Home » Archived » Java WorkFlow Tooling (JWT) » Wrap-up
Wrap-up [message #15239] |
Sat, 14 January 2006 16:38  |
Originally posted by: fabrice.dewasmes.openwide.fr
Hi all,
I think it's time to wrap up on recent discussions on this newsgroup and
consider pending actions.
Here are several threads and decisions (if any) :
*** Code contributions
First of all, I would like to thank Roman Zulauf and ObjectEngineering
GmBH and Allen Young and others from Shanghai JiaoTong University for
their initial code contributions. Please see
https://forge.openwide.fr/frs/?group_id=61 and check them.
I have also posted a first code contribution to show how JaWE can fit
into Eclipse views using SWT AWT bridge (please see notes about this
topic below). I'm in the process of packaging our intial work on GEF
based XPDL graphical editor. I hope to be able to publish this at the
beginning of the week.
*** EMF/GMF use
Well there have been lots of discussion around here to choose whether or
not to use EMF and eventually GMF.
* First my feelings about these are :
+ on EMF :
pros :
- EMF modeling is interesting.
- Using Omondo make things simple to create a EMF ecore diagram and
generate model.
- Code generation works fine and can end up with serialization in
desired format and especially XML. If model was created using an XML
schema, generated XML conforms to this XML Schema. Editors are created
automatically and help creating what EMF call Model instances meaning a
resource that conforms to the model definition (i.e for an XML schema
model this gives you an XML file valid against the XML schema)
cons
- Everything is cool when considering XPDL XML schema or BPEL
schema but this forces any new workflow/process grammar to be developped
this way which is not so easy for newcomers.
- Few people have sufficient EMF experience and none on this
newsgroup seems to have this kind of experience. Charlie is building a
frontend on EMF + GMF and is ready to share his experience on this but
it might be too late if JWT development have begun.
+ on GMF :
Well, I did everything I can with docs, tutorials and everything...
The tutorial was hard to get up and running (due to lack of GMF working
release) but when you finish the tutorial it's impressive. This is good
but I'm always scared of the demo effect (you know the kind of demo
where you push and button and just can say 'waow !'). So I've tried to
build a small XSD schema and see if I can build quickly a graphical
editor using GMF. This failed because the generated EMF model needed
some parametrization and I'm not an expert and when writing GMF map, you
just don't know what the different parameters are and it's like being
blind... So I tried from scratch and worked on the same model but
beginning directly with an EMF model (using Omondo EMF Class diagram
editor). Doing so means that even if you say that your model resource
type is XML you end up with XMI-like XML, meaning that you need to
completely handle the serialization your self if you want XML that is
valid against your schema. Moreover : this didn't help much in writing
the GMF map... :(
The conclusion for using GMF is that it is not mature enough. It has not
reached its first release yet and suffers from lack of documentation.
Adopting GMF would certainly cause us to jump into an ocean of
misunderstanding.
My feeling on using EMF/GMF is that there are chances that using these
frameworks may turn development into a nightmare of configuration tricks.
--> Seems that most of the people around here have expressed same kind
of feelings and for this reason I propose to stay on the only use of GEF.
*** Use of BPMN
Use of BPMN is of interest for two important reasons :
- First, it allows to have a common graphical representation for two
different grammar in one shot : BPEL and XPDL.
- second, as Allen reported in reply to Guennadi, BPMN proposes to fold
up Pool and lane which would be helpful for addressing large workflows
which don't fit into one screen.
Roman and Guennadi have exposed the requirement to be able to plug in
other representations and especially simplfied representation for
business users. As a matter of fact BPMN is for technical users and
might be not understandable by a business analyst.
--> I propose to had this as a requirement in the proposal and put BPMN
as an exemplary graphical representation.
Roman is already working on how to abstract things to allow several
representations to be plugged in. Roman, it would be really nice if we
can integrate an early snapshot of your work in the proposal or creation
review slides.
*** Use of a Swing bridge
Recent discussions have raised the possibility of reusing some existing
graphical editors or pieces of work relying on Swing. The proposed way
of reusing this work is to use SWT AWT bridge. I'm not in favor of doing
this because this will certainly be a cause of refusal.
--> What is the opinion of others ?
