Home » Modeling » GMF (Graphical Modeling Framework) » GMF Problem -> Once one node added, none other can be
GMF Problem -> Once one node added, none other can be [message #161511] Mon, 19 November 2007 14:22 Go to next message
Originally posted by: s0452900.sms.ed.ac.uk
Hello there,
I am currently in the middle of my university Thesis project, which
involves using GMF to create a graphical representation of a system
(described in the PEPA modelling language) which allows user
interactions to view all different possible states of the system.
I have been working on the project since the end of September and only
learned about GMF and my need to use it at the same time. Although I
have gotten somewhere, I am having a slight problem which I cannot seem
to solve:
When I create my editor and attempt to add nodes to it, I am only able
to add the one node. This is locked to the top left-hand corner of the
screen. I am unable to move this node, add any connections or, as stated
previously, add any more nodes.
Looking at the number of posts in the newsgroup that I currently have as
unread (9351), I can imagine there is a post somewhere where this
problem has already been experienced and answered. My apologies for
"double-posting" if this is the case, but would greatly appreciate any
help that could be given to solve my problem :).
Thank you,
Paul McEwan
P.S. With the need for my editor to be read-only; generate automatically
the models to display; allow users to click on specific nodes to change
the state; calculate what the next state should be; edit the colour of
nodes depending on the current state and other lovely things, I can
imagine having to post at least a few more messages to this newsgroup :P.
Re: GMF Problem -> Once one node added, none other can be [message #161544 is a reply to message #161511] Mon, 19 November 2007 16:58 Go to previous messageGo to next message
Originally posted by: trommas.yahoo.com
This can be any number of problems.
The issue with only being able to create one node is usually because the
containment is not multiple. Ex: Library contains 0,1 books instead of
0,* books.
The issue with the node being unmovable can result from many things in
my experience. But usually it's a wrong configuration in the graph.
Hope this gives you any pointers.
I'm in the middle of a master thesis as well :)
Please post any further questions.
Best Regards,
Tomas Zijdemans
Paul McEwan wrote:
> Hello there,
> to solve:
> able to add the one node. This is locked to the top left-hand corner of
> the screen. I am unable to move this node, add any connections or, as
> stated previously, add any more nodes.
> Thank you,
> Paul McEwan
Re: GMF Problem -> Once one node added, none other can be [message #161589 is a reply to message #161544] Mon, 19 November 2007 17:56 Go to previous messageGo to next message
Thank you for the prompt response.
I was having a look at the problem of just one node. Opening the Ecore
model in text editor view I noticed the line:
<eStructuralFeatures xsi:type="ecore:EReference" name="processNodes"
upperBound="-1"
eType="#//ProcessNodeVis" containment="true" resolveProxies="false"/>
This is, if I have it right, describes the list of "process nodes" in my
"pepa model" class. I notice it said that the upper bound was "-1". Is
this correct for multiple instances? In the Ecore editor it does show
the "0..*" type icon for all the lists of nodes.
I'll have a look at the graph configuration to see about the unmovable
nodes.
Thank you
Paul
> 0,* books.
> Best Regards,
> Tomas Zijdemans
> Paul McEwan wrote:
>> Hello there,
>> seem to solve:
>> only able to add the one node. This is locked to the top left-hand
>> corner of the screen. I am unable to move this node, add any
>> connections or, as stated previously, add any more nodes.
>> as unread (9351), I can imagine there is a post somewhere where this
>> Thank you,
>> Paul McEwan
>> automatically the models to display; allow users to click on specific
>> nodes to change the state; calculate what the next state should be;
>> edit the colour of nodes depending on the current state and other
>> lovely things, I can imagine having to post at least a few more
Re: GMF Problem -> Once one node added, none other can be [message #161626 is a reply to message #161589] Tue, 20 November 2007 03:46 Go to previous messageGo to next message
Ok, the containment seems correct.
I am guessing that you in fact can create many nodes, but they all end
up in your top left corner (with 100% overlap).
This is probably either a graphical issue, or an issue with the model
element (the node). If you customize any methods, now would be a good
time to debug them.
HTH,
Tomas Zijdemans
> upperBound="-1"
> nodes.
> Thank you
> Paul
>> the containment is not multiple. Ex: Library contains 0,1 books
>> instead of 0,* books.
>> Best Regards,
>> Tomas Zijdemans
>> Paul McEwan wrote:
>>> Hello there,
>>> only learned about GMF and my need to use it at the same time.
>>> Although I have gotten somewhere, I am having a slight problem which
>>> I cannot seem to solve:
>>> any help that could be given to solve my problem :).
>>> Thank you,
>>> Paul McEwan
Re: GMF Problem -> Once one node added, none other can be [message #161630 is a reply to message #161626] Tue, 20 November 2007 04:00 Go to previous messageGo to next message
LOL, I just got the same problem :P
I got it because I:
1. Derived an editor.
2. Changed the name of a node in the ecore.
3. Tried to run the editor.
HTH,
Tomas Zijdemans
> time to debug them.
> HTH,
> Tomas Zijdemans
>> upperBound="-1"
>> my "pepa model" class. I notice it said that the upper bound was "-1".
>> Is this correct for multiple instances? In the Ecore editor it does
>> show the "0..*" type icon for all the lists of nodes.
>> nodes.
>> Thank you
>> Paul
>>> in my experience. But usually it's a wrong configuration in the graph.
>>> Best Regards,
>>> Tomas Zijdemans
>>> Paul McEwan wrote:
>>>> Hello there,
>>>> have as unread (9351), I can imagine there is a post somewhere where
>>>> this problem has already been experienced and answered. My apologies
>>>> for "double-posting" if this is the case, but would greatly
>>>> appreciate any help that could be given to solve my problem :).
>>>> Thank you,
>>>> Paul McEwan
>>>> specific nodes to change the state; calculate what the next state
>>>> should be; edit the colour of nodes depending on the current state
>>>> and other lovely things, I can imagine having to post at least a few
Re: GMF Problem -> Once one node added, none other can be [message #161836 is a reply to message #161630] Wed, 21 November 2007 08:47 Go to previous messageGo to next message
Thank you for the help so far. After reading the responses, I decided to
have a deeper look at my code, I think the way I am trying to describe
my model my be the problem:
- My PEPA model has ProcessNodes and ActionNodes, both of which extend a
Node class, that are connected via a Connection object.
- The PEPAModel class (the one describing the model) contains a list of
ProcessNodes, Rate, ActionNodes and NodeConnections
- A ProcessNode has a name and NodeState (current, next etc)
- A ActionNode has a Rate object as well as a name and NodeState
- A Connection has a getConnectionOriginNode() (which is a Node) and a
getConnectionTargetNode() (again a Node)
- In PEPAModel, I state that the NodeConnections list should be a
container ( since it should contain the process nodes and action nodes
of the model )
For the graphical part, I want the ProcessNodes and ActionNodes
represented by ellipses, while the connection objects represented by a
link ( the rate will not be illustrated ). When it comes to creating the
mapping, I get the screen presented in the attached picture. I remove
the Rate and Connection from "Nodes", rate from "Links", then create.
This part seems okay, but when I create the diagram code I get the
following classes with errors:
- ConnectionConnectionDestinationNodeEditPart
protected Connection createConnectionFigure() {
return new NodeConnectionFigureDescriptor();
- ConnectionConnectionOriginNodeEditPart
They both report "Type mismatch: cannot convert from
ConnectionConnection"x"NodeEditPart.NodeConnectionFigureDescriptor
to Connection". I have the return types cast to "Connection", which
seems to appease it.
I then run the Eclipse test application. Now, not only does the original
problem I have persist, but now I'm getting the "Invalid view - remove
from diagram" error for the selected node!
My apologies for such a long post, but I was wondering if the problem
could be how I define my connections:
1 - should I have the node objects themselves have a list of connections
or is a list in PEPAModel sufficient?
2 - is the name "Connection" used for some other object and that's
what's causing the problem?
3 - is there something else I'm missing?
Any help that would be given would be greatly appreciated.
Thank you
Paul
> I got it because I:
> HTH,
> Tomas Zijdemans
>> time to debug them.
>> HTH,
>> Tomas Zijdemans
>>> Ecore model in text editor view I noticed the line:
>>> upperBound="-1"
>>> "-1". Is this correct for multiple instances? In the Ecore editor it
>>> does show the "0..*" type icon for all the lists of nodes.
>>> unmovable nodes.
>>> Thank you
>>> Paul
>>>> Best Regards,
>>>> Tomas Zijdemans
>>>> Paul McEwan wrote:
>>>>> Hello there,
>>>>> which I cannot seem to solve:
>>>>> am only able to add the one node. This is locked to the top
>>>>> left-hand corner of the screen. I am unable to move this node, add
>>>>> any connections or, as stated previously, add any more nodes.
