Home » Language IDEs » C / C++ IDE (CDT) » "space" character between option and argument - howto?
"space" character between option and argument - howto? [message #162742] Mon, 30 January 2006 17:45 Go to next message
Originally posted by: stenny.gmx.de
I'm just developing a tiny CDT plugin to support my cross compilation
tool chain in the managed make environment.
With that, I'm having difficulties defining command line options to the
tools, which require som sort of parameter and a space separating the
option and the parameter.
Just one example:
With most C-Compilers, include paths are given in this way
"-I/path/to/include".
In the CDT plugin, I define an option with the command being "-I" and
the type being an includePath and the browseType set to "directory".
Now I need a similar setup for special include paths. Th C-Compiler I
have to use supports the option "-sys_include_directory
/path/to/include". It definitely needs the space between option and
path. How do I specify options, which are separated from their arguments
by a space?
thanks
stefan
Re: "space" character between option and argument - howto? [message #162760 is a reply to message #162742] Tue, 31 January 2006 02:21 Go to previous messageGo to next message
Hi Stefan,
surely you have already noticed the "CDT Extensibility Document" (Menu
Help --> Contents -->CDT Plugin Developers Guide --> Programmer's Guide -->
Managed Build System Extensibility Document
The "option" element is described in section 3.13, and in the big table in
3.13.4 ("Schema") it says:
command
An optional value that specifies the actual command that will be passed
to the tool on the command line. The command provides a "pattern" for
specifying where the value should be placed for options of type string and
stringlist. The pattern can contain the replaceable variable "value". If
no ${value} is specified in the command, the option value is appended to the
end of the specified command.
So you could try to specify
"-sys_include_directory "
(note the blank behind -sys_include_directory) or, even more explicitly
"-sys_include_directory ${value}"
Norbert
Re: "space" character between option and argument - howto? [message #162818 is a reply to message #162760] Tue, 31 January 2006 16:24 Go to previous message
Norbert Ploett wrote:
> Hi Stefan,
> command
thanks a lot ...
meanwhile I discovered, that thorough reading of the documentation can
effectively avoid such questions.
The setting "-sys_include_directory ${value}" does exactly, what I expect.
Thank you
stefan
Previous Topic:Custom build step causes null pointer exception in addFragmentMakefileEntriesForSource()
Next Topic:Excluding sub directories from build
Current Time: Fri May 16 06:31:45 EDT 2025
Powered by FUDForum. Page generated in 0.03280 seconds
