Home » Archived » BIRT » JNDI Datasource ???
JNDI Datasource ??? [message #161894] Wed, 17 May 2006 10:39 Go to next message
Originally posted by: Torsten.MuellerX.web.de
is there a way to use JNDI Datasources inside reports?
Thanks in advance.
Re: JNDI Datasource ??? [message #163343 is a reply to message #161894] Mon, 22 May 2006 06:30 Go to previous messageGo to next message
Originally posted by: l.forni.inwind.it
There is a work in progress:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=131662
"Torsten M
Re: JNDI Datasource ??? [message #170397 is a reply to message #163343] Wed, 14 June 2006 17:23 Go to previous messageGo to next message
The JNDI data source feature is now added in the BIRT oda.jdbc driver,
as of 2.1 RC5. It supports the use of a JNDI Name Service to look up a
Data Source resource factory to get a pooled JDBC connection.
Please see more feature description in the Bugzilla entry 131662.
Linda
> "Torsten Müller" <Torsten.MuellerX@web.de> ha scritto nel messaggio
> news:39cb69c0218f98fc3bc8218bd2c5c4bf$1@www.eclipse.org...
> > Hello,
> > Thanks in advance.
Re: JNDI Datasource ??? [message #170803 is a reply to message #170397] Thu, 15 June 2006 17:31 Go to previous messageGo to next message
Originally posted by: blev.whocares.com
Is it possible to override the data source embedded within the rptdesign
by passing an external JDBC java.sql.Connection object via API? If yes,
please let me know how using a code snippet.
Thanks.
- Brian
Re: JNDI Datasource ??? [message #171176 is a reply to message #170803] Fri, 16 June 2006 18:03 Go to previous message
See the link for an earlier posting "Re: Pooled connection object in BIRT"
that should address your question.
news://news.eclipse.org/dph13u%24ijn%241%40utils.eclipse.org
> Thanks.
> - Brian
Previous Topic:BIRT charts interaktive?
Next Topic:performance issue
Current Time: Sat Jul 26 06:03:42 EDT 2025
Powered by FUDForum. Page generated in 0.04860 seconds
