| RCP and GEF: Cannot open editor [message #162321] |
Mon, 20 December 2004 19:11  |
I'm trying to learn both RCP and GEF. Peter Mayne posted a nice GEF
plugin some time ago to the GEF newsgroup and now I'm trying to create a
RCP application of it.
He defined that files ending ".smeg" open the GEF editor. However, I'd
like to open the editor within the postWindowOpen method of the
WorkbenchAdvisor class and I don't want a persisted model. I'd like to
provide the model when starting the application.
Here's the postWindowOpen method of the WorchbenchAdvisor class:
public void postWindowOpen(IWorkbenchWindowConfigurer configurer) {
super.postWindowOpen(configurer);
SmegEditorInput input = new SmegEditorInput();
input.setModelRoot(new SmegDiagramModel());
String editorId = "com.spherion.ap.smeg.editors.SmegEditor";
IWorkbenchPage page = configurer.getWindow().getActivePage();
try {
page.openEditor(input, editorId, true);
} catch (PartInitException e) {
e.printStackTrace();
But I always get a PartInitException (Unable to open editor, unknown
editor ID: com.spherion.ap.smeg.editors.SmegEditor) as can be seen at
the end of this posting.
The editor should be known, though:
plugin.xml:
<extension
point="org.eclipse.ui.editors">
<editor
class="com.spherion.ap.smeg.editors.SmegEditor"
default="true"
name="Smeg Editor"
id="com.spherion.ap.smeg.editors.SmegEditor"/>
</extension>
I'd be very happy if someone could enlighten me on what I'm doing wrong.
I've been trying to get this running for more than 2 days now and cannot
find a solution.
Thanks in advance for any hint on what I'm missing.
Christian
Output when running the RCP app:
Invalid Menu Extension (Path is invalid): org.eclipse.update.ui.updateMenu
org.eclipse.update.ui.configManager
Invalid Menu Extension (Path is invalid): org.eclipse.update.ui.newUpdates
org.eclipse.ui.actions.showKeyAssistHandler
Plugin com.spherion.ap.smeg, extension org.eclipse.ui.editors
Required attribute 'icon' not defined
org.eclipse.ui.PartInitException: Unable to open editor, unknown editor
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:630)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2207)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2139)
at org.eclipse.ui.internal.WorkbenchPage.access$5(WorkbenchPage .java:2131)
at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.ja va:2117)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2112)
com.spherion.ap.smeg.SmegWorkbenchAdvisor.postWindowOpen(Sme gWorkbenchAdvisor.java:36)
at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow .java:586)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:587)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1170)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:178)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:665)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:886)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1516)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:285)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at com.spherion.ap.smeg.SmegApplication.run(SmegApplication.jav a:18)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:220)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:710)
at org.eclipse.core.launcher.Main.main(Main.java:694)
| Eclipse Executable Jar File not working [message #164479 is a reply to message #162321] |
Tue, 18 January 2005 15:53  |
Originally posted by: sfrierdich.custom-mfg-eng.com
HI
I creates an executable jar file for my application. When I click on the
file I get the same error everytime that the main could not be found.
The main class is pointed when created the jar file. Anyone have any
suggestions
Steve
FUDForum. Page generated in 0.04113 seconds