*** WAM
This topic has not been very much discussed. Michael Lipp has proposed
pointers to WfXML for workflow process deployment and OMG API for
accessing and controlling running workflow processes. We might consider
working on WAM in a second step, but I'd like to make people aware that
the STP project has been accepted and created those last days. STP
project is of great interest for JWT as JWT could be part of required
tools for the STP project and deployment and management facilities could
be done by implementing contracts defined by STP.
--> I will contact Carl from STP during the next days to see synergies
between projects.
*** Creation review
As I've said in previous posts, I think we're ready to ask for creation
review. As you might know this is a very important step in the project
lifecycle as failing to creation review will prevent it to go any
further. We have to hardly work on creation review slides and update the
proposal.
--> If everyone is OK I'm going to ask next week for creation review to
Eclipse PMC.
*** Proposal
Pending modifications on the proposal are :
- give pointers to the initial code contributions
- put Allen Young and people from Shanghai JiaoTong University in the
proposed committer list
- Add Guennadi to interested participants
- rectify typo in ObjectEngineering GmbH
- Add BPMN
- Add requirements to plug several representations especially for
business oriented users
--> Anyone willing to make modifications to the proposal is welcome.
Waiting for your comments/reactions
Fabrice Dewasmes
catching up the train [message #15311 is a reply to message #15239] |
Sat, 14 January 2006 18:12   |
Originally posted by: vgv8.yahoo.com.br
Hi all,
How can I help? (I am interested only in designer and possibility to compact
workflow graphical representation, add definitions of workflow nodes to
sidebar, attach editable data structures to workflow nodes at run-time
through pop-up datagrid table and save it according to my XSD in one fused
XML definition of workflow)
I think I lag behind all others (I currently review JaWE docs, Swing-AWT
bridge, my own Swing designer, GMF, GEF, GMT, XSD, etc.)
I also would like to see designer both as plug-in and STAND-ALONE.
Thereafter the design somewhat defensive to Eclipse UI reuse.
Here is, ahead of us, BPEL Designer with dead discussion forum and somewhat
proprietory activity. Let me note that it is from that type of designers
where user do not have control of coordinates of workflow nodes (it is
managed by Layout Manager) and this is the sequence of BPEL, i.e its
context/objectives (orchestration of webservices, and this is very NARROW
and proprietory). And BPEL-Designer project treats already BPEL but I am
interested in non-webservices oriented workflow definitions with human
interactions on server-side and possibilities to control/redefine formats
and on client side.
I also posted that XPDL (there is always lost in trnslation from graphical
notation to XML representation) is the most flexible and complete and BPEL
is really not first priority.
Pluggability of various representation is.
The issue of Swing is not so much and not only of code reuse but also
interoperability. At least, IMHO the design should leave holes for this.
In another post, I mentioned that it is difficult to count with Omondo
EclipseUML Free Ed.
Then I could not understand how someone will fuse dynamically added data
associated eith workflow nodes into XML/XMI model as well as how to specidy
the model in XML (in text editor?). You go from XMI to EMF ECore in order to
produce Java representation model. Anyway, the problem is how to cotrol EMF
ECore model representation in custom XML
GEF with EMF is good for creation of a number of similar pure graphical
editors (m.b. for more than 6) but we are to create one. But EMF or GMF
doesn't give any PLUGGABILITY of various workflow models (other than
recompiling or upgrading the designer). It is conceptual issue and has
nothing to do with experience or stability of frameworks and tools.
Correct me,
Guennadi Vanine
Re: catching up the train [message #15410 is a reply to message #15311] |
Sun, 15 January 2006 02:13   |
"Guennadi Vanine" <vgv8@yahoo.com.br> wrote:
>Hi all,
this would mean eventually being able to use the designer in Eclipse
RCP. In my opinion there is no other way to do it.
>and on client side.
Right but where and how ?
>EclipseUML Free Ed.
I noticed your remark and knew about this issue. But I was not saying to
that we should use Omondo. I used it as a convenient way to build the
model.
If you read the EMF redbook they point to how you can customize the XML
serialization and augment it with your own custom tags. If think the EMF
way of doing this is to use a JET template for the doSave command.>
This is both issues indeed. But maybe that I was not clear enough on
this part :
"- Everything is cool when considering XPDL XML schema or BPEL
this way which is not so easy for newcomers."