>>>>> where this problem has already been experienced and answered. My
>>>>> apologies for "double-posting" if this is the case, but would
>>>>> greatly appreciate any help that could be given to solve my problem
>>>>> Thank you,
>>>>> Paul McEwan
Re: GMF Problem -> Once one node added, none other can be [message #161848 is a reply to message #161836] Wed, 21 November 2007 08:51 Go to previous message
--------------050107010508080500070908
Sorry for the double post, forgot to attach picture
Paul
Content-Type: image/png;
name="Picture 1.png"
Content-Disposition: inline;
filename="Picture 1.png"
iVBORw0KGgoAAAANSUhEUgAAA/kAAAHPCAIAAACHm43CAAABSmlDQ1BJQ0Mg UHJvZmlsZQAA
eJyVj79LAnEYh5+vBEmBGR3R0HBTFBSd2qA1eSoSBJk16G3eeViI3nH37Ydr zY0NgUNL0NjQ
3NTYEPSDpiCov6Bwcmi44AgH6Zme98OHl/eFiJbN64VIHFpt6ZWLulqpGuro A1HGmSLFWs3y
3WyptAHQdto2A/ReEACPS9m8Xni7Ojl+PX/uffo3yeLqe3qw/4cxy/Uk0AeS ddu3QGhA81C6
EkQXUMymK0FcA4q3U86BuANijcCfgJgZ+AcQ8ypVA8Q3oDQqVQMiUUAxA58F FGkfSYCc43a8
vcauVJOapqnZumPa6nbHl3bLV9fbluO5jleTdh0I7gNgMiiWi7o6n8hk0gtD /vw3laqhBva1
hQDE9H2YhVj73sGvikhq+Bzu6M7A5iWM9MNs5RQuFmHiLMzmEhBfhtvuD2jb Wg5OFLZ9AAAg
AElEQVR4nOzde1xM6f8A8GdmarrRza2U7qVUkpIQFV3ECluRW6jdWGux1mWx XwpbfZHb5mtZ
a4mNpR/rUhTJl5LwdVkWkVslpdJtus7MeX5/PPZ85zvnzDTdYz/v79e+pjPn PM9zznnmeZ55
5nPO4WCMEQAAAAAAAKBroyjUKKIoicG7UISFIoq8JoN6/P4f+Q9S6tgSAgAA AAAAAJoHYyQU
YbHkMB+jBhFFUU1sCGN9AAAAAAAAui6RGIvE/xOLgzFuFGJKgegcLv3qwYMH HA6Hw+HMnDmT
Xujh4UEWVlVVtb6gqqqq3t7erU8HAAAAAACAjx6FUYMQCxkD/QahomH4LPP6 Z86caWxs5PP5
ZWVlGRkZbVRUhBCKj4/v1atXGyYIAAAAAADAR+n9dP7/LiSjf6Tw9bZcqb91 dXWrqqouXLiA
EEpKShKLxfTovK6u7vPPP+/Zs6eqquqQIUNu3ryJEFq6dOmoUaM2bdrUu3dv Ozu7M2fOIITO
nTvn6Oj4ww8/2NjY6OnprVixggQTxcbG/vbbb2Kx2NHR8R//+MfMmTO1tLRc XV2fP3+OEHr9
+rW3t7e2tva0adMWL17s5ubW8mMDAAAAAADAhwkj1CjEIrH0iJ7CqFHYVIT+ /5Ie6/v6+vL5
/MTERITQqVOn+vbt6+zsTN7auHHjvn37wsPDf/755z///HPp0qUIoRcvXly9 ejU+Pn7+/PkV
FRWffvppXl5eeXn53bt3V61aNWnSJFtb282bN8fFxSGE7t279+zZM4zx3bt3 Y2JiioqKBg0a
lJ2dHRUVhRAKCQm5dOnSnDlzxGJxXFzcH3/80aKDAwAAAAAAwIeKonCjkKIY MToYo0ZR8wb6
iBnDo6WlNXr06FOnTlVXV6ekpISEhLx69Yq8NW7cOGdn54kTJxYUFGhoaNDL EUKJiYnW1tZD
hw795JNPjh49amhoiBBasWLF2rVrGxoa9PX14+PjFy1aJJmRnp7exYsXa2pq NDU1Hz9+XFJS
cunSpeDg4O3btyOErK2tCwsLm7szAAAAAAAAfLhI3A5z+fuBfvNvlS89r48Q +vTTT8vLy9es
WVNTUzN58mR6uY6Ozi+//NKnTx8rK6uamhp6uZKSkrW1NULI0dERIfTixQuy 3N7eHiGkoqJi
Y2Pz8uVLqVwGDhyIENLQ0OjVq1ddXd2bN28QQubm5uRdS0vLZu8KAAAAAAAA HyaMUKNIxkCf
Qo0iRW66w4JlrO/v78/lcnft2qWtre3h4UEvnzt3bmZm5smTJysrK01NTTkc DlkuEonKy8sR
QqWlpQghbW1tsvzt27fkRWlpqZaWllQufD6fvCDp6OnpIYQePHiAEKIo6uHD hy3aHQAAAAAA
AD4wGKNGIWa/t06LQndoLGP9Pn36DB8+nKKo8ePHKysr08tfv36to6Pj5OR0 //79p0+fSt67
f+XKlffu3YuIiEAIeXl5kYXbt2+/efNmXFzckydPmrzVZu/evUeNGnXq1KlZ s2Z5e3tLBggB
AAAAAADwsRJTuFFEIbYAHYyQUNSyCf33WMb6CKFPP/0UISQZwIMQWrRo0cuX LzU0NEJCQiws
LN69eycSichb9fX1jo6OZ86cWbp06ZgxY8hCOzs7Dw+Pr776ytXVNTIyssmi HD9+PCws7MWL
F25ubn5+fjwerzU7BgAAAAAAQBcnK0CfEIoUvI2+TBxFb8SPEEKooqKitra2 b9++9JLJkyf/
/vvvQqGwurpaRUVFXV0dIZSQkDBjxoxff/01MDCwsrJSwXvqL1iwgMPh7Ny5 s7q62tra2sTE
5Pr1683dHwAAAAAAAD4IIjEWU0hyRl9yYP7Xu4gM1//6978v/nqX3lbqXfZ5 fVm0tbUlB/qS
dHR0yEBfEp/PV/zhWdbW1nv27DEwMDAwMMAYx8bGNqtsAAAAAAAAfBBIcI5Y dhy+mEJy3lVc
8+b1mfLy8qqrq21tbSUXVlZWFhQUGBoaMi/Jla+goODOnTt6enq2trbMbw4A AAAAAAB8BIQi
jP/79FvpeX2M/yd6pzXz+q0d6wMAAAAAAAAUhDESirHkcFxqrP/+etz/fhNo 5lgfIzGFxRSi
KExhxrO0AAAAAAAAAO0BYyQSS4zi2ci5VFdmsghRYjLEp0P8378FY30AAAAA AADaHRnoyx/I
iymkeMwNxlhMIbEYi6i/fgdgbAtjfQAAAAAAANqXIgN9ikKUIo/HxUhEYbEY iykyvpe3CYz1
AQAAAAAAaEeKDPQxRqKmBvpiCokpLBZj1il8VjDWBwAAAAAAoL28j9Fvikgs b/guEmORGFHN
v6cOjPUBAAAAAABoFwoO9KWeqCWxORaKsVjcdKyOLDDWBwAAAAAAoO0pEpZD VmOG6VMYC8WY
avXjtGCsDwAAAAAAQBsj97lXIKpe+um5GGOhCFFYkW2bxpX1Rl5eHofDWb9+ Pb1ELBb37dt3
woQJrcnvyZMnQ4cObU0KxNWrVydOnNj6dGSZPn36uXPnmMs3bNiwbds2+dvq 6Oi0T6FQRERE
O6UMAAAAAADaChnoKxJ0Q1H/fRgWhVGjCDeKcBs+61bmWB8hpKure+zYMfrP CxcucDictsq4
lYYMGbJnz57OLkVH27lzZ2cXAQAAAAAANEGs2FW0GGPqr4fdNoqwUKTY94Pm kDfW19LSsrGx
uXbtGvkzPj5+xowZ5HV2draDg4OZmVn//v2zs7MpinJyclq8eLGVlZWdnd3F ixelktq8ebO5
ubm5uTk9QC8sLPzkk08sLCwGDRp04cIFhFBMTMzGjRuHDx9ubGz8yy+/zJw5 08zMbOjQoaWl
pQih/fv3m5mZmZiYjBw5sqys7P79++vWrUMITZ48+Ycffhg0aJCBgcGJEyck M5Wf4J49ewYM
GGBpafnZZ5/V1tYihF68eOHp6WlsbDx69Oi3b9+SRPbt22dnZ2dra7tlyxbW o3T9+nUXF5f+
/fvPmTOnoaGBXi4UChcvXmxtbe3k5JSamkqKGhsbO2jQoP79+6ekpIwcObJf v35z5swhJ1Uq
o5iYmH/+85/Dhw/X19dftWoVQmjEiBGVlZWWlpb5+fm7d++2tLQ0NTWdMmVK fX19EycZAAAA
