Home » Eclipse Projects » GEF » Selection and Delete actions don't work in FormEditor
Selection and Delete actions don't work in FormEditor [message #161518] |
Wed, 15 December 2004 02:29  |
Originally posted by: notavalidaddress.notavaliddomain.com
I created a GraphicalEditorWithFlyoutPalette, that uses the
Delete action, and the standard alignment, and match action,
which all extend SelectionAction.
All of this worked fine, but now I have created a FormEditor
in which I add a FormPage, and then the GraphicalEditor.
Since I did this, the action aren't enabled when I select my
edit parts.
Has anybody seen this before?
Thanks.
Re: Selection and Delete actions don't work in FormEditor [message #161542 is a reply to message #161518] |
Wed, 15 December 2004 03:56   |
I found a temporary solution, just added this to my GraphicalEditor :
public void selectionChanged(IWorkbenchPart part, ISelection selection) {
updateActions(getSelectionActions());
The only problem is that the actions need to be updated when I switch to
another page.
"John Doe" <notavalidaddress@notavaliddomain.com> wrote in message
news:cpop52$jrh$1@www.eclipse.org...
> edit parts.
> Thanks.
Re: Selection and Delete actions don't work in FormEditor [message #161596 is a reply to message #161542] |
Wed, 15 December 2004 10:19   |
The selection should change when you change pages. Both pages are probably
selection providers?
news:cpou7p$2vp$1@www.eclipse.org...
> another page.
> > Hi,
> > edit parts.
> > Thanks.
Re: Selection and Delete actions don't work in FormEditor [message #162329 is a reply to message #161596] |
Tue, 21 December 2004 00:49  |
Originally posted by: zhanglq.primeton.com
Yes! I Got the same problem!
And i have done updateActions(getSelectionActions()); in GraphicalEditor
selectionChanged,nothing better.
So,anybody help me!
thanks!!!
>>Hi,
>>another page.
>>>Hi,
>>>edit parts.
>>>Thanks.
Current Time: Sat Sep 06 09:51:11 EDT 2025
Powered by FUDForum. Page generated in 0.07568 seconds
