Home » Archived » DSDP - Real-Time Software Components (RTSC) » ModA changing ModB's module parameters
ModA changing ModB's module parameters [message #1248] Fri, 20 February 2009 10:20 Go to next message
I have a question about one module changing another modules config
parameter. More explicitly, when it changes a front-end module that then
pushes its config parameter to a delegate. Are there any rules for this?
Let’s take a look at an example
ModA uses ModB. ModA increments one of ModB’s module wide config
parameter (e.g. maxRuntimeEntries)
ModB is the front end for different implementations (e.g. Bios impl.,
Linux impl, etc.). Let’s call the delegate ModBDelegate.
I have ModB pushing its module config parameter to ModBDelegate in its
module$use.
ModB.Proxy.delegate$.maxRuntimeEntries = ModB.maxRuntimeEntries; // proxy
is ModBDelegate
The maxRuntimeEntries can be changed (e.g. set, incremented, decremented)
in the app’s cfg file and that works fine. How can ModA change the
setting? There is no order guarantee, so it cannot do it in it’s
module$use (since ModB could have already pushed the setting to
ModBDelegate).
Should ModA be restricted to setting the module config parameter in
module$meta$init (or instance$meta$init)? Or should ModB change the way it
is pushing the parameter to the delegate? Or should the delegate pull it
from the front-end when it needs it (e.g. in ModBDelegate’s
module$static$init)?
Todd
Re: ModA changing ModB's module parameters [message #1296 is a reply to message #1248] Fri, 20 February 2009 16:23 Go to previous message
i could be wrong, but if ModA truly *uses* ModB (and this static
relationship is captured in package requires statments), then we can
ensure that ModA's module$use will run be ModB's module$use....
> then pushes its config parameter to a delegate. Are there any rules for
> this?
> Let�s take a look at an example
> ModA uses ModB. ModA increments one of ModB�s module wide config
> Linux impl, etc.). Let�s call the delegate ModBDelegate.
> module$use.
> proxy is ModBDelegate
> decremented) in the app�s cfg file and that works fine. How can ModA
> change the setting? There is no order guarantee, so it cannot do it in
> it�s module$use (since ModB could have already pushed the setting to
> ModBDelegate).
> it is pushing the parameter to the delegate? Or should the delegate pull
> it from the front-end when it needs it (e.g. in ModBDelegate�s
> Todd
Previous Topic:Changing library suffix
Next Topic:correct way to set profile for executable
Current Time: Sat Jul 12 22:33:20 EDT 2025
Powered by FUDForum. Page generated in 0.03010 seconds
