Home » Eclipse Projects » Eclipse Platform » createLineBreakpoint
createLineBreakpoint [message #162709] Thu, 27 November 2003 04:57 Go to next message
Originally posted by: brogger.daimi.au.dk
Hi.
Im writing an IDE that uses the JDT debugger. It works to some extent -
it is possible to create a line break point. Running the code in debug
mode then stops at the indicated line.
The only problem is that I can't make the little icon appear in the
vertical ruler. Im using the method
JDIDebugModel.createLineBreakpoint(...) (and I can see that JDT does
excatly the same), which should create a marker in the ruler.
My first guess was that the image that should be inserted was not
available - so I copied the "icon" directory into my plug-in workspace
directory - but it didn't help.
Any help will be appreciated,
Mads
Re: createLineBreakpoint [message #162918 is a reply to message #162709] Thu, 27 November 2003 10:41 Go to previous messageGo to next message
The icon appears in the ruler based on the resource that the breakpoint
marker is associated with. Have you done the same as JDT in this respect?
Darin
"Mads Brogger Enevoldsen" <brogger@daimi.au.dk> wrote in message
news:3FC5CA82.2CA715AF@daimi.au.dk...
> Hi.
> Mads
Re: createLineBreakpoint [message #163003 is a reply to message #162918] Thu, 27 November 2003 11:50 Go to previous messageGo to next message
No I haven't. I couldn't find the place where there was mentioned anything
about images or resources.
All I have is the following declaration in plugin.xml
<action
label="Beta Breakpoint"
class=" org.eclipse.ui.betaeditor.launching.BetaBreakpointRulerActio nDelegate "
actionID="RulerDoubleClick"
id="org.eclipse.ui.betaeditor.actions.BetaBreakpointAction" >
</action>
So how do I associate a ressource with the breakpoint?
Mads
> Darin
> > Hi.
> > Mads
Re: createLineBreakpoint [message #163086 is a reply to message #163003] Thu, 27 November 2003 14:32 Go to previous messageGo to next message
The breakpoint creation APIs accept a resource. See
JDIDebugModel.createLineBreakpoint(...) for example. The first argument is a
resource.
For examples on how the Java debugger associates resources with breakpoints
see BreakpointUtils in org.eclipse.jdt.debug.ui (but note, this is an
internal class).
Darin
news:3FC62B5C.D0FF844D@daimi.au.dk...
> <action
> </action>
> Mads
respect?
> > Darin
> > > Hi.
extent -
does
> > > Mads
Re: createLineBreakpoint [message #163179 is a reply to message #163086] Fri, 28 November 2003 03:48 Go to previous messageGo to next message
Yes the JDIDebugModel.createLineBreakpoint() accepts a resource, and it gets it
by calling the method getBreakpointResource(IMember member).
The JavaDoc for this method reads:
* Returns the resource on which a breakpoint marker should
* be created for the given member. The resource returned is the
* associated file, or project in the case of a class file in
* a jar.
I can't see what that has to do with the image appearing in the ruler. To me
this method simply finds the IResource correspondig to the file currently being
edited.
I find the IResource with the following code:
protected IResource getResource() {
IEditorInput input= fEditor.getEditorInput();
IResource resource= (IResource) input.getAdapter(IFile.class);
if (resource == null) {
resource= (IResource) input.getAdapter(IResource.class);
return resource;
The Breakpoint is created porpberly - running the debugger makes it stop at the
right location.
My question is: Where do I declare what image that should be shown in the
ruler?
> resource.
> internal class).
> Darin
> > <action
> > </action>
> > Thanks,
> > Mads
> respect?
> > > Darin
> > > > Hi.
> extent -
> does
> > > > Mads
Re: createLineBreakpoint [message #163316 is a reply to message #163179] Fri, 28 November 2003 10:04 Go to previous messageGo to next message
The editor displays annotations in its vertical ruler. The editor knows
about breakpoints because each breakpoint has an associated marker, which
displays as an "annotation" in the ruler. When the marker changes
(created/modified/removed), a resource delta is fired and the editor knows
to update the annotation. The image for a breakpoint is retrieved from a
debug model presentation - in this case, the Java debugger contributes a
"model presentation" that is used to render elements from the Java debug
model.
See the Java editor as an example.
Darin
news:3FC70BDE.E60DC570@daimi.au.dk...
gets it
> * a jar.
me
being
> edited.
> return resource;
at the
> right location.
> ruler?
is a
> > resource.
breakpoints
> > internal class).
> > Darin
anything
> > > <action
> > > </action>
> > > Thanks,
> > > Mads
breakpoint
> > respect?
> > > > Darin
> > > > > Hi.
> > extent -
debug
the
> > does
workspace
> > > > > Mads
Re: createLineBreakpoint [message #164518 is a reply to message #163316] Tue, 02 December 2003 06:05 Go to previous messageGo to next message
> model.
> Darin
I've tried to add a debug model presentation to my plug-in. I write the
following extension in the plugin.xml
<extension point = "org.eclipse.debug.ui.debugModelPresentations">
<debugModelPresentation
class = "org.eclipse.jdt.internal.debug.ui.JDIModelPresentation"
id = "org.eclipse.jdt.debug"
</debugModelPresentation>
</extension>
This is exactly the same as JDT does. I can trace the addBreakpoint call down
into the JDIDebugModel and further on into JavaLineBreakpoint - but it is as if
the JDIModelPresentation doesn't get used. The method getImage is never called
(as it is in Java mode).
It's hard to figure out what is happening in the JDT editor, but do I need a
Resource delta listener registered - and make it react to resource changes
using the JDIModelPresentation?
Mads
Re: createLineBreakpoint [message #164631 is a reply to message #164518] Tue, 02 December 2003 09:28 Go to previous messageGo to next message
You cannot re-define the JDT model presentation. The Java debugger
contributes its model presentation for the Java debug model, identified by
"org.eclipse.jdt.debug". There can only be one presentation per debug
model - and this duplicate definition may cause trouble.
I don't understand what you are trying to accomplish. Perhaps you could
explain the problem you are trying to solve.
Darin
news:3FCC720E.78F7D4EC@daimi.au.dk...
which
knows
> > model.
> > Darin
> class =
> </extension>
down
as if
called
a
> Mads
Re: createLineBreakpoint [message #165863 is a reply to message #164631] Thu, 04 December 2003 10:28 Go to previous message
Im writing an IDE for the language Beta. The Beta compiler generates Java
bytecodes, so it is natural to reuse some of the clases in JDT. In fact the
class I use as the launch delegate is
JavaLocalApplicationLaunchConfigurationDelegate.
So launching applications works perfectly fine! But debugging is more
complicated. I've made the ruler respond to double clicks and let the
corresponding action be to insert a breakpoint. In the code I have the
code: JDIDebugModel.createLineBreakpoint(resource, "beta.program", lineNo, -1,
-1, 0, true, null).
And this almost works. The only thing missing is the little icon appearing in
the ruler - the debugger stops executing when reaching the specified line.
So what Im really asking: How do I make the little icon appear in the ruler?
Mads
> Darin
Previous Topic:plugin.xml
Next Topic:debugger error messages
Current Time: Sat Jul 26 06:07:34 EDT 2025
Powered by FUDForum. Page generated in 0.06720 seconds