AAB0FLFiD77F7yf1kUhM5vLbpTDyxvoIoVmzZsXHxyOEqqqq7ty54+7uTpZ/ ++23UVFRz58/
X758+d69ezHGt2/ftra2fvLkSUJCwqxZsyoqKuhELl++fPDgwdu3bz99+pQe Q4eGho4ZMyY3
N/fw4cOzZs0qKSkpKytLT0+/fPlyUlJSaGjo1KlTnz9/bmZmdvr06bq6ulWr VmVlZb18+dLY
2Dg5Obm+vr6oqAghVFBQ8OrVq7t37/76669k9E+Tk2BWVlZsbOzly5dzcnIo ioqMjEQIzZ07
d+bMma9evdq2bVtmZiZC6MaNGwcOHLhx48atW7eSkpLS09Oljo9AIJg7d+5v v/2Wk5Ojp6cX
FRVFv7V9+3Yul/v48eOTJ0/Onz+/qqqqoKCgoqLi7t27X3311dSpUxMSEp49 e3b58uUXL14w
MyorK0tKSkpLS3v06NGePXtKS0szMzO1tLSePn1qaGi4YsWK7Ozs58+f6+jo ZGRktOjUAwAA
AACANqbgjD5CiKKwiMJCEdX6C3DlaGKs7+fnd+nSpYaGhuPHjwcEBNAxPJcu XerVq9ePP/54
6NChmpoahJCGhsa8efMQQgMHDnRxcaF/DUAIpaSkzJo1S0tLi8vlfv311wih hoaGjIyMxYsX
I4Ts7Ozc3d0vX76MEJo6dSqfz7e0tNTR0SEXBlhZWdXU1Kipqb18+fKPP/7Y smVLRkYGyZE2
Z84chNCIESPoLxI0WQkmJSXNnTu3d+/eXC53+fLlZ8+era+v/89//jN37lyE kIODg7e3N0Lo
zJkzWlpa27dv37Ztm5aW1unTp6XSz87ORggdOXIkKiqqoaFBcoXTp08LhcKo qKjDhw9369aN
fE+YNWsWQsjS0nL06NH9+vXj8/nGxsY1NTWsGU2ZMkVNTU1bW9va2rqkpIRO mcPheHl5+fv7
79y5c9myZV5eXvJPIgAAAAAA6AAKxugjhMQYNwgpcVMP2Gq9Jsb6ysrKY8eO PXPmTHx8PBmn
EmPHjv3ll1/09PRCQ0PJEiUlJS73fWqqqqqSgSUikUhVVZV+iyzh8XiS6zc2 NiKEeDweQojD
4fD5fMlivH37dvDgwTdv3hw4cKC/v79UIdXU1GSVX1aCDQ0NKioqkrmLxWJl ZWXJIiGEGhsb
dXR0+vbt27dv30mTJgUEBEil39jYqKGhQVZwcHBYvXq15Ft6enrkraVLl9ra 2sopD2tG9H4x
L5P4v//7v+jo6NLSUnd398OHD8vafQAAAAAA0DFIQE6T3gftNLb7KJ9oYqyP EAoJCYmOjm5o
aOjfvz9ZUl1dfe3atX/961+TJk0qKCgg318qKyvJjWvevXt39erVIUOG0CmM HDny+PHjQqEQ
IXT06FGEkIaGhoWFxdmzZxFCZWVlaWlpw4YNk1OG7Oxsc3Pz1atXe3l55eTk tD6gadSoUYmJ
iaRICQkJo0aN0tDQMDExIbtQUlKSlpZGVquqqgoJCZkzZ87z58+ZkfHOzs6V lZWTJ0+eM2dO
z549c3NzJbNQVVWdM2dOSEjIqVOntLS05JdHfkYEh8OhKKq6utrX13fYsGEb NmxYs2bNlStX
Wnk0AAAAAABAa2Cs0ENtKQoLRZSoBc+/bamm76/v7OxcV1dHz98jhLp37+7u 7u7k5KSpqenk
5JSenv7gwQNNTc1//etfMTExBQUF3333Xb9+/ej1J0yYkJqaOnDgwB49ehgY GJCF+/fvDwkJ
2bJlS0FBwbp168zMzOSUYejQoUuXLh09erRYLLa0tNy+ffu+fftausvvi3T5 8uWBAwfq6uoq
KyuTbyD79u2bOXNmTExMfX29lZUVQmj8+PEpKSkODg7a2tpGRkaRkZFZWVmS 6fTq1WvdunUu
Li76+vocDichIYF+a9WqVVOnTj158qRYLA4MDOzVq5ec8jAzSklJYa42fPhw a2vrS5cuDR48
2MHBoV+/fgUFBeSCCgAAAAAA0Cne30q/qXVE1Pvb7uD2DNCXwmnxHHlpaam2 traSklJ1dbW6
unqfPn1KS0tLS0t1dHRIpIqU+vp6iqLU1dUlF5aXl5M4/iazE4vF7969IyPm qqoqTU3NlhVb
klAorKurk0rq3bt3urq6kktIhI+cSCGMcXV1NWuRqqurNTQ0FNlBRTKSVFdX V1VV1bt3765z
I1QAAAAAgL8bjBDFFqaP3/9DCCExRR6YhRFGYoww+f/7/yH011OzSCr/XfLf 5eTPvzKReBdL
bCa1CdHysb4ksVhMxvqtTwoAAAAAAIAPBXk4LnM8TY/1RWL81zNwMcaIPCW3 w8b6TcfwKILH
45GbVAIAAAAAAPA3QckN3aEwFlNI8ntAu95ek1XbzOsDAAAAAADwt0Lhv6ba GfP6GCExPZ3/
fhVEYUyP9T+weX0AAAAAAAD+PjBGsmbMyaW6jDc7Z4IdxvoAAAAAAAA0A5mk Z32LwjIu1e2k
SBoY6wMAAAAAANAMWEaYvqzn5uLOG+srdC9IAAAAAAAAACJh+mzLZQ30UWeF 7yCEYF4fAAAA
AAAABWGMmCN9CiMKyx7od+ZQH+b1AQAAAAAAUABrKA5FyYzdf79Vp97zEsb6 AAAAAAAANO2D
G+gjiOEBAAAAAACgSczoHTHV9Fi+059kBfP6AAAAAAAAyIMZ1+NSFGKJ3Jfe qrNn9WFeHwAA
AAAAAPkkx+wYy7rlprytOgvM6wMAAAAAACCT5Ox8Mwb6XWGkD2N9AAAAAAAA ZJGM3sEYU4pv
2C7FaTYY6wMAAAAAANAE2TfQZ8dpr4I0D4z1AQAAAAAAYEGP7nGzRvq4qwTw IBjrAwAAAAAA
wETG67i5A30SvdNFZvVhrA8AAAAAAIAsXeG+ma0BY30AAAAAAAD+x/tJ/eYP 9LvaVwMY6wMA
AAAAAPBfZLje3ItxuyYY6wMAAAAAACDh/X02u0zQfSvAWB8AAAAAAID3MJnX b/6Uftf8ZgBj
fQAAAAAAAP7S0sCdrhnwA2N9AAAAAAAAEOp6V9a2Hoz1AQAAAAAAaJ2u+iWB U1pa2tllAAAA
AAAAALQ9pX379nV2GQAAAAAAAABtj1NRUdHZZQAAAAAAAAC0PYjXBwAAAAAA 4OOkJBKJOrsM
AAAAAAAAgLYH8/oAAAAAAAB8nJSUlJQ6uwwAAAAAAACAtgfz+gAAAAAAAHyc IF4fAAAAAACA
jxPM6wMAAAAAAPBxgnh9AAAAAAAAPk4wrw8AAAAAAMDHCeL1AQAAAAAA+Dix B/BgjDu4HACA
vzMOh9PZRQDyQKcAAAAfBGZ/yh6vD806AKAjwVi/i4NOAQAAPgjM/rRD4/Wz srLOnDnTkTkC
AADoaoqKin744YfOLgUAAPwtsMfrNzmF07dv3zVr1nz55ZfkT2dn57Nnz+rp 6cnf6ubNmzk5
OX5+fi0rKwDgYwXz+l2cIp3ClStXLCwsyJ9//PFHaGjorVu3WFcuLCz8+eef v/jiizYuJQAA
/O212bw+h8PZvHnz8+fPW10kAAAAHxs7O7vLly93dikAAAC0NF6fw+HMmjXr m2++OX36NPkC
oaSkpKSkdPny5dWrV9fW1hoZGe3cudPExAQhtGnTpkOHDunq6hoZGWlpaZEc N2/efPz4cRMT
k1WrVjk6OlIU9eWXXz5+/LiqqurSpUtaWlptv68AgK4K5vW7OEXi9Xk8Ht2h PH78eNmyZWfP
nkUIubm5rVq1atOmTQKBIDY21sPDg6ympKRUVFQUGhq6e/duY2Pj9PT0LVu2 lJeXT5w4ceXK
le26OwAA8LFqy3j977777tWrV/Hx8ZILFy1aFBsbe+fOndGjR0dHRyOEnj17 lpCQcPHixRMn
TnC577PLzc1NSkq6evXqsmXLIiMjEUIZGRl//vlnenr6rVu3NDU1W1wqAAAA na6xsbGgoIC8
zsvLO3jwYGJi4ldffSUZpl9TUzNt2rSFCxcaGxsjhDZv3rxgwYJr164tX768 cwoNAAAfoxbG
6yOEVFRUtm7dGhYWNmbMGISQSCS6ceMGj8cbMmSIWCwODAwcNmxYTU3N+fPn R4wY0aNHD4SQ
k5NTTk6OSCQ6efIkxnjt2rUURWVnZwsEAisrq7dv386dOzciIsLAwKDN9xMA 0JXBvH4Xp0in