This is the same exact thing you're telling. Meeting of the minds ;)
>Correct me,
>Guennadi Vanine
Fabrice
experience vs. common sense in EMF [message #15443 is a reply to message #15410] |
Sun, 15 January 2006 09:38   |
------=_NextPart_000_002F_01C619E1.57950DC0
Content-Type: text/plain;
charset="iso-8859-1"
"Fabrice Dewasmes" wrote:..
> If you read the EMF redbook they point to how you can customize the =
XML
> serialization and augment it with your own custom tags. If think the =
EMF
This is where I really started to hate EMF.
It is very creative in producing time-consuming problems.
As I understood I should have produced initial XMI, Java =
representations,
block code generation and start manually hacking to attach run-time=20
(i.e. behavioral, i.e. those that u cannot add through static models)
artifacts, probably in Swing (somehow desactivating model generation and =
JET
templates)
Have you noticed that you cannot insert anything manually, it is=20
just replaced according to JET templates?=20
BTW, if you use EclipseUML, it cannot be swithed off:
http://www.forum-omondo.com/viewtopic.php?t=3D566&highli ght=3Dturn
"It is not and will never be possible to turn off the live code and =
model=20
synchro between the UML model and the Java code, inside the EclipseUML =
for=20
Java build and between UML model and XMI inside the EclipseUML for MDA=20
build. "
Now, when I tried to disable EclipseUML for Redbook sample,
I got error (*)
My purpose in EMF was not to get me more work with EMF but to the =
contrary.
Just common sense=20
I also have read the following answers from the autor of RedBook Anna =
Gaber=20
(at those times when authors still responded, try this now):
http://dev.eclipse.org/newslists/news.eclipse.tools.gef/msg0 6004.html
"There is no wizard to generate this code. You could use JET to generate =
some of the code from your model (as hinted in Chapter 5 of the book).=20
However, unless you are working with very large models, or intend to=20
generate a lot of very similar editors from different models, it is =
probably=20
less effort to write the code by hand than to set up the templates that =
such=20
an approach would require."
http://dev.eclipse.org/newslists/news.eclipse.tools.gef/msg0 6003.html
"> Also: is it recommended to use the methods generated by EMF.Edit in
II wouldn't use them. It takes less time to learn what you need to do =
and=20
do
it. For a graphical editpart, you are talking about a handful of =
methods.
They are:
mandatory
1) createFigure
2) refreshVisuals
3) activate(), extend to hook model
4) deactivate(), extend to unhook model
optional
5) getModel***(), depending on your part's structural features"
http://www.forum-omondo.com/viewtopic.php?t=3D772&highli ght=3Dcvs
"Omondo EclipseUML Free Ed will never offer CVS support"
I also can give links to some outraged cries on EMF breaking other =
plug-ins
Guennadi Vanine
error (*):
"cvc-elt.1: Cannot find the declaration of element 'merge:options'.=20
emf-merge.xml WorkflowModel/templates line 6 27 de Novembro de 2005=20
14:38:31"
pointing to the last line of
\WorkflowModel\templates\emf-merge.xml=20
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.2802" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>"Fabrice Dewasmes" wrote:</FONT><FONT =
face=3DArial=20
size=3D2>..<BR>> If you read the EMF redbook they point to how you =
can=20
customize the XML<BR>> serialization and augment it with your own =
custom=20
tags. If think the EMF<BR>> way of doing this is to use a JET =
template for=20
the doSave command.><BR><BR>This is where I really started to hate =
EMF.<BR>It=20
is very creative in producing time-consuming problems.<BR><BR>As I =
understood I=20
should have produced initial XMI, Java representations,<BR>block code =
generation=20
and start manually hacking to attach run-time </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>(i.e. behavioral, i.e. those that u =
cannot add=20
through static models)<BR>artifacts, probably in Swing (somehow =
desactivating=20
model generation and JET<BR>templates)<BR>Have you noticed that you =
cannot=20
insert anything manually, it is <BR>just replaced according=20
to JET templates? </FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>BTW, if you use EclipseUML, it cannot =
