Home » Archived » EPF » Import Export Method Plugin
Import Export Method Plugin [message #15210] Fri, 23 June 2006 17:07
I'm having import export problems with EPF. I already opened a BUG
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=145422) and Bing Xu told me
that:
"We had made changes to the export and
import in the newer M3 build, and there is a limitation that old library
(or
more precisely library created by older versions of EPF) may not be able to
import plugins or configurations from a newer version."
I need to correct my library made with the first public version of EPF,
because merging libraries seems too complicated and import/export works
well for introducing new content packages.
Someone can help me?
Previous Topic:Publishing a Configuration in a script?
Next Topic:Import Export Method Plugin
Current Time: Sun Jul 27 00:31:19 EDT 2025
Powered by FUDForum. Page generated in 0.02224 seconds
