3M9 - very unstable (with 1.5) [message #162560] |
Thu, 03 June 2004 12:07  |
Originally posted by: avinu.papayasoft.net
i had the following problems:
1. freezing of the IDE when trying to paste text. It was consistent with
that particular class.
2. classes that when i tried to save them, the save failed. Again - it
was consistent with the same class (a different one).
In both cases i tried to delete the class and recreate it - it didn't
help. i now have a problem - i need to work on those classes. i guess
i'll have to recreate a workspace and get the stuff from the cvs.
However - it maybe a bug that relates to the content of my code (im
using the 1.5 EA patch, so it might be related) and then it won't help.
Ah... i hope eclipse will start to stabilize and move toward the 1.5
instead of adding more and more marginal features....
Wouldn't you agree?
Re: 3M9 - very unstable (with 1.5) [message #163389 is a reply to message #162907] |
Wed, 09 June 2004 07:50  |
Right, this is up to you to live dangerously. But to be fair, you should
report such failures to the VM vendor.
FYI - looking at 1.5 libraries (when addressing strange Cheetah compiler
bugs) I observed quite a few exotic attribute values, which were not
following the spec (remember also that 3rd edition of the specs hasn't been
finalized yet).
However, if you can reproduce these with a stable JRE 1.4 release, then yes
we should definitely look into it.
"Johan Compagner" <jcompagner@j-com.nl> wrote in message
news:c9s797$ju0$1@eclipse.org...
> I run RC1 on 1.5.0b2 just as i runned all the eclipse builds on 1.5b1 as
long
> as 1.5b1 was around. I didn't find any problems with the combo eclipse/1.5
> I did find quite a few other problems in 1.5b1 and b2 that i already
reported
> for example both beta's are not able to start our webstart application:
> http://demo.servoy.com:8080
> johan
> Artur Biesiadowski wrote:
> > Adam Kiezun wrote:
> >> Don't run eclipse on 1.5, it's not supported!
> >> No wonder you have problems. You're running a pre-release software on
> >> a beta jdk. Are you at least running a stable version of the OS?
> >> BTW, I'm hacking and building 1.5 code on m9 not problem. But i'd
> >> never even for a second consider _running_ m9 on 1.5 JRE.
> > I was running M8 on 1.5beta1 and it worked perfectly for me - still had
> > no chance to really try M9/beta2 combo.
> > Given such mindset, we would be still running Eclipse 2.0 on jdk 1.3
> > running windows 2000 - and who would file bugs against new releases ? ;)
> > Artur
FUDForum. Page generated in 0.06896 seconds