be swithed=20
off:<BR></FONT><A=20
href=3D"http://www.forum-omondo.com/viewtopic.php?t=3D566&highlight=3D=
turn"><FONT=20
face=3DArial=20
size=3D2>http://www.forum-omondo.com/viewtopic.php?t=3D566&highlight=3D=
turn</FONT></A><BR><FONT=20
face=3DArial size=3D2>"It is not and will never be possible to turn off =
the live=20
code and model <BR>synchro between the UML model and the Java code, =
inside the=20
EclipseUML for <BR>Java build and between UML model and XMI inside the=20
EclipseUML for MDA <BR>build. "<BR><BR>Now, when I tried to disable =
EclipseUML=20
for Redbook sample,<BR>I got error (*)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>My purpose in EMF was not to get =
me more=20
work with EMF but to the contrary.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Just common sense </DIV>
<DIV><BR>I also have read the following answers from the autor of =
RedBook Anna=20
Gaber <BR>(at those times when authors still responded, try this=20
now):<BR></FONT><A=20
href=3D" http://dev.eclipse.org/newslists/news.eclipse.tools.gef/msg0 6004.=
html"><FONT=20
face=3DArial=20
size=3D2> http://dev.eclipse.org/newslists/news.eclipse.tools.gef/msg0 6004=
..html</FONT></A><BR><FONT=20
face=3DArial size=3D2>"There is no wizard to generate this code. You =
could use JET=20
to generate <BR>some of the code from your model (as hinted in Chapter 5 =
of the=20
book). <BR>However, unless you are working with very large models, or =
intend to=20
<BR>generate a lot of very similar editors from different models, it is =
probably=20
<BR>less effort to write the code by hand than to set up the templates =
that such=20
<BR>an approach would require."<BR><BR></FONT><A=20
href=3D" http://dev.eclipse.org/newslists/news.eclipse.tools.gef/msg0 6003.=
html"><FONT=20
face=3DArial=20
size=3D2> http://dev.eclipse.org/newslists/news.eclipse.tools.gef/msg0 6003=
face=3DArial size=3D2>"> Also: is it recommended to use the methods =
generated by=20
EMF.Edit in<BR><BR>II wouldn't use them. It takes less time to =
learn what=20
you need to do and <BR>do<BR>it. For a graphical editpart, you are =
talking=20
about a handful of methods.<BR>They are:<BR>mandatory<BR>1) =
createFigure<BR>2)=20
refreshVisuals<BR>3) activate(), extend to hook model<BR>4) =
deactivate(), extend=20
to unhook model<BR>optional<BR>5) getModel***(), depending on your =
part's=20
structural features"<BR><BR></FONT><A=20
href=3D"http://www.forum-omondo.com/viewtopic.php?t=3D772&highlight=3D=
cvs"><FONT=20
face=3DArial=20
size=3D2>http://www.forum-omondo.com/viewtopic.php?t=3D772&highlight=3D=
cvs</FONT></A><BR><FONT=20
face=3DArial size=3D2>"Omondo EclipseUML Free Ed will never offer CVS=20
support"<BR><BR>I also can give links to some outraged cries on EMF =
breaking other plug-ins<BR><BR>Guennadi Vanine<BR>error =
(*):<BR>"cvc-elt.1:=20
Cannot find the declaration of element 'merge:options'. =
<BR>emf-merge.xml=20
WorkflowModel/templates line 6 27 de Novembro de 2005 =
<BR>14:38:31"<BR>pointing=20
to the last line of<BR>\WorkflowModel\templates\emf-merge.xml=20
<BR><BR></DIV></FONT></BODY></HTML>
------=_NextPart_000_002F_01C619E1.57950DC0--
Re: Wrap-up [message #15509 is a reply to message #15239] |
Mon, 16 January 2006 03:01   |
Originally posted by: rzulauf.objeng.ch
Hi Farbrice
I agree with you completely
> *** Use of BPMN
Good idea.
> review slides.
What exactly do you need at this point? While I have done some work I
would need to assemble my results to provide you with what you need. I
assume this is within the timeframe of the next few days?
I feel that we should do it right from the start. While the SWT AWT
bridge has its correct place in the eclipse platform, I think it is the
wrong thing to base on for a project to become part of the eclipse
technology platform. I would rather favor rewriting the graphical editor
from scratch while reusing key concepts and design patterns used in
existing editors.
> *** WAM
WfXML and the OMG API are two possible APIs to use. But again I suggest
to provide a generic interface which can be implemented by a plugin. So
there could be a plugin for the WfXML (SOAP/ASAP) interface, a plugin
for the OMG API, a plugin for the jBPM API etc. etc.