IBaL6Q6FvCD/xRhHRUXp6OhYWloWFhaKRCKRSCQWi+fOnTt58mQfHx+ymoeH x9dff11VVRUU
FERRVHvuDQAAfLTa+D48Hh4e48aNo+dgampqVFRUyGs+ny8Wi4VCYV5eHnOe vqioqF+/fhMm
TJg4ceLx48e5XG7Pnj0zMjL69evn6en5559/tqZUAAAAuhRlZWX0vz0Qh8NR V1e/ceMGPaxf
unTprl27fvzxR/quDwAAAFqv5ffXJxtGR0cPHTq0pKRESUlp1KhR7969Kyws NDIySktLGz16
tLa2tqen5/fff9/Q0EBRVFpaWr9+/ZSUlLy8vBYvXrxr1y46Ll8gEPTo0WP9 +vUFBQV37951
cHBo2/0EAHRlMK/fxTU3Xp+OyEcIcTgc8haPx+NwOOTiLi6Xu3fv3ilTpqxc uXLbtm0Ioaqq
Km9vb2Nj44kTJ7J2TAAAAJrE8iytVqaora29efPm2bNnI4R4PF5kZKSnp6ep qWlJScmBAwcQ
Qu7u7mfOnBk8eHCvXr1GjBhRU1ODEPLz87t3797AgQMHDhxYUVFx5syZ9PT0 iIgIU1NTiqIC
AgJaWSoAAAAdLDAwkPy06+LiEh4e3uT6fD7/8OHDEyZMiIqKWr169eTJk3k8 HkVRa9asaf/C
AgDA3wWntLSUubQ1j0gUi8Xl5eU9e/aUXCgQCLp16ya1plAorKqqIqH8CCGK oqqrq+EOPAD8
DcG8fhfXMc/Nrays7NatG4/H64C8AADgo8TsT9t+rA8AAM0FY/0uDjoFAAD4 ILDE8LQ4Xh8A
ANoKjPW7OOgUAADgg9DseP3i4uJXr169e/eurq5OJBJJ/rSKMSbJMV/ACrAC rAArsK5AURSP
x1NXV9fR0TEyMtLT00PggwKdAqwAK8AKsEJXWEHx/lReDM/Dhw8LCwv5Kmpq 3TSRsirmKIlh
ZgcA0Ao8DuJgERLW1wmqGhvq+vbtO2DAAATz+l2eZKegqqravXt3Pp+vpKQE Jw4AADoFxlgk
EjU2NlZXV9fX18vpT2XO6z969KioqKiPXl+Vblr1WLlWrNRAcSgMzToAoOW4 HKzCxeoaIi0d
3QZBZXFxMUKINE+giyOdQt++fTU1NVVUVJSVlblcruS0E/k+QL9AEl0OrAAr wAqwAqzQ5itQ
FCUUChsbGysr5fWn7PH6xcXFFRUVxsbGat11aih+hQCX1YrrhBhmcAAArcNR VeL0UFfT76be
U0NdXU2lpKSkrKwMgnm6OLpT0NHRUVVVJTP6pONhdk6SvRTrclgBVoAVYAVY oZUrEBRFURSl
rq6uoiKzP2Wf1y8qKtLW1tbR0WnkqjbWoVqhqOh1PsIUV9zAuj4AACiC4qkg DlfNxLiB4nZX
VdHR0WlsbCwuLoaxfhdHdwrq6uokRj8hIaGzCwUAAH9306dP53A4ampqcvpT JZFIxNyypqZG
X1+fz+dX1lKVdVSdkOqjpRLuP7xDig0A+MCkpKSoqqqqqqpqaGioqqqqqamp qKjw+XxlZWUy
AczhcMRisVAoFAqFx68+qhNSVfVIQ4mroabcrVu3oqIi1oYIdB10p0BRFFli Y2Mzbty4zi0V
AAB8ZJrVn2ZlZYnFYoQQxlhZWWZ/ymXNicPh8Pl8DocjorCI4tQJMebAE8sB AG2AQrw6IRZR
HBGFuVwuaWo6u1CgCXSnQJ8sOGsAANB1yOlP2eP1yTcJPp+vpCTicMSS7TsA ALQG5y9KSjw+
X0ldXZ3Ef3d2uYA8dKdA9wXwdFsAAOhcPB6P7j0xxrL6U/Z5fR6Px+VyJWP/ AQCgPXC5XBg1
dn3QKQAAQBcnqz/lithQFCX+C/5LxxealpeX14m5t1h8fPydO3faNs3IyMjK ysq2TVNxH+iJ
AF0K3aTQjQxFUawNEeg66E6BXkKCRD9WGOPnz59XVFR0dkH+R3v0KfIVFhZu 2bJFwZVb00Eo
klFtbe3jx4+rqqpanEunyM/Pf/nyJX2hC2gr1dXVu3btCg8Pv3fvnoKbNDmC +uAGOVJtsqz+
lH1evzVUVFTMzMx69eo1ceLEp0+fylpN8e8PJSUl33//PULI19dXX1+/T58+ JiYm8fHxbVbi
pkRHRxsYGND149ChQ/PmzVNkw8TExAcPHrRtmrGxsW3b0jXri9zWrVs/uE8C 6Mpgnhi0B3pc
defOHXNz8+ZuHh8fb2pqunDhwjFjxowePTo/P5+5zrZt28LCwmSlID/frKws Ho+XnZ1N/szP
z+/fv78iBZPTpzRJRUVFcjBtbm7+5s2bJrcqKiravXu3Iulfu3bt2LFj7ZRR YWHhhAkTBg8e
vGLFioEDB3bYbbtaWZEOHjxobGw8d+7cWbNm6erq7ty5s60LyI4utvxa+oHS 0tIiH8ndu3ff
vn17/vz56urqHA6nsbGxyW2bHEGlpKQkJye3WVk7BN2NyulPuUpseDweiQHi 8Xh0cK3iGaem
pr5+/VpFRSU2NlbWOiYmJjk5OYqkFhwcvHjxYvJ6w4YNxcXF69atW716dUfO KhUVFS1fvrzr
p9kCip8IhNCyZcumTp36cc/ngfZGNyl0I8PlsjdEoOugOwXJJZ1dldjl5uYa GhqS1w4ODorP
+RH//ve/lyxZkp6enpyc/J///MfNzS0gIIDZiX755ZdxcXGyElEk37CwMEVG J22Fw+FERkbm
5ua2R+LFxcXffPPNwoUL2ymj4OBgfX39hw8fnj59+uXLlx3z40YrK1JaWtrC hQvPnz9/8eLF
q1evlpSUzJgxox2KKW3//v3Tp08nr+XX0tZ49OhReySriPz8fHJe0tPT/fz8 Bg8ebGlpWVFR
wefzFU/k6dOnrCOZ0NDQTZs2PXv2rM2K2854PB65Pw/dLLP2p20/r0/w+XwT ExOBQIAQKigo
GDdunJOT07Bhw27duoUQWrdu3Zs3bwICApYtW4YQSk5OtrOzGzFixNGjR6XS yc/PxxhLPQbM
wcHh9evXAoEgPDx8x44drq6u69atQwjFxsaam5ubm5uHhobW1tYihOrq6ubN m2doaGhra7t5
82aEUG5u7ogRIwYNGrR+/XqRSIQQunDhgru7u729/fr160n6W7dudXV1tbGx SU1NJUvmzp37
22+/paenSxWPmWNNTU1wcLCZmZmXlxc9mcHMVFaatbW1YWFhJE16auTp06eu rq4WFhaff/45
XTuZaV6+fHnKlClSJZQ8RC04EVIHx9DQ0NDQ8I8//mji9AMAwF/S0tIGDRpk ZmZmbW1dV1fH
2sqFh4f/9NNPfn5+hoaGW7duJQsdHBxOnTrl5ORkZWV18eJFspDZTEml/8UX X5SUlDg5OR05
cuTx48effPIJWe3ixYv29vbm5uZjxox5/vw5Qujhw4ceHh779+83Nzd3c3Mj k4WbN2/28fEx
NTWlC3bz5s3Lly+T8vzyyy9WVlapqamHDx+OiIgg60RERPTr18/JySk0NHTl ypUIITpf1iwQ
Qm5ubioqKlFRUVLHSsE+paamZvr06QMGDPjss8+KioqkEpk0aVJmZqbUQg6H ExYWFh4eLvW9
5fnz515eXubm5nZ2dnSXl5SUZG5ubmtrKznXvnHjRhsbm/Hjx5PuQ1Jqaqqf n5+qqmp7ZHTj
xo2rV68uWLCAy30/YtHX10cyukvWisS6sL0rUmxs7JgxY2xsbMhWysrKPXr0 kHUcmFVdVs1h
noUdO3aYmppaW1sHBgYWFhZGRkampqY6OTk9ffpUspYyq9b+/fuXLVu2aGom HuAAACAASURB
VNGivn37zpgxg5yvmJgYObO0CKErV654eXn99NNPCCGMsZmZWU1NDUIoPT19 6tSpskpOUdTs
2bOHDBliZWVFIhrCw8Pj4uJGjRplZmZGnxTmwObFixdjx441MjKytra+cuUK QmjkyJFFRUVb
tmzJzMxcuXKlk5OTk5OTo6OjUChkTYF1BHXz5k0XF5dDhw5Jjfh5PF5QUNDp 06flHIEPUimb
y5cvP3v2LC8vL+vBi//Ler7j/JMfT2djxfD5/AMHDqxfv97S0vL69esY48rK ypcvX2KMN23a
9Pnnn5PV9PX1Hz16hDGmKMrU1PT169fV1dX9+vVraGiQTC0hIeGzzz4jr318 fHbt2pWZmenj
4zNu3DiMsb+/v4ODw6tXr0hspbGxcX5+fk1NzeTJk/ft24cxPnDggIODQ15e HsZYKBRijKdN
