Sequenze of Calls To External Tools [message #161590] |
Wed, 19 July 2006 11:59 |
Originally posted by: Reza.somewhere.com
we're trying to develop WSRF Stuff. Therefore we need to use and run
external scripts through Eclipse by using "External tools". In most cases
we have to first stop the container, build the project, deploy it and then
start the container. Which results in a sequenz of 4 clicks. So we would
like to have one button that actually clicks in the given order the 4
other buttons/starts theses task from inside of eclipse. Since we have a
complicated path and environment that is easy to maintain and use inside
of eclipse, but difficult in the normal environment, we would like to know
how you solved this problem? Is there a cool plugin which can do that?
any help would be greatly apprechiated.
With many thanks in advance,
Reza
FUDForum. Page generated in 0.07204 seconds
