Home » Eclipse Projects » GEF » Visualize connections when Source and Target(EditParts) are the same.
Visualize connections when Source and Target(EditParts) are the same. [message #162065] Sat, 18 December 2004 08:23 Go to next message
Originally posted by: alimail.onlinehome.de
Hello everybody,
I want to visualize a state diagram with gef. When nodes are states and
connections are (state-)transitions there is exists also
"self"-Transitions, a connection where source a target node is the same.
My standard visualization (polyLine with Arrow-Decoration) paints
only an arrow at the bottom of the node-figure. But i want to visualize
it like this:
node<--
my hope is that someone has already coded somethign similar like this
above... Any suggestions?
Alex
Re: Visualize connections when Source and Target(EditParts) are the same. [message #162133 is a reply to message #162065] Mon, 20 December 2004 00:17 Go to previous messageGo to next message
You could add some bendpoints to the connection when you create it. The
EDiagram example in the repository does this. It's not a very elegant
solution though, because then when you move the node, the bendpoints stay at
their original location.
"alitari" <alimail@onlinehome.de> wrote in message
news:cq1b4s$5m5$1@www.eclipse.org...
> Hello everybody,
> My standard visualization (polyLine with Arrow-Decoration) paints only an
> arrow at the bottom of the node-figure. But i want to visualize it like
> this:
> node<--
> Alex
Re: Visualize connections when Source and Target(EditParts) are the same. [message #162572 is a reply to message #162065] Wed, 22 December 2004 10:42 Go to previous messageGo to next message
You need to identify this special case in your connection router, and create
the loopback points.
> Hello everybody,
> it like this:
> node<--
> Alex
Re: Visualize connections when Source and Target(EditParts) are the same. [message #1063881 is a reply to message #162572] Fri, 14 June 2013 13:08 Go to previous message
Hello every one!
it's 4 years and I'm fined in the same problem, also I want create this node as polyline, that needn't 2 others nodes to connect, just one (the containment) please did you solve this case, i want know how you did it
Previous Topic:Draw2D 3.9 with Eclipse 4.2.1 has incorrect rendering output
Next Topic:Layouting a large number of draw2d widgets in a Canvas
Current Time: Sun Jun 29 05:19:02 EDT 2025
Powered by FUDForum. Page generated in 0.03112 seconds
