Home » Eclipse Projects » Eclipse Platform » SAX2 driver class org.apache.xerces.parsers.SAXParser not found
SAX2 driver class org.apache.xerces.parsers.SAXParser not found [message #162759] Thu, 27 November 2003 05:46 Go to next message
Originally posted by: johannes.neuber.gmx.de
Hello everybody,
once again I've a question about referencing specific libraries, which
are requiered for running my plugin. This plugin contains an Image Viewer
for displaying SVG Graphics. Therefor several external "Batik" libraries
(jar's) are requiered. I've created a "Batik Eclipse plugin" which simly
wraps the 20 Batik jar's. So I'm able to import the required "Batik
Plugin" in the plugin.xml of my Image Viewer, instead of referencing all
jar-libraries manually.
Running the Plugin within a Run-time Workbech works fine until the
following code inside my SVGLoader class is reached:
String parser = XMLResourceDescriptor.getXMLParserClassName();
SAXSVGDocumentFactory f = new SAXSVGDocumentFactory(parser);
svgDocument = f.createSVGDocument(svgURL.toString());
At this point the following java.io.IOException is thrown:
at org.apache.batik.dom.util.SAXDocumentFactory.createDocument( Unknown
Source)
at org.apache.batik.dom.svg.SAXSVGDocumentFactory.createDocumen t(Unknown
Source)
org.apache.batik.dom.svg.SAXSVGDocumentFactory.createSVGDocu ment(Unknown
Source)
I don't understand this exception because the requiered SAXParser class
exists within the "xerces_2_3_0.jar" of my "Batik-Plugin" ... !
All other classes and libraries of this plugin are imported correctly
to the Image Viewer plugin - only the SAXParser makes problems! Why ?
May it be possible that there are any conflicts with the Eclipse's
Xerces Plugin ?
Here's a short excerpt of my Image Viewer's plugin.xml:
<plugin
id="java.xyz.editor"
class="xyzEditorClass">
<runtime>
<library name="runtime/"><export name="*"/></library>
</runtime>
<requires>
<import plugin="org.apache.batik" export="true"/>
</requires>
<extension point="org.eclipse.ui.views">
<view name="Image View"
</view>
</extension>
</plugin>
... and the "Batik-Plugin's" *.xml file looks like this:
<plugin
id="org.apache.batik"
name="%pluginName"
version="1.5"
provider-name="%providerName">
<runtime>
<!-- ... here all batik jar's are listed ... -->
<library name="lib/xerces_2_3_0.jar">
<export name="*"/>
</library>
</runtime>
</plugin>
Thanks in advance ...
Johannes
Re: SAX2 driver class org.apache.xerces.parsers.SAXParser not found [message #162823 is a reply to message #162759] Thu, 27 November 2003 07:45 Go to previous message
The problem is solved ...! If I insert the following line of code:
Thread.currentThread().setContextClassLoader(getClass().getC lassLoader());
before i call "svgDocument = f.createSVGDocument(svgURL.toString());"
all works fine and the SVGDocument is parsed correctly! This seems to
be an old and well known Eclipse problem. A short description can be
found here: http://eclipsewiki.swiki.net/114#context
Although I don't really understand the problem, it works now ! Would
somebody like to explain ?
"the very confused" Johannes *g
Johannes wrote:
> Hello everybody,
> Source)
> Source)
> at
> Source)
> Xerces Plugin ?
> <plugin
> <runtime>
> </runtime>
> <requires>
> </requires>
> </view>
> </extension>
> </plugin>
> <plugin
> name="%pluginName"
> version="1.5"
> <runtime>
> <export name="*"/>
> </library>
> </runtime>
> </plugin>
> Johannes
Previous Topic:Howto Assert/Ensure that the platform is initialized
Next Topic:How to contribute classes to another plugin
Current Time: Mon Jul 14 14:14:25 EDT 2025
Powered by FUDForum. Page generated in 0.13045 seconds
