Home » Modeling » GMF (Graphical Modeling Framework) » GMF and XML
GMF and XML [message #162189] Fri, 23 November 2007 03:29 Go to next message
Originally posted by: hovabul.gmail.com
My ecore is:
Top --rel--> X
And my XML file is:
<rel/> when I click X in the diagram.
How can I use 'X' instead of 'rel'?
Hova Bul
Re: GMF and XML [message #162337 is a reply to message #162189] Fri, 23 November 2007 08:17 Go to previous messageGo to next message
--------------050204050301080601090501
Hova,
Call "rel" "X" instead. Using extended meta data annotations you could
specify that the XML name for "rel" is "X" without affecting the name
used in the generated APIs.
XML Schema to Ecore Mapping
< http://www.eclipse.org/modeling/emf/docs/overviews/XMLSchema ToEcoreMapping.pdf>
Hova Bul wrote:
> Hello,
> My ecore is:
> Top --rel--> X
> And my XML file is:
> Hova Bul
<html>
<head>
http-equiv="Content-Type">
</head>
Hova,<br>
<br>
Re: GMF and XML [message #162345 is a reply to message #162337] Fri, 23 November 2007 09:21 Go to previous messageGo to next message
So what I actually do? Bofore or After the created XML file should I do
something. And what? (Sorry I am beginner)
Hova
Re: GMF and XML [message #162384 is a reply to message #162345] Fri, 23 November 2007 11:44 Go to previous message
Originally posted by: ali.akar.geensys.com
hello,
you have to add annotation to your ecore metamodel
best,
Ali
Hova Bul a écrit :
> Hello,
> Hova
Previous Topic:Hide elements via setVisible doesn't work correctly
Next Topic:dynamic images reflecting node state
Current Time: Mon Jul 21 20:10:42 EDT 2025
Powered by FUDForum. Page generated in 0.04850 seconds