m5aYmCgWi8eOHZuRkYExHjly5O+//06ihzHGtbW13bp1KykpwRiLRCKMcVRU VGRkZFxcnIWF
RW1tbXx8PGnFWHPcu3fvp59+WldX9/DhQxsbm/j4eNZMZaW5f/9+f39/gUBQ UFBgamqam5uL
MZ4+ffrmzZspikpNTeXz+WR3mGlWVFQ8fvxY6nRIHqIWnAipg4MxXrly5Q8/ /KBgZQB/E+fP
n798+fL169fv37//9OnTgoKCkpKSysrK2traxsZGoVAoEokaGhoEAkF5efmP p7N3nH/yf1nP
sx68yM/Pf/bs2eXLl1kbItB10J1C/l+Sk5MVrB4mJiZxcXEkrhTLaOX8/f3N zMzu3buXk5Oj
qalJ2h9NTc1x48YVFxfv2bPH19cXy2impNLPycnp06cPyfr27dtmZmbktbGx 8dWrVymKiomJ
mTlzJnlXWVl55cqVZOgcHR2NMTY1NSWNOW3AgAFxcXGkPCEhIZWVlRjjrVu3 hoaGYowfPnxo
ZGRUUFBQVlYWGBhIFtL5smZx7do1T0/Pu3fvqqurP3jwIC8vz8rKCjenT9mz Z8/ChQsxxlFR
URs3bpQ64I8ePaqqqpJaqKqqKhAITExM9u7dizE2MzMrLCzEGIeEhHz//fdi sfjatWtGRkYU
RWGMDQwMsrOzGxoaoqKiyI7k5OQ4OTnV19dfu3bNy8tLKvHw8PDDhw+3U0YH Dx7U19cn60tS
vCIxF3ZMRfrxxx8xA+txYFZ11jSZB+fFixdqamrZ2dn4r0HOnj17pk6dSvKi aylr1dq6dWu3
bt1+++232tpaU1PTrKwsjHFBQcHr16+ZxcYYZ2RkeHt7BwcHkzEDxpgEC5HK dvbsWTc3N1kl
T0tLc3R0JJuQXfb39ycBcjk5OXp6evfu3cNsA5s5c+aEhIRUV1fTO6ipqUlG QZ6enidOnMAY
19XVIYTISWSmwDqCwhiXlpZ+++23gwcPPnz4sOS1qefOnSM/5XWWZvWnycnJ +RJk9acy5/Vb
c5PNM2fO/Pzzz1999dXQoUMRQpqamj169EhLS/vzzz+ZgY9ZWVk1NTWbNm36 7rvvKIrKysqS
fPePP/4wMDCg/4yKitq9e3dYWBiJC0QIff3110ZGRgih48ePe3l5GRoaqqur BwUFkRWOHDky
Y8aMfv36IYSUlJQaGhrOnj2blpa2dOnSd+/ekW/Pvr6+8+bNO3z4MJkzUFNT c3V19fPzIyGV
dNYLFizQ09Nbu3YtvYQ1x+Tk5EmTJqmqqtrY2FhYWCCEWDOVk2ZQUJCGhoaB gYG3t/exY8co
ikpJSZk6dSqHw/H29lZRUZGVppaWFmvQJ32IWnAipA4OQsjAwKC5P2UCIAuG eP0PR8s6hevX
r5eXl4eHh9M3iGC2cmTNNWvWDBw40MrKqra2trq6miz84YcfevfubWtr+/r1 a8TWTDHTZ3Xj
xg0lJSU3NzcOhxMSEnL69OmGhgaEkJ6eXkxMjLq6+oABA0gWiFEtxWIxve/r 16/X1NSUfPfE
iRO+vr4GBga6urrDhg1jZs2aBULIwcFhyZIlYWFh9Myign0KQigxMTEvL2/J kiW3bt2S7FMI
a2vr7t27M0uioaGxd+/eFStWFBYWkiWNjY2nTp0KCQnhcrnDhg1TVVW9fv36 vXv3VFRUXFxc
+Hy+r68vnSPGeOXKlUeOHMnMzKyvr5dMWaqnbtuMZLUSzapIUgs7oCKRcZvU 5qzHgbwlVdVZ
02QenKNHj3p6erq4uCCElGTfuZi1aiGEJk+ePGXKFDU1NXNzc5KFgYFB3759 pTZ/8uSJj49P
RETE9u3bjxw5Ym1tLSsjWSW3t7cvLi4ODg4uKCigP01z5swxNDS0srJyd3c/ f/48c2DT0NBw
8uTJhQsXduvWTf4OEswUWEdQRI8ePaKjo1NSUrKzs21tbVNSUsjyD3eQI6c/ VWI9dnTED4+H
WnB//ZiYmJKSkvHjx0+YMMHExOTs2bPLli2LjIwkJ1tq5cLCQg0NjcDAQIRQ YGCg1Gh1wIAB
GRkZ9J8RERGfffaZ5Ar0GFQgEJAfEBFCKioq5CcqoVBIL0QIVVdXCwQCPz8/ HR2dwMBAcn3P
mjVrhgwZsmrVqgsXLhw8eBAhdP78+X379gUEBGzYsIG+roXD4ezbt4/8Sisn xxcvXmhpaUmW
kDVTxdOsqKgoLy+X6l3kpMlEH6IWnAjmwSkqKrK1tZWTHQDyScXrUxRFWpvO LheQh+4Umnt/
faFQyOfzJVdmbTkRQsrKyuSFZHdDFtJLmM3U48ePpdJnJZkpn88XiUTkF39m pgMGDLh48SLd
0RQUFOTk5NCRGHRzSquvr5dfe1n3i1i7du2JEyfoSzYV7FPIcQgODvbw8EAI qampyd93Sd7e
3pMmTVqwYAH5kzx6UyrT4uJi1hxNTEzIkZ8yZYrUcRgwYIDUBbhtmFH//v3f vHmTnZ3t6uoq
uWYLKhK9sAMqUv/+/X///ff58+dLbs56HCRLKKfMrAdHKBQqUgGadayYLC0t P//8882bN//8
888rVqzo06eP/OyYyfbq1evBgwf//Oc/HR0dL126NHDgQKlNtLW1mQMbcvsv xWs4MwXWERSt
vr4+ISHhypUroaGhI0eOJAs/rEGO1P31ZfWn7RWvP2zYsLCwsJkzZ4rF4hMn TsycOZP8qES+
ASOEdHR0SJShm5vb27dvyRdlNze3Xr16Sabj5uam4EUSQUFB6enpZA4gKSkp KCgIITRt2rSE
hAQSHCYSiXr27Ono6Pjnn3+SvMgcSVVVlY+Pz6+//kpmRxobG0Ui0bx589au XXvp0iXJLPr3
779mzZpdu3bJydHLyys5OZmiqCdPnty9exchxJqpnDTPnz+PEKqvr09LSwsK CtLV1XV0dExK
SkIInTlzhvxWxZqmSCQiYXOytOBESB0chNCzZ89GjBihyBkBQD56EgIe1fcR c3NzU1VVTUxM
RAiRn++ZrVyzUpNqppjpa2trV1VVSU08u7u7l5aWvnr1CiGUlJTk6+tLZgqZ li9ffuHChRcv
XpA/9+7d6+zsTEbVrD755JOkpKSsrKyLFy/+8ssvzbpkWUVFZd++fT/88AP5 U8E+BSHk6+ub
nZ09dOhQNzc3JycnqWRramrk3EFh69at2dnZL1++RAhpaGiMHTv23LlzCKFX r169ffvWw8PD
w8Pj0aNHJPKTngD29fXNzMy0s7MjR17qOkjWnrqtMho6dKirq2tsbCzptsRi MbkaoYtXJHKF
Nx2qUFRUlJOTw3ocFC828+BMmzbt/Pnz5LIBEp5O9+mSWKsWq/r6enp4QONw OEFBQdevX3dx
cfnkk0+WL1/+9u1bslxHR6ewsFAgEERHR8spuUAg0NbWjomJ8fLyou9A9fjx Y4qiampqrl27
Nm7cOObARk1NbeLEiXv27CH1mb7cURZmCqwjKIRQQ0NDXFycq6trfX19Zmbm 8uXL1dXVyVsf
6CBHfn/Kfn99sQQ6hKi5GW/YsKG0tDQ6OjokJGT37t329vbv3r27f//+8ePH EUJffvllWFjY
li1b9PT0EhISJk2aNHz48CFDhtCXqhCmpqb19fWkHstnb2/v4eFBrvJ59uwZ ueA9ODhYV1fX
2Nh48ODBJFTm119/PXr0qI2NjZubG7kuytvbe/jw4XPmzNmwYQNCqLCw0MrK asyYMQcOHFi6
dKlULsuXL3dwcJCTY3h4eG5urpGR0bJly+ipIGamstKcMWNGbm6unZ2dqamp u7s7+e67fv36
DRs2mJub37x5k/6Cy0wzNTV17Nixcg5RC06E1MF5+/bts2fPHB0dmzwdAMhC x92S2wBL3bUd
dE10jyC5RJHTzeFwduzYMW/ePHt7eysrK3I3EmYrpyBmM8VMv3fv3gEBAa6u rmRERfB4vE2b
Njk7O7u6ukZERKxevVpWFu7u7tu2bfPw8Bg/fvzgwYMzMzNPnDgh5+uoi4tL TEzMt99+e/To
0UmTJuno6Ci+OwihESNG0FO/ivcpERERfD6/X79+o0eP/vTTT6XS9PT0ZN5J gqajoxMXF0ff
lnHNmjXr1q0bNmyYs7NzTEwMj8fT1tZev3798OHD+/fvr6GhQVabMGHC/Pnz TUxMRo8ePWjQ
oPLycsk0fXx8zp07R2a42zwjDodz7Nix6upqU1PTMWPGWFpaki6vi1eksWPH xsXF+fv7u7i4