I am definetely interested in the definition of these interfaces.
> between projects.
> *** Creation review
> proposal.
> Eclipse PMC.
> *** Proposal
> - Add BPMN
This seems ok to me.
> Best regards,
> Fabrice Dewasmes
Hope my feedback helps. Thanks again for your hard work on this.
Roman
Re: Wrap-up [message #15603 is a reply to message #15509] |
Mon, 16 January 2006 04:42   |
Roman Zulauf wrote:
> Hi Farbrice
>> *** Use of BPMN
>> fold up Pool and lane which would be helpful for addressing large
>> workflows which don't fit into one screen.
>> BPMN as an exemplary graphical representation.
> Good idea.
>> creation review slides.
We don't need detailed conception yet but a general idea of how we plan
to do things. The correct input should be a simple diagram illsutrating
the different building blocks and how they collaborate.
>> existing graphical editors or pieces of work relying on Swing. The
>> proposed way of reusing this work is to use SWT AWT bridge. I'm not in
>> favor of doing this because this will certainly be a cause of refusal.
> existing editors.
This is also my opinion.
>> *** WAM
>> consider working on WAM in a second step, but I'd like to make people
>> aware that the STP project has been accepted and created those last
>> days. STP project is of great interest for JWT as JWT could be part of
>> required tools for the STP project and deployment and management
>> facilities could be done by implementing contracts defined by STP.
This is a good idea as we need to be able to provide extension points. I
propose to modify the proposal this way.
>> between projects.
>> *** Creation review
>> creation review. As you might know this is a very important step in
>> the project lifecycle as failing to creation review will prevent it to
>> go any further. We have to hardly work on creation review slides and
>> update the proposal.
>> to Eclipse PMC.
>> *** Proposal
>> - Add BPMN
>> Best regards,
>> Fabrice Dewasmes
> Regards
> Roman
Fabrice
Re: experience vs. common sense in EMF [message #15635 is a reply to message #15443] |
Mon, 16 January 2006 04:50   |
> As I understood I should have produced initial XMI, Java representations,
> artifacts, probably in Swing (somehow desactivating model generation and JET
> templates)
MMmh I understood that you can specifiy non overwritable sections using JET.
> http://www.forum-omondo.com/viewtopic.php?t=566&highligh t=turn
> < http://www.forum-omondo.com/viewtopic.php?t=566&highligh t=turn>
> "It is not and will never be possible to turn off the live code and model
> synchro between the UML model and the Java code, inside the EclipseUML for
> build. "
> I got error (*)
I didn't know about this issue. Anyway this is one more point against
use of EMF.
> My purpose in EMF was not to get me more work with EMF but to the contrary.
> Just common sense
> I also have read the following answers from the autor of RedBook Anna Gaber
> probably
> such
Ah! This is interesting. I'll keep this information.
> II wouldn't use them. It takes less time to learn what you need to do and
> do
> it. For a graphical editpart, you are talking about a handful of methods.
> They are:
> mandatory
> 1) createFigure
> 2) refreshVisuals
> optional
> http://www.forum-omondo.com/viewtopic.php?t=772&highligh t=cvs
> < http://www.forum-omondo.com/viewtopic.php?t=772&highligh t=cvs>
> I also can give links to some outraged cries on EMF breaking other plug-ins
OK this might interesting if we have justify the choice of not using EMF.
Thanks for this work.
Fabrice
> Guennadi Vanine
> error (*):
> 14:38:31"
Swing vs. SWT - no way to bypass this problem [message #17645 is a reply to message #17589] |
Tue, 17 January 2006 10:33   |
Hi, all,
I badly need opinion of the others on SWT AWT bridge problem.
IMHO it is "go/no go" decision.
I feel that:
- SWT is not mature (in comparison with Swing where there are plethora of
widgets, libraries, books, samples, etc. and that is around for decade), I
even do not know how to reproduce in SWT features of my existing Wf Dwsigner
in Swing that I should substitute;
- I feel bad about compatibility with Java world outside of Eclipse
including my own project (I have Wf Designer in Swing)
- if to decide on clean eclipse vision, do we have resources (programmers,
qualifications and TIME to wait for completing other eclipse projects on
which such decision depends on? In my project - no!)
