"netb" <kardo@mail.pt> wrote in message news:cqrvam$f71$1@www.eclipse.org...
> 50%
Re: Draw2d Figures with transparency [message #163005 is a reply to message #162887] Wed, 29 December 2004 11:25 Go to previous messageGo to next message
The only transparency support in SWT is via Image. You'll have to create a
transparent image, and paint the Image. It's a pretty expensive workaround.
You can stretch a small image. See ScrollableThumbnail for an example in
GEF.
boa sorte.
50%
Re: Draw2d Figures with transparency [message #163050 is a reply to message #163005] Thu, 30 December 2004 07:37 Go to previous messageGo to next message
Hi have tried to use makeGhostShape() and it worked. It's not exactly what
I want but for now it will do.
But I will try this workarround, it could be better.
Muito Obrigado!
> GEF.
> boa sorte.
> 50%
Re: Draw2d Figures with transparency [message #185057 is a reply to message #163050] Wed, 22 June 2005 03:11 Go to previous message
Since 3.1 there is Alpha Transparency Supported in the Graphics class.
Here a snippet for a transparent Polygon (NON XOR)
public class TransparentPolygonFigure extends Polygon {
private int m_transparencyValue = 50;
private int m_transparencyValueOutline = 50;
protected void fillShape(Graphics g) {
// must call it before super
g.setAlpha(m_transparencyValue);
g.setAntialias(SWT.ON);
super.fillShape(g);
protected void outlineShape(Graphics g) {
g.setAlpha(m_transparencyValueOutline);
super.outlineShape(g);
public void setTransparentFill(int value) {
m_transparencyValue = value;
public void setTransparentOutline(int value) {
m_transparencyValueOutline = value;
> what I want but for now it will do.
> Muito Obrigado!
>> create a
>> workaround.
>> GEF.
>> boa sorte.
>>> want
>> 50%
Previous Topic:Do I need EditPolicy.LAYOUT_ROLE just to select a child?
Next Topic:guides on ruler not displaying properly
Current Time: Mon Jul 14 10:07:30 EDT 2025
Powered by FUDForum. Page generated in 0.28283 seconds