ODs7+/j4kPulMo+D4sVmHhwLC4tFixbZ2to6OzuTOCg/P7+ysjIPDw/JSF3W qsVq7dq1Gzdu
ZH2Ly+VOnTo1OzvbyclpxYoVZOHixYs9PT2HDh06btw4OSVPTk42Nzf39vYu KSmZNm0aWZiT
k+Pv729paRkQEEBurcMc2KxZs+bChQtmZmY2NjaK3A2TmQLrCGr79u0CgSAj I2PFihV03UMI
YYwTExPp67C7PskGWSS7P+WUlpYyN37w4EG/fv2UlZVfV4kLq3FBpUilsXze BJcWl6axsZGi
KHLJDv38XoFAoKSkRH5XwhiXlJT06tWL2aQWFBRs2LBhz549imRUV1fX0NCg ra0tubCiokJV
VVUymKesrKx79+70zERFRUX37t0lP3JlZWXkkvmW5VhdXc0Ml5TKVI7y8nI1 NTXJAmOMa2tr
JWska5pffvkl/RMBqxacCMmDs3Tp0vnz51tZWTW5C+BvJSUlhXzENDQ0VFVV 1dTUVFRU+Hw+
uRcYidgRi8Xk9+vfrj5p4OsYain17c4x0OQJhcL8/Hw7O7vO3gkgD90p0C3D /fv3/fz8FNyc
oqiysjLJn22ZrZzimM0Ua/qamppSAymxWPzu3TupX49lFfj58+e9evViBpnI MXr06ODg4PDw
cMU3YVK8TxEIBBhj1tD85nr79m3Pnj0lI3Pq6urI51dyNaFQWFlZ2bNnT2YK Fy5cePjwIX2D
7PbISCAQvHnzxtzcXHLzLl6RMMavXr3S1NTU1dWVXM48DopjHhwyGS9ZV0tL S5mnibVqSbl5
8+aDBw/mzp2reHlYKycTRVFVVVV07hMnTgwMDJwxY0ZNTY3U5szBUklJSY8e PRQ/XFIpyBpB
MR08eFBNTY15S8OO1Kz+NCsry97enmyIMZbVn8qM1//r1tctiddnoo+45K9d kq85HE7v3r1Z
tzU0NPzmm28UzEhNTY0Z2sWs2VLj+CZXaG6OrPVe8TSZM0McDoe1mkqm+ezZ s6+++kp+yi04
EZIHBwb6oPUk4/WVlZUpipKMOARdE90pNDden+ByuVIDo+bOf0tiNlMKps/j 8RQZn5EEpeIt
ZXnz5o2np+ewYcNyc3P79u07a9YsRbaSQ/E+RVb0SAsw+1/WIGllZWXWgT5C yNvb29jYuF0z
6tatm6WlpdTCLl6ROByOiYkJc7msAY8imAdHajYTIcR6mlirlpT6+vqAgIBm lUfBb5tcLpc5
1uJyuczNmYMlBY+2rBRkjaCYhg0b9mENcqR6T1n96YfRv35Yh76ztOCpfs0F JwIAACTp6+s/
fvy4s0vRJUAH8RGgL1Ftb6dOneqYjJrlY63DSiK2ax3oiJ/WxOsDAAAT3aSI xWKh8L+tTWeX
C8hDnyZ6Xh+enw0AAJ2LBPOQZpn0qqz9aXvdhwcAABQEUwkAAABAC0jF2LP2 px0Urw8AAATz
/voQr9/1tTJeHwAAQJtj3l+ftT+FeX0AQKchA0eYSgAAAABaQ05/KjNen771 NcTrAwDaEMTr
f4joTgHi9QEAoIuQ7D1bEq8Pg3sAQMeA1uaDAKcJAAC6ONaGmqvERiJen0cH 13Z8iTtAYWHh
li1bOrsUrdWsvcjLy2vXwrSTyMjIysrKrp9mV6P4PnZYxaCbFC6XSxoZ1lYI dCl0pyC5pGMq
DGhX8fHxd+7c6cgcMzIyTpw4oeDKrWmXFMmotrb28ePHVVVVLc6lU+Tn5798 +ZJ+JjFoK9XV
1bt27QoPD793756CmzTZybZr30o3y/SgnbUBlxev37LxvYqKipmZma6u7qBB g27fvt3S8jeb
r6+v5GONw8LCjhw50uRWRUVFu3fvZn0rPj5+1KhRkkuGDx9+48aNiRMnHjp0 qJWllaXN90LK
tWvXjh07RjLS19fv06ePiYlJfHx8iwvcXNHR0QYGBvQH49ChQ/PmzVNkw9jY WFnNcXuk2dV0
wD6mpKQo8gTyNvSxziB8xD6UU0aPge7cudPcB49ER0drampaWVkZGhoOGjRo x44dzfpBozVZ
t7LYLWsiEhMTHzx40Ky8aCoqKpLTTObm5m/evGlyqxs3biQlJSmSPt1htUdG hYWFEyZMGDx4
8IoVKwYOHKinp6dIkVqvNWcZIXTw4EFjY+O5c+fOmjVLV1d3586dbV1AdnSx t23bFhYW1jGZ
dhgtLa38/HyE0O7du2/fvj1//nx1dXUOh9PY2Njktk12su3at9Ktk/zGmSti QyJ+hEJhy+L1
U1NTi4uLnZ2dN2/e3KqdaKZz584lJCS0VWoBAQF379599uwZ+TM3N7esrMzF xeXIkSPBwcEt
SPDRo0eKrNa2eyGpuLj4m2++WbhwIflzw4YNxcXF69atW716dUeG3hYVFS1f vrzrp9nVtPc+
hoaGbtq0ia7w7UcyXp9ubVgbItB10J2C5JL2riotk5uba2hoSF47ODgoPj9H Gz9+/JMnTwoK
CuLj43fu3Ll27VoFN9y/f//06dNblnXri93xzSCHw4mMjMzNzW2PxCU7rPbI KDg4WF9f/+HD
h6dPn3758mXH/LjRyrOclpa2cOHC8+fPX7x48erVqyUlJTNmzGiHYkqbPXv2 3r17yesvv/wy
Li6uPXJRcIzUHvLz88l5SU9P9/PzGzx4sKWlZUVFBZ/PVzyRp0+fsraK7dq3 ksuopBpqZgPe
XvfhUVZWHjBgQE5ODkLIwcHhl19+sbKySk1Nra2tDQsLMzc3Nzc3p7+mv3jx YuzYsUZGRtbW
1leuXEEIbdy40cbGZvz48bdu3SLrbN261dXV1cbGJjU1FSGUl5c3btw4R0fH 8ePH05kuWrRo
8eLFpaWlkiV5/vy5l5eXubm5nZ0d2RYhlJSUZG5ubmtrKzkdnpycbGdnN2LE iKNHjyKENDQ0
AgMDDx48SN49fPjwzJkzEUJLliw5e/asrDLIsXfvXm9v76tXr8pfrW33QlJq aqqfn5/Uk7Qd
HBxev34tEAjCw8N37Njh6uq6bt06hFBsbCw5TaGhobW1tQihurq6efPmGRoa 2trakm9xubm5
I0aMGDRo0Pr160UiEULowoUL7u7u9vb269evJ+lLnTiE0Ny5c3/77bf09HTJ YrBWjKdPn7q6
ulpYWHz++ef0R4iZaXukGRMTExsbK3UAw8PD4+LiRo0aZWZmtnXrVnphmx83 iqJmz549ZMgQ
KysreqKuzfdRqgLzeLygoKDTp0+jDvShzBOD1khLSxs0aJCZmZm1tXVdXR1r pQ0PD//pp5/8
/PwMDQ3pD5eDg8OpU6ecnJysrKwuXrxIFjKbOKn0v/jii5KSEicnpyNHjjx+ /Jj+pfTixYv2
9vbm5uZjxox5/vw5Qujhw4ceHh779+83Nzd3c3MjE3uSBg4c+MUXX2zdupV8 juR3TIWFhZGR
kampqU5OTk+fPqWzZs2loKBg3LhxTk5Ow4YNI6m1vtisTQRia5RqamqCg4PN zMy8vLzoCfKa
mprp06cPGDDgs88+Kyoqkkpk0qRJmZmZUgs5HE5YWFh4eLjUbCCzzAihDRs2 GBsbOzk5SabD
PKQ0yQ6rzTO6cePG1atXFyxYwOW+HwXp6+sjGS1q16mcsbGxY8aMsbGxIVsp Kyv36NEDyRgh
MEvImibred+xY4epqam1tXVgYOCZM2fOnDkTHR3t6emJEDp8+HBERARZjVm1 9u/fv2zZskWL
FvXt23fGjBnkfLH2p5KuXLni5eX1008/IYQwxmZmZjU1NQih9PT0qVOnyio5 cwzG2kczTwpz
zDly5MiioqItW7ZkZmauXLnSycnJycnJ0dFRKBQitt6TtZO9efOmi4vLoUOH pEb8Hda3yutP
K9hcvXr15cuXhYWFNx7lnbj+YmfK0z1nbmDF8Pn8//znP6dOnTI1Nd20aRPG WFNTMyQkpLKy
EmO8f/9+f39/gUBQUFBgamqam5uLMZ4zZ05ISEh1dTXGWCgU5uTkODk51dfX X7t2zcvLC2Nc
W1vbrVu3kpISjLFIJMIY/+Mf/1iyZAmZGiT5+vj4/Pvf/w4MDJw+fTrGODQ0 NCEhAWMcEhLy
/fffi8Xia9euGRkZURSFMTYwMMjOzm5oaIiKijIzMyM3JTU1NX39+nV1dXW/ fv0aGhowxv/+