- the architecture, coding in SWT is horrible, it resembles me MFC that MS
is desperately abandoning last years
- Yes, JFace/SWT seems cleaner it is because it doesn't permit to
differentiate between UI elements (models) and data models.
"One interesting idea in jface.databinding is that UI elements and data
models are treated the same"
http://michaelscharf.blogspot.com/2006/01/new-jfacedatabindi ng-needs-users.html
It hardly started and it is already of no use to me
Here are some links (between others) that I read tonight:
http://www.eclipsezone.com/eclipse/forums/m91978575.html
Anybody venturing into the world of the SWT-AWT bridge needs to be aware:
1. The linux version is buggy, and
2. The Mac version does not work at all.
To be sure, people are working on these things, but it is slow going.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=47716
https://bugs.eclipse.org/bugs/show_bug.cgi?id=67384
https://bugs.eclipse.org/bugs/show_bug.cgi?id=104570
Data binding framework for SWT and RCP needed
http://swingwt.sourceforge.net/
(Swing/AWT API on top of SWT, org.eclipse.swt.awt.SWT_AWT class)
http://chrriis.brainlex.com/projects/swtswing/
(SWT API on top of Swing)
Guennadi Vanine
"Guennadi Vanine" <vgv8@yahoo.com.br> wrote in message
news:dqhvcj$odo$1@utils.eclipse.org...
> "Roman Zulauf" wrote in message
>> existing editors.
> Should it be understood that SWT/JFace is right and Swing/AWT is wrong?
> and I am really very-very eager to understand why
> Have you seen this bug report
> If SWT AWT bridge is wrong then only because Eclipse as underlying
> platform is not good.
> The most curious is that I have seen dozens of articles describing as
> ready (with code snippets) something that should appear only in 1-3 years
> and in quite stealthy way
> Or click on this trick
> http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-ui-home/databinding-proposal/databinding.html
> hmm, redirected. You will never find this Eclipse.org project under
> eclipse.org site.
> Cunny
> I also have looked for all posts on databinding in EEclipse - they are
> never answered
> All these MVCs with GEF, EMF, GMF, SWT/JFace doesn't come out from
> manipulation of purely graphic data (as model) aka shapes.
> Guennai Vanine
Re: Vista/WinFX support? [message #19706 is a reply to message #19661] |
Fri, 27 January 2006 03:53   |
>>I feel that we should do it right from the start. While the SWT AWT bridge
>>has its correct place in the eclipse platform, I think it is the wrong
>>thing to base on for a project to become part of the eclipse technology
>>platform. I would rather favor rewriting the graphical editor from scratch
>>while reusing key concepts and design patterns used in existing editors.
> But what is right?
> GEF is not based specifically on any model at all!
That is correct, it just leverages the MVC pattern and leaves the
definition of the concrete model up to you.
I'm not saying other, existing graphical editors are wrong, all I am
saying is that we are trying to build an *eclipse* workflow editor and
in the context of the eclipse platform the right thing to do is use SWT.
> SWT is based on Win32 API/MFC that is discontinued for coming MS Windows,
> starting from Vista/Avalon that are shifted to WinFX/XAML/XAML/.NET, etc.
Personally I am not interested in political discussions about which GUI
Toolkit or API is the best. And if SWT uses Win32 or WinFX or something
else behind the scenes is of little importance to us. That's what an
Interface or a Wrapper is for, to hide the implementation details.
All we need to ask ourselves is, can we get the job done with GEF and
SWT? The answer is yes, so that is the obvious choice considering we are
building an editor for the eclipse platform.
> BTW there both SWT_AWT anf AWT_SWT bridge
Correct.
> It is just dangerous approach to be hooked to native implementations. It
> defeats "Write once, debug everywhere"
Realize that SWT has many stakeholders. The entire eclipse platform
depends on SWT, so as long as eclipse has industry backup, SWT will be
supported and maintained. I do not see any risk here.
Regards Roman
will we cope with that? [message #19778 is a reply to message #19706] |
Fri, 27 January 2006 11:44   |
Hi, Roman,
recently I have been discussing with Allen on messenger (he is currently out
up to 05Febr, 2006 to vacation due to Chinese New Year)
And our worry was that it would be laborious to reproduce in SWT and GEF all
functionalities offered by EMF or GMF frameworks.
