Home » Archived » BIRT » Error when running current BIRT from CVS
Error when running current BIRT from CVS [message #15282] Mon, 07 March 2005 16:30 Go to next message
I've got the current BIRT checked out from CVS. I've added ojdbc14.jar to
org.eclipse.birt.report.data.oda.jdbc, and added jodbc14.jar to
odaconfig.xml in the same project. I'm able to create a data source and
start on a dataset, but I get the following error when trying to do anything
with the data set.
org.eclipse.birt.data.engine.core.DataException occurred
Error Code:DATA_EXCEPTION_odaconsumer.OdaInitEntryNotFound
Error Message:org.eclipse.birt.report.data.oda.jdbc.JDBCConnection Factory
cannot be found or cannot be instantiated.
Unable to create the ODA driver's connection factory.
org.eclipse.birt.report.data.oda.jdbc.JDBCConnectionFactory
Any ideas?
Re: Error when running current BIRT from CVS [message #15315 is a reply to message #15282] Mon, 07 March 2005 17:26 Go to previous messageGo to next message
Hi Thierry,
The oda-config.xml file refers to the oda-jdbc.jar file.
This jar file needs to be built before you run the application.
You can build this by just running the build.xml under the
org.eclipse.birt.report.data.oda.jdbc project.
Alternatively you can run the viewer's build.xml file.
This will build the jars for all the required projects and copy them
over to the viewer as well so that you can run the preview.
The full build instructions are at
http://eclipse.org/birt/index.php?page=build/build_instr.htm l
Roshan
> with the data set.
> Any ideas?
Re: Error when running current BIRT from CVS [message #16465 is a reply to message #15315] Tue, 08 March 2005 09:59 Go to previous messageGo to next message
OK that worked (sort of).
It works fine for MYSQL. But under Oracle I get
Error Code:DATA_EXCEPTION_odaconsumer.CannotGetResultSetMetaData
Error Message:Cannot get the result set metadata.
A JDBC Exception occured: ORA-00933: SQL command not properly ended
I'm fairly confident that this is because oracle is not completely supported
yet, and I'd be willing to try to deal with that. But I'm not familiar
enough with the code to know where to start looking. Any suggestions?
"Roshan" <rail@actuate.com> wrote in message
news:d0il4h$lpt$1@www.eclipse.org...
> Hi Thierry,
> Roshan
to
anything
> > with the data set.
> > Error
> > Any ideas?
Re: Error when running current BIRT from CVS [message #16519 is a reply to message #16465] Tue, 08 March 2005 15:15 Go to previous messageGo to next message
I can connect to oracle 9.0.1 using the thin driver and it seems to work
without any issues.
Try checking your query.
The query I used was a simple one "select * from ITEMS".
I used the thin driver in classes12.zip from
http://www.oracle.com/technology/software/tech/java/sqlj_jdb c/htdocs/jdbc901.html
Maybe it fails with a different version of the database.
It could also be a driver issue.
I am not sure.
Can you try the thin driver if you are not using it?
If it fails only for specific queries then can you provide an example.
Roshan
>>Hi Thierry,
>>Roshan
> to
> anything
>>>with the data set.
>>> Error
>>>Any ideas?
Re: Error when running current BIRT from CVS [message #16537 is a reply to message #16519] Tue, 08 March 2005 15:49 Go to previous messageGo to next message
It's a join. Non-join queries work fine (as you indicate). I'm using the
ojdbc14.jar that was bundled with the recent M1 release of BIRT (in the
engine jar).
news:d0l1p7$j3$1@www.eclipse.org...
> without any issues.
> I am not sure.
> Roshan
supported
> >>Hi Thierry,
> >>Roshan
> > to
and
> > anything
> >>>with the data set.
> >>> Error
> >>>Any ideas?
Re: Error when running current BIRT from CVS [message #16553 is a reply to message #16537] Tue, 08 March 2005 16:21 Go to previous messageGo to next message
Further information. I can open the "Edit Data Set" window and take the
query sql there and run it directly in Oracle's SQL*Plus tool, so the sql
itself appears to be fine.
"Thierry Lach" <thierry.lach@bbdodetroit.com> wrote in message
news:d0l35b$7ba$1@www.eclipse.org...
> engine jar).
> > without any issues.
> > I am not sure.
> > Roshan
> supported
familiar
> > >>Hi Thierry,
> > >>Roshan
ojdbc14.jar
> > > to
> and
> > > anything
> > >>>with the data set.
> > >>> Error
> > >>>Any ideas?
Re: Error when running current BIRT from CVS [message #16568 is a reply to message #16553] Tue, 08 March 2005 17:17 Go to previous messageGo to next message
I think I know what your problem might be.
Did you put a semi colon at the end of the query.
If I remember correctly then sql plus expects a semi colon at the end.
If you pasted it directly then that might be the problem.