97+NjY3JJhYWFs+ePcMY+/v7x8fHs5ahSQ8fPpw6daq3t3dGRgbrCu2xF7Tw 8PDDhw/TGe3a
tSszM9PHx2fcuHFkvxwcHF69eoUxfv78ubGxcX5+fk1NzeTJk/ft24cxPnDg gIODQ15eHjlN
GONp06YlJiaKxeKxY8eSPRo5cuTvv/9OHxPmiYuKioqMjIyLi7OwsKitrY2P jyfNN2vFmD59
+ubNmymKSk1N5fP5JGtmpu2RZkFBwevXr6XOjr+//+jRo/Pz83NycvT09O7d u9dOxy0tLc3R
0ZGcUHKu22MfmRX43LlzAQEBClZmSefPn798+fL169fv37//9OnTgoKCkpKS ysrK2traxsZG
Mhnc0NAgEAjKy8v3nLmxM+XpiesvbjzKe/PmzcuXL69evcraEIGug+4U3vwl JSVFwephYmIS
FxdHZptkVVp/f38zM7N79+7l5ORoamqStktTU3PcuHHFxcV79uzx9fXFMpo4 qfRzcnL69OlD
sr59+zZpGzHGxsbGV69epSgqJiZm5syZ5F1lZeWVK1eS4U50dDT5rAUHB9OF f/LkCULo+fPn
inRMe/bsmTp1qlTWrLlUVla+fPkSY7xp06bPP/+8TYrN2kSwNkp79+799NNP 6+rqHj58aGNj
Q3q0PXv2LFy4kCS1ceNGqZP46NGjqqoqqYWqqqoCgcDExGTv3r0YYzMzs8LC QtYyP3nyxMzM
7M2bNyUlJYGBgaGhoWSXpQ6pJMkOq80zOnjwoL6+PmldJXXxymlqavrjjz9i BtYRArOErGky
z/uLFy/U1NSys7OxRJ+1e/duktfWrVvJUWWtWlu3bu3Wrdtvv/1WW1tramqa lZWFZfSnREZG
hre3d3Bw8KNHj8gSEixEKtvZs2fd3NxklZzZhTH7aNaTIjXmJMeKdJSenp4n TpzAGNfV1SGE
yPrM3pO1k8UYl5aWfvvtt4MHDz58+LDkyLBZfWuz+tOUlJQ3EmT1p+0yrx8S EnLp0qV9+/Yt
W7aMLFm/fr2mpiZC6Pjx40FBQRoaGgYGBt7e3seOHWtoaDh58uTChQu7deuG EFJSUkpMTMQY
r1y58siRI5mZmfX19Wpqaq6urn5+fllZWeSCMHd3959++ikyMrKhoUEy67i4 uPPnz9Mheo2N
jadOnQoJCeFyucOGDVNVVb1+/fq9e/dUVFRcXFz4fL6vry9ZMysrq6amZtOm Td999x1FUVlZ
WQihkSNH8ni89PT0rKys3r17m5mZSeYlqwwIoV27ds2XQCoNQsjGxubo0aPb tm1bt26dj4/P
06dPWQ9g2+4F7Y8//jAwMKD/jIqK2r17d1hYGAmIRAh9/fXXRkZG5DR5eXkZ Ghqqq6sHBQWR
FY4cOTJjxox+/fqR09TQ0HD27Nm0tLSlS5e+e/eOTBv4+vrOmzfv8OHDZLKE eeKIBQsW6Onp
Sf4yzqwYFEWlpKRMnTqVw+F4e3urqKgghFgzbY80DQwM+vbtyzw1c+bMMTQ0 tLKycnd3P3/+
fDsdN3t7++Li4uDg4IKCAslv6m27j8wKbGBg0ILIgdbAcGuXj93169fLy8vD w8O5XC5pBJiV
lqy5Zs2agQMHWllZ1dbWVldXk4U//PBD7969bW1tX79+jdiaOGb6rG7cuKGk pOTm5sbhcEJC
Qk6fPk2qvZ6eXkxMjLq6+oABA0gWUshsZffu3RXpmGRh5qKpqdmjR4+0tLQ/ //yT+XtCi4vN
2kQwG6Xk5ORJkyapqqra2NhYWFiQNRMTE/Py8pYsWXLr1i3JppWwtrbu3r07 s4QaGhp79+5d
sWJFYWGhnDInJyd7eHjo6en17Nlz2LBhdI5Sh1QyZakOq20zktXydPHKScaC UpuzjhBYS8ia
JvO8Hz161NPT08XFBSGkJPsph6xVCyE0efLkKVOmqKmpmZubkyxY+9MnT574 +PhERERs3779
yJEj1tbWsjKSVXLWMZhUH808Kcwxp/x8mb0naydL9OjRIzo6OiUlJTs729bW NiUlhSxv176V
rhJy+lOZ99enQ2nprxqKZ/z777/TzQdB/0wmEAjoGBIVFZXa2lqKosRisZqa Gr1yYWGhiYlJ
YGAgQmjKlClk2/Pnz+/bty8gIGDDhg1hYWFjxoy5devWP/7xDwcHhwcPHtAx VX369Nm6dev8
+fNdXV0RQkKhUCgUSuVYXFyspaUlVebCwkIStIMQCgwM7N+/P0KIEqwljAAA IABJREFUw+HM
nj37wIED3bt3JwE8kmSVASHk6+s7dOhQ+k/Jt4qLi3/++eeqqqrly5dLHSVa 2+4FbcCAAZLX
M0VERHz22WeSK8g5TaQYkvE/1dXVAoHAz89PR0cnMDCQXNi0Zs2aIUOGrFq1 6sKFCyT8SerE
kW05HM6+ffucnJxCQ0Nl5VhRUVFeXk6+IsrPtP3SlE9bW7udjluvXr0ePHjw z3/+09HR8dKl
SwMHDmyPfWRW4KKiIltbWwV3v8XoJkUsFotEiA4ubO98QWvQnUJz768vFAr5 fL7kQIf1Y4IQ
UlZWJi8kv9+ShfQSZhP3+PFjqfRZSWbK5/NFIhH5dZ41U0nJyckGBgY9e/ZU pGOSlTszl7Nn
zy5btiwyMpJ8sW+rYivSRCCEXrx4wdp9BAcHe3h4IIQke+QmeXt7T5o0acGC BXLKLCtH5iGl
SXVYbZtR//7937x5k52dTTpZWhevnP379//999/nz58vuTnrCIG1hKxpMs+7 UChUpAI061gx
WVpafv7555s3b/75559XrFjRp08f+dkxk5UzBiO0tbWZJ4U55pSP2XuydrK0 +vr6hISEK1eu
hIaGjhw5kixsv76VtMzk9V+9Kkt/2tHPzQ0KCiKzofX19WlpaUFBQWpqahMn TtyzZw8prkgk
8vX1zczMtLOzc3Nzc3Nz4/P5jY2NIpFo3rx5a9euvXTpEkKoqqrK2tr6+PHj 1dXVr169ksxi
9uzZtra25E5bGhoaY8eOPXfuHELo1atXb9++9fDw8PDwePToEQm6oL+Jurm5 vX37lny3dnNz
69WrF53ayZMnT5w4QYLGJMkpg4WFhbME8lF/+/btsmXLJkyY4Orqmp2dHRQU JOeT0LZ7Qb+r
4NUhQUFB6enpZPIjKSkpKCgIITRt2rSEhAQSPi4SiXr27Ono6Pjnn3+SvMj3 lqqqKh8fn19/
/ZVMDzBPHK1///5r1qzZtWsXnaNUxdDV1XV0dCQ/bpw5c4b8NsKaaXukWV9f z/y5BiH0+PFj
iqJqamquXbs2bty4djpuAoFAW1s7JibGy8srOzu7nfaRWYGfPXs2YsQIRWoI AApyc3NTVVVN
TExECJGYNGalbVZqUk0cM31tbe2qqiqpSWJ3d/fS0lJSz5OSknx9fcmsnnyP Hj36+eefv//+
e4SQIh2Tjo4OM9Kd1YkTJ2bOnEkCfkhT01bFZjYRzEbJy8srOTmZoqgnT57c vXuXrOnr65ud
nT106FA3NzcnJyepZGtqauR8u9u6dWt2dvbLly9lldnLyys9Pb2mpqa6upq+ JwnzkEqmydph
tVVGQ4cOdXV1jY2NJQdfLBaT4P4uXjmXLFlCAg3In0VFRTk5OawjBMWLzTzv 06ZNO3/+PLls
gIwaWSs2a9VixdqfcjicoKCg69evu7i4fPLJJ8uXL3/79i1ZrqOjU1hYKBAI oqOj5ZScdQwm
1UczTwpzzCn/+DB7T9ZOFiHU0NAQFxfn6upaX1+fmZm5fPlydXV18lan960d fX/9GTNm5Obm
2tnZmZqauru7kwnLNWvWXLhwwczMzMbGJjk5ecKECfPnzzcxMRk9evSgQYPK y8sLCwutrKzG
jBlz4MCBpUuXIoTWrl1rZ2fn4eExefJkS0tLqVz27NlDH+I1a9asW7du2LBh zs7OMTExPB5P
W1t7/fr1w4cP79+/v4aGBllNT08vISFh0qRJw4cPHzJkCH11i7GxsYuLy9Ch Q3V1daVykV8G
puXLlw8ZMuT69etTpkxR5Hi24V4QPj4+586dIxMG8tnb23t4eJALf589e0au 9A8ODtbV1TU2
Nh48eDD5jfjXX389evSojY2Nm5tbVFQUQsjb23v48OFz5szZsGEDQoh54qQO iIODA3nNWjHW
r1+/YcMGc3Pzmzdv0t/CmZm2R5pr167duHEj88jk5OT4+/tbWloGBATQt1No 8+OWnJxsbm7u
