Home » Archived » BIRT » Error when running current BIRT from CVS
Error when running current BIRT from CVS [message #15282] |
Mon, 07 March 2005 16:30  |
I've got the current BIRT checked out from CVS. I've added ojdbc14.jar to
org.eclipse.birt.report.data.oda.jdbc, and added jodbc14.jar to
odaconfig.xml in the same project. I'm able to create a data source and
start on a dataset, but I get the following error when trying to do anything
with the data set.
org.eclipse.birt.data.engine.core.DataException occurred
Error Code:DATA_EXCEPTION_odaconsumer.OdaInitEntryNotFound
Error Message:org.eclipse.birt.report.data.oda.jdbc.JDBCConnection Factory
cannot be found or cannot be instantiated.
Unable to create the ODA driver's connection factory.
org.eclipse.birt.report.data.oda.jdbc.JDBCConnectionFactory
Any ideas?
Re: Error when running current BIRT from CVS [message #16709 is a reply to message #16694] |
Wed, 09 March 2005 17:19   |
Do you have any special characters in names?
Can you provide your query which fails?
I have the following and it works.
SELECT "DEMO"."DEPARTMENT"."DEPARTMENT_ID",
"DEMO"."DEPARTMENT"."NAME",
"DEMO"."DEPARTMENT"."LOCATION_ID",
"DEMO"."EMPLOYEE"."EMPLOYEE_ID",
"DEMO"."EMPLOYEE"."LAST_NAME",
"DEMO"."EMPLOYEE"."FIRST_NAME",
"DEMO"."EMPLOYEE"."MIDDLE_INITIAL",
"DEMO"."EMPLOYEE"."JOB_ID",
"DEMO"."EMPLOYEE"."MANAGER_ID",
"DEMO"."EMPLOYEE"."HIRE_DATE",
"DEMO"."EMPLOYEE"."SALARY",
"DEMO"."EMPLOYEE"."COMMISSION"
FROM ("DEMO"."DEPARTMENT" INNER JOIN "DEMO"."EMPLOYEE" ON
"DEMO"."DEPARTMENT"."DEPARTMENT_ID" = "DEMO"."EMPLOYEE"."DEPARTMENT_ID" )
Also file a bugzilla entry with the query so that somebody can look at
it to see whether it is a bug.
Roshan
Thierry Lach wrote:
> I'm not having the problem with SQL*Plus. It runs there just fine. The
> query is failing when run inside of BIRT.
> "Roshan" <rail@actuate.com> wrote in message
> news:d0l8v7$3b2$1@www.eclipse.org...
>>I think I know what your problem might be.
>>Did you put a semi colon at the end of the query.
>>If I remember correctly then sql plus expects a semi colon at the end.
>>If you pasted it directly then that might be the problem.
>>Remove the semi colon.
>>Roshan
>>Thierry Lach wrote:
>>>Further information. I can open the "Edit Data Set" window and take the
>>>query sql there and run it directly in Oracle's SQL*Plus tool, so the
> sql
>>>itself appears to be fine.
>>>"Thierry Lach" <thierry.lach@bbdodetroit.com> wrote in message
>>>news:d0l35b$7ba$1@www.eclipse.org...
>>>>It's a join. Non-join queries work fine (as you indicate). I'm using
> the
>>>>ojdbc14.jar that was bundled with the recent M1 release of BIRT (in the
>>>>engine jar).
>>>>news:d0l1p7$j3$1@www.eclipse.org...
>>>>>I can connect to oracle 9.0.1 using the thin driver and it seems to
> work
>>>>>without any issues.
>>>>>Try checking your query.
>>>>>The query I used was a simple one "select * from ITEMS".
>>>>>I used the thin driver in classes12.zip from
> http://www.oracle.com/technology/software/tech/java/sqlj_jdb c/htdocs/jdbc901.html
>>>>>Maybe it fails with a different version of the database.
>>>>>It could also be a driver issue.
>>>>>I am not sure.
>>>>>Can you try the thin driver if you are not using it?
>>>>>If it fails only for specific queries then can you provide an example.
>>>>>Roshan
>>>>>Thierry Lach wrote:
>>>>>>OK that worked (sort of).
>>>>>>It works fine for MYSQL. But under Oracle I get
>>>>>>Error Code:DATA_EXCEPTION_odaconsumer.CannotGetResultSetMetaData
>>>>>> Error Message:Cannot get the result set metadata.
>>>>>> A JDBC Exception occured: ORA-00933: SQL command not properly ended
>>>>>>I'm fairly confident that this is because oracle is not completely
>>>>supported
>>>>>>yet, and I'd be willing to try to deal with that. But I'm not
>>>familiar
>>>>>>enough with the code to know where to start looking. Any suggestions?
>>>>>>news:d0il4h$lpt$1@www.eclipse.org...
>>>>>>>Hi Thierry,
>>>>>>>The oda-config.xml file refers to the oda-jdbc.jar file.
>>>>>>>This jar file needs to be built before you run the application.
>>>>>>>You can build this by just running the build.xml under the
>>>>>>>org.eclipse.birt.report.data.oda.jdbc project.
>>>>>>>Alternatively you can run the viewer's build.xml file.
>>>>>>>This will build the jars for all the required projects and copy them
>>>>>>>over to the viewer as well so that you can run the preview.
>>>>>>>The full build instructions are at
>>>>>>> http://eclipse.org/birt/index.php?page=build/build_instr.htm l
>>>>>>>Roshan
>>>ojdbc14.jar
>>>>>>to
>>>>and
>>>>>>anything
>>>>>>>>with the data set.
>>>>>>>>Error
>>>>>>>>Any ideas?
Re: Error when running current BIRT from CVS [message #17518 is a reply to message #16709] |
Thu, 10 March 2005 10:05  |
OK, one of the more recent changes must have fixed it. It runs now.
Just for reference:
SELECT "GENWEBREG11_QA"."ATTENDEE"."FIRST_NAME",
"GENWEBREG11_QA"."ATTENDEE"."LAST_NAME",
"GENWEBREG11_QA"."ATTENDEE"."MID_INITIAL",
"GENWEBREG11_QA"."ATTENDEE"."AGE",
"GENWEBREG11_QA"."REGISTRATION"."INVITATION_CD",
"GENWEBREG11_QA"."REGISTRATION"."REGISTRATION_ID"
FROM ("GENWEBREG11_QA"."REGISTRATION" INNER JOIN "GENWEBREG11_QA"."ATTENDEE"
ON "GENWEBREG11_QA"."REGISTRATION"."REGISTRATION_ID" =
"GENWEBREG11_QA"."ATTENDEE"."REGISTRATION_ID" )
news:d0ntef$6h2$1@www.eclipse.org...
> Roshan
> >>Roshan
the
> > sql
> > the
the
> >>>>engine jar).
> > work
> >>>>>without any issues.
> >>>>>I am not sure.
example.
> >>>>>Roshan
> >>>>supported
> >>>familiar
suggestions?
> >>>>>>>Hi Thierry,
them
> >>>>>>>Roshan
> >>>ojdbc14.jar
> >>>>>>to
source
> >>>>and
do
> >>>>>>anything
> >>>>>>>>with the data set.
> >>>>>>>>Error
> >>>>>>>>Any ideas?
Current Time: Sun Jul 27 00:29:20 EDT 2025
Powered by FUDForum. Page generated in 0.04049 seconds