Remove the semi colon.
Roshan
>>engine jar).
>>>without any issues.
>>>I am not sure.
>>>Roshan
>>supported
> familiar
>>>>>Hi Thierry,
>>>>>Roshan
> ojdbc14.jar
>>>>to
>>and
>>>>anything
>>>>>>with the data set.
>>>>>> Error
>>>>>>Any ideas?
Re: Error when running current BIRT from CVS [message #16694 is a reply to message #16568] Wed, 09 March 2005 17:05 Go to previous messageGo to next message
I'm not having the problem with SQL*Plus. It runs there just fine. The
query is failing when run inside of BIRT.
news:d0l8v7$3b2$1@www.eclipse.org...
> Roshan
sql
the
> >>engine jar).
work
> >>>without any issues.
> >>>I am not sure.
> >>>Roshan
> >>supported
> > familiar
> >>>>>Hi Thierry,
> >>>>>Roshan
> > ojdbc14.jar
> >>>>to
> >>and
> >>>>anything
> >>>>>>with the data set.
> >>>>>> Error
> >>>>>>Any ideas?
Re: Error when running current BIRT from CVS [message #16709 is a reply to message #16694] Wed, 09 March 2005 17:19 Go to previous messageGo to next message
Do you have any special characters in names?
Can you provide your query which fails?
I have the following and it works.
SELECT "DEMO"."DEPARTMENT"."DEPARTMENT_ID",
"DEMO"."DEPARTMENT"."NAME",
"DEMO"."DEPARTMENT"."LOCATION_ID",
"DEMO"."EMPLOYEE"."EMPLOYEE_ID",
"DEMO"."EMPLOYEE"."LAST_NAME",
"DEMO"."EMPLOYEE"."FIRST_NAME",
"DEMO"."EMPLOYEE"."MIDDLE_INITIAL",
"DEMO"."EMPLOYEE"."JOB_ID",
"DEMO"."EMPLOYEE"."MANAGER_ID",
"DEMO"."EMPLOYEE"."HIRE_DATE",
"DEMO"."EMPLOYEE"."SALARY",
"DEMO"."EMPLOYEE"."COMMISSION"
FROM ("DEMO"."DEPARTMENT" INNER JOIN "DEMO"."EMPLOYEE" ON
"DEMO"."DEPARTMENT"."DEPARTMENT_ID" = "DEMO"."EMPLOYEE"."DEPARTMENT_ID" )
Also file a bugzilla entry with the query so that somebody can look at
it to see whether it is a bug.
Roshan
>>Roshan
> sql
> the
>>>>engine jar).
> work
>>>>>without any issues.
>>>>>I am not sure.
>>>>>Roshan
>>>>supported
>>>familiar
>>>>>>>Hi Thierry,
>>>>>>>Roshan
>>>ojdbc14.jar
>>>>>>to
>>>>and
>>>>>>anything
>>>>>>>>with the data set.
>>>>>>>>Error
>>>>>>>>Any ideas?
Re: Error when running current BIRT from CVS [message #17518 is a reply to message #16709] Thu, 10 March 2005 10:05 Go to previous message
OK, one of the more recent changes must have fixed it. It runs now.
Just for reference:
SELECT "GENWEBREG11_QA"."ATTENDEE"."FIRST_NAME",
"GENWEBREG11_QA"."ATTENDEE"."LAST_NAME",
"GENWEBREG11_QA"."ATTENDEE"."MID_INITIAL",
"GENWEBREG11_QA"."ATTENDEE"."AGE",
"GENWEBREG11_QA"."REGISTRATION"."INVITATION_CD",
"GENWEBREG11_QA"."REGISTRATION"."REGISTRATION_ID"
FROM ("GENWEBREG11_QA"."REGISTRATION" INNER JOIN "GENWEBREG11_QA"."ATTENDEE"
ON "GENWEBREG11_QA"."REGISTRATION"."REGISTRATION_ID" =
"GENWEBREG11_QA"."ATTENDEE"."REGISTRATION_ID" )
news:d0ntef$6h2$1@www.eclipse.org...
> Roshan
> >>Roshan
the
> > sql
> > the
the
> >>>>engine jar).
> > work
> >>>>>without any issues.
> >>>>>I am not sure.
example.
> >>>>>Roshan
> >>>>supported
> >>>familiar
suggestions?
> >>>>>>>Hi Thierry,
them
> >>>>>>>Roshan
> >>>ojdbc14.jar
> >>>>>>to
source
> >>>>and
do
> >>>>>>anything
> >>>>>>>>with the data set.
> >>>>>>>>Error
> >>>>>>>>Any ideas?
Previous Topic:Nigel, Paul re: download
Next Topic:RCP Application and report viewer
Current Time: Sun Jul 27 00:31:36 EDT 2025
Powered by FUDForum. Page generated in 0.06284 seconds