This depends on our resources (programmers and time available)
Anyway, our progress rate (and resources) seem to be much less than that of
GMF project and the latter exhibits great improvements. While we made
wrap-up in the past based on the situation in the past while it could have
been more correct to synchronize our start in the future with GMF state in
the future.
Then, the logic is that if Eclipse is targeted as platform then it is
logical to base on its frameworks. And GEF with SWT doesn't add much to
non-Eclipse Swing/AWT. Don't we target non-Eclipse arquitectures, solutions
by targeting GEF/SWT only?
Allen thought that we should have from the very start all-embracing
meta-model.
I expressed my concern that we should wrap up current practical necessities
to designer functionalities from interested parties and do not target for
immediate realization all possible (in the future) usage scenarios.
That is, to device extensibility, interoperability in the future.
For ex., BPMN, as graphical notation, with close to it XPDL, as its textual
representation, is more then all-embracing for me (I even do not need XPDL's
participants and processes, in my case it is configured at server-side).
BPEL, BPML, etrc. may be seen as truncated versions, subset of XPDL.
We could have one unique graphical notation BPMN and closely corresponding
to it XPDL representation and give possibility to translate to BPEL, BPML,
etc. (really I am interested in non-standard format) angle of view reflected
graphically again by the same (subset of) BPMN.
Though I still have difficulties to grasp how to customize GMF, EMF.
I am just worried whether it was correct to target too ambitious/noble
plans. If we do not reuse legacy code themn we should rely more on
high-level framework reutilization and should adapt it to our capabilites
(resources).
Guennadi Vanine
"Roman Zulauf" <rzulauf@objeng.ch> wrote in message
news:drcn3m$q7i$1@utils.eclipse.org...
>>>existing editors.
>> But what is right?
> saying is that we are trying to build an *eclipse* workflow editor and in
>> Windows,
> All we need to ask ourselves is, can we get the job done with GEF and SWT?
> Correct.
> Regards Roman
Re: will we cope with that? [message #19819 is a reply to message #19778] |
Mon, 30 January 2006 08:17   |
Yes. I'll post something about this today or tomorrow.
> the future.
Glad you're OK with this now ;)
Non-eclipse platforms are not targeted and of course using GEF/SWT will
stick us to Eclipse platforms or at least SWT platform.
> meta-model.
Yes This is a discussion we also had. The point is how to simply write
the meta model without any high level tools such as EclipseUML ?
Of course. We definitely need to have an iterative roadmap. I'm going to
work on it for creation review. Your point is grist to my mill and will
include this in the roadmap
> (resources).
Yes this is also a concern to me. Experience says that doing too generic
things end up with a bloatware. As expressed earlier we should stick
with concrete 'simple' implementations at first and keep in mind targets.
no errors/warning in code generation [message #19960 is a reply to message #19863] |
Tue, 31 January 2006 12:11  |
And vote for this one!
https://bugs.eclipse.org/bugs/show_bug.cgi?id=104727
[Plan Item] Improve code generation error reporting and handling
Guennadi Vanine
news:dro2vp$5qf$1@utils.eclipse.org...
>I bumped into many problems with EMF.
> Then I encountered their description in bugzilla.
> They are even not considered as bugs but as duplication of
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=75933
> And what is the last bug? Absence of the concept of well-defineIt is EMF
> architecture to be decided in the future while other framework should base
> their own architectures on it.
> This is fundamental issue without which u should not even start framework
> instead this bug has the lowest priority "enhancement" (it is lower than
> "trivial") And any usability problems are marked as duplication of it
> Another but dependent on firs is GMF "bug":
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=114233
> [req] Provide alternative persistence mechanism
> It is even not targeted by GMF1.0 Release!
> and again is has just an "enhancement" priority
> (am I crazy? first to make framework and then design/architecture it)
> IMHO the main problem in development using Eclipse frameworks is that u r
> forced not only to do yr application but also hack the tool, IDE, and
> frameworks for this.
> These issues are quite critical for their use or plans to use. In JWT also
> Everybody, go to vote for this bugs!
> Salvation of all is the matter of everybody!
> Guennadi Vanine
Current Time: Sun Jul 27 00:31:01 EDT 2025
Powered by FUDForum. Page generated in 0.06955 seconds
