Home » Archived » BIRT » pdf rendering
pdf rendering [message #161734] Wed, 17 May 2006 04:34 Go to next message
Originally posted by: vinee1983.yahoo.com
Hi!
I am not getting the pdf output in BIRT 2.0.1. What needs to be done to
render BIRT to display the pdf? Coz IE is not displaying the report and
firefox says file doesnot contain %PDF- when i set format=pdf
Re: pdf rendering [message #161968 is a reply to message #161734] Wed, 17 May 2006 12:01 Go to previous messageGo to next message
Originally posted by: ejf7.hotmail.com
Do you have the itext plugin in the correct folder?
It needs to be in place in order for the pdf rendering to work.
Re: pdf rendering [message #162211 is a reply to message #161968] Thu, 18 May 2006 04:38 Go to previous messageGo to next message
yes i have the itext jar at the rt place . Do i need to write some java
code to enable BIRT pdf output.
Re: pdf rendering [message #162442 is a reply to message #162211] Thu, 18 May 2006 10:42 Go to previous messageGo to next message
Does it generate a PDF from Eclipse when you preview as a PDF?
Re: pdf rendering [message #162747 is a reply to message #162442] Fri, 19 May 2006 00:54 Go to previous messageGo to next message
No it says error happened while running the report when i preview it as pdf
Re: pdf rendering [message #162767 is a reply to message #162747] Fri, 19 May 2006 02:45 Go to previous messageGo to next message
Originally posted by: sangria.gmx.net
How big is your itext.jar file? It happended to me two times that I downloaded the
file and it was only 19kb big instead of 1.09mb
michael
Re: pdf rendering [message #162808 is a reply to message #162767] Fri, 19 May 2006 05:04 Go to previous messageGo to next message
The size of the file is fine....
Re: pdf rendering [message #163071 is a reply to message #162808] Fri, 19 May 2006 13:39 Go to previous message
If the itext file is definately in the correct place, you probably have
errors in your report.
Does the report compile when you preview as an html? If it does when you
use the preview tab at the bottom of the report, and there are no errors
at the bottom of the preview, I can't think of anything other than the
itext plugin being in the wrong place that would cause the problem. Maybe
you need to re-install Eclipse.
Previous Topic:Report Engine on 2.1RC
Next Topic:Excel Export as PDF and HTML
Current Time: Thu May 08 19:36:01 EDT 2025
Powered by FUDForum. Page generated in 0.04714 seconds
