Home » Archived » XML Schema Definition (XSD) » NullPointerEx at EMFPlugin when using xsd library in a TomCat JSP page
NullPointerEx at EMFPlugin when using xsd library in a TomCat JSP page [message #15261] Tue, 25 March 2003 13:52 Go to next message
I am having problems running some XSD schema generation code in a JSP
environment. In a test (standalone/Java application)environment, the
schema is created without problems. But when I call the class from a jsp
page the schema is not created beyond the minimum namespace declarations.
When this following snippet of code is encountered, it throws the
exception..
XSDElementDeclaration constraint =
xsdFactory.createXSDElementDeclaration();
constraint.setName("Constraint");
constraint.setTypeDefinition(schema.getSchemaForSchema).reso lveSimpleTypeDefinition( "string"));
The culprit is: schema.getSchemaForSchema()..
I have read that you would need to put xsd.resources.jar in the classpath.
But I do have that jar in the WEB-INF/classes directory under my
application. I have also attached the Stack Trace(logged in TomCat) below.
Would be great if someone could point out what might be wrong
kaunteya
STACK TRACE:
at org.eclipse.emf.common.EMFPlugin.getBaseURL(EMFPlugin.java:1 01)
org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaForSchema(XSDSch emaImpl.j
ava:630)
ava:2383)
com.sensima.swift.SchemaGenerator.createSchemaForMT1XX(Schem aGenerato
r.java:83)
com.sensima.swift.SwiftSchemaManager.getSchemaFromRawTextDat a(SwiftSc
hemaManager.java:74)
at org.apache.jsp.SwiftMain_jsp._jspService(SwiftMain_jsp.java: 129)
org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:137)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper
java:204)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:2
95)
Re: NullPointerEx at EMFPlugin when using xsd library in a TomCat JSP page [message #15294 is a reply to message #15261] Tue, 25 March 2003 15:26 Go to previous message
no worries. found the problem. Apparently it works if you dump it into the
lib directory of TomCat. thanks
kb
kaunteya wrote:
> Hello,
> exception..
> kaunteya
> STACK TRACE:
> java.lang.NullPointerException
> at
> ava:630)
> at
> ava:2383)
> at
> r.java:83)
> at
> at
> at
> java:204)
> at
> 95)
Re: NullPointerEx at EMFPlugin when using xsd library in a TomCat JSP page [message #566578 is a reply to message #15261] Tue, 25 March 2003 15:26 Go to previous message
kb
kaunteya wrote:
> Hello,
> exception..
> kaunteya
> STACK TRACE:
> at
> ava:630)
> at
> ava:2383)
> at
> r.java:83)
> at
> at
> at
> java:204)
> at
> 95)
Previous Topic:NullPointerEx at EMFPlugin when using xsd library in a TomCat JSP page
Next Topic:Retrieving the line number from XSDDiagnostic
Current Time: Sun Jul 27 00:32:34 EDT 2025
Powered by FUDForum. Page generated in 0.03727 seconds