7e1dUlIybdq09ttHyQqMMU5MTJS85Ws7oZsUHo+nrKwM99f/ILT4/vocDmfH jh3z5s2zt7e3
srIidw5hVloFMZs4Zvq9e/cOCAhwdXUlox+Cx+Nt2rTJ2dnZ1dU1IiJi9erV cnJJSkqysbGx
srKaO3fu5s2bZ8+ejRBSpGPy8/MrKyvz8PCQE5ZDhISE7N69297e/t27d/fv 3z9+/Hjri02T
bCJYG6Xw8PDc3FwjI6Nly5bRF3pGRETw+fx+/fqNHj36008/lUrT09OTedUv TUdHJy4ujkRa
s5Z5zJgxjo6OFhYWbm5uAwYMIFsxD6lkmqwdVltlxOFwjh07Vl1dbWpqOmbM GEtLS9IqdvHK
OXbs2Li4OH9/fxcXF2dnZx8fH3K/VOYIQfFiM8+7hYXFokWLbG1tnZ2dSYTw rFmz4uPjpe75
w1q1WMnqTxFCXC536tSp2dnZTk5OK1asIAsXL17s6ek5dOhQ5oSaVLLMMZhU H806KJIaczZ5
iJi9J2snu337doFAkJGRsWLFCnpUhhBq175VslmW059yKioqmBvfv3/fyMhI WVm5oFJUUCku
qBSpNJaHfzKkrQpXXl6upqYmdUOYkpKSHj160L/iCYXCysrKnj170iuUlZWR S86J+vp6iqLo
0bB8b9++7dmzp+RPhHV1dcrKykr/G6qFMS4pKenVq5eC322aVYbWa/1eXLhw 4eHDh4sXL1Yk
u7q6uoaGBjpShaioqFBVVZU8d2VlZd27d6enZCoqKrp37y7Z1kidODmYFQNj XFtbK/mxYc20
zdO8efPmgwcP5s6dK7nCxIkTAwMDZ8yYUVNTwxq6SrTJcaMoqqqqSiqRtt1H 9L8V+ODBg2pq
alOmTFEkRykpKSlk7zQ0NFRVVdXU1FRUVPh8PqmcZGRP7tgoFAqPZTxt4OsY aikZavEMtZQa
Gxvz8/Pt7e1bkC/oMHSnQLcqf/zxh4+Pj4KbUxRVVlYm+Usjay+gIGYTx5q+ pqam1KBHLBa/
e/dO6gfPZmmyY0IIlZaWSq4gS2NjI0VR5KpTVVVV0oy3U7FZG6Xq6mpmOyYQ CDDGcto3BbGW
mTVH5iGlKdJhtTIjgUDw5s0bc3NzyY61i1dOjPGrV680NTWlpiCZIwTFMc87 mYynA6JEIhH5
wVlqQ9aqJYW1P5WP9QwySY3BZPXRrIMiqTFnk6R6T1mdLFNz+9Zm9ac3btyg v5FijGX1pzLj
9UlcZsvi9Zuko6PDXChVxZWVlaU+k1LtabM+h71795ZawhqtxeFwmGvK0bK2 oMVavxfe3t7G
xsYKZqempsZMn/mRljovTa4gB7NicDgc1s9Se6dZX18fEBDAmiCXy5XfBrXJ ceNyuQoO9FEr
jptkBR42bJiVlZWCObYGxOt/iOhOobnx+gSXy5Vq4Vl7AQUxmzgF0+fxeK0Z MSMFOiaEkCID
fSRxHZdkwEY7FZu1UWJtxxQJbVIEa5lZc2QeUpoiHVYrM+rWrRvzZ/kuXjk5 HI6JiQlzebNG
L1KY511qckpJSYm1S2KtWlLk9KeyKPhtk3UMxuyjWQdFzf1MSX3SZXWyTO3a t5KWmbyWE6/f
xAXI4OPTMeO5Dx19SY2kU6dOdXxJOkzHVwys2AP/AAB/W9BhfQRY+9P20DX7 6A6bRCMvWPtT
JSW2+w2R0ExlZWUeD3E44jaM1wcA/M3R8fpKSjwlJSWKokiIYWeXC8hDdwqS SzqxPAAAALhc
Lt17Yoxl9afyApXg1tcAAABo0CkAAEDXoeBEfLvcXx8AAGSRjNcXizl0a9PZ 5QLytPj++gAA
ANqJVO8pqz/t6PvrAwAAAAAAADqGvHh9JSUliNcHALQtyfvr0yBev4ujTxPd F0C8PgAAdC7S
MpNmGWMsqz+FeX0AQCeDEEEAAACgBaTm4ln7079XvH5GRsbbt2+ZTwTsXM0q VV5enpGRUXsX
qTUKCwsTEhKWLVvWxdPsLPHx8fb29o6Ojk2u2fXPdcsw768P8fpd398qXr+m pqa+vl7xh3hI
iYyMXLJkCf0QIlb5+flisdjIyKhlTz7qFLW1tXl5eX379tXU1OzssnxssrOz f/31V319/VWr
VimyfpPDBoFA0NjYKPWwLfDxYd5fv+Pi9RsaGnr27EmeGS6L5PeHiRMnHjp0 qFlZqKiobNmy
hf7T3Nz8zZs3TW5148aNpKSkZmXUpUp17dq1Y8eOkdeKHGSEEHmWOOrAg1xU VLR79+6OTLPF
6INz584dc3PzZm0bHR1tYGBQWVlJ/jx06NC8efMU2TAxMZE81bxJKSkpijy+ +4NGBo4QIvg3
R38SW8DX11dfX793794jR46U35AqmAtFUYsXL+bxeC3+jMfGxlZVVcl69+DB g8bGxnPnzp01
a5auru7OnTsVSbP1WtMXFBYWTpgwYfDgwStWrBg4cKCenl47FJCF5CnT0tLK z8/vmHw7Bn0i
hELhxIkTg4OD3d3dv/3229WrVze5bZPDBmVl5a+//rqxsbHNigu6PDn9KVeJ DQn3IS/o4FrF
8zt58qSKisqhQ4fk1DMTE5OcnBzy+siRI8HBwc3dpcjIyNzc3GZt1WJCofDZ s2dNrtaupSou
Lv7mm28WLlxI/lTkIM+ePXvv3r3kdRc5yB184uTYv3//9OnTyWsHB4d79+41 N4WioqLly5e3
dbn+KzQ0dNOmTYpUvA+LrHh90JUxz1FbxetLfhJbZsOGDcXFxYGBgXJ++pNs DOWLiIhwdXUl
jwht8894WlrawoULz58/f/HixatXr5aUlMyYMaMN05ellX1BcHCwvr7+w4cP T58+/fLlyzt3
7rRDGaXl5uYaGhrSf+bn50v+2VYqKysVmW9qD/SJuH37ds+ePYcPHz58+PDI yMh169Ypnois
wYmKisrkyZP/n717j26izv/HP5nM5NL0mqalkBbaprQFCghFKFKXIpcKiNwR L8sqKLqsxw9n
jyvrF2VFdpXVxbOuyn4QPqirLCroeuMqNy+ARZRLAbkVSlt6SemFpLk0k8z8 /ngf5jebG22S
ttPyfPzBCSGdzEzI+/XuO895ZenSpRHbXZAl6cgcpJ4GXNcPJ7Szfv36t956 S61Wf/HFF+Qe
h8Px+OOPp6amDho06NVXX/3Tn/5UU1Mze/ZsMjQvXbr0q6++oijKbrcvWrTI ZDKZTCZx9Xfx
4sXr16+fPHlyamrqa6+9Ru5UKBSLFi1avHix137u2bNn8ODBJpNp/Pjxly5d IneuWrWqX79+
+fn5Bw8eFB/55z//ecCAAVOnTj169OhNj4jn+YULFy5cuPDy5ctBHtahe7V7 9+7JkyeL3wh9
05P85Zdffvnlly+//PK4ceOoiJ7kS5cuTZgwwWQy5eXl7d69m9y5bds2k8k0 aNAg6QL89u3b
8/LyxowZ8+GHH0Zqm76naMaMGdJzSDz88MMFBQWDBw9+7733yD179+697bbb MjMzc3Nzy8rK
Vq5cuXv37vz8/AsXLpw9e/aee+4J9GKdOXOmqKho48aNJpOpsLBQXFt65JFH Pvroo/3790uf
1+/ptdls8+fPz8zMnDBhglhXLl68OGbMmNtuu+3FF18kn7hVVFRMmTJl2LBh U6dOpShKqVTO
nTtXfH17sJ4REezxQn6Zhg4d+s4772RnZ+/evXvPnj1FRUVDhgyZMmWK1Wqt rq6WvhNtNtsD
DzwwcODARx99tLa21ms7q1evXrNmjd+nUCgU/fv3t1qt5K9eb3+vwdD3rSf1 8ccfP/LII+R2
29/jFy5cKCgoyMrKeuyxx8R0k+8TrVmzZvz48QMGDCAPYFmWJIXaOOxs3Ljx 6aeffuqpp/r0
6fPggw+SV8T3pEW2Fhw5cuS7775bsmSJGDfq3bs3ubFmzRry4wsXLrTb7YH2 0G998a0Oly9f
vvvuu/v27Zubm/vtt9/+9re/ra+vz8/P37x5M0VRd955Jzk6v8Vi6NChn3/+ eX5+fnZ29p49
e8hJyMzMDJI0s1gsL774YlFRUWNjI0VRf//731966SXyT9OnTz906FCgPX/t tdcKCgoGDBhA
np28Uq+99lpaWtqsWbPOnDnj90WhKOr111/PyMjIzc2dM2eO+EJYLJYFCxZc unQpPz8/Pz9/
2LBh4kc9vsXOd9oQZHIyY8aMPXv2YHS91fh/xa/5c+DAgbKysoqKisOnLn9y +NLrO8//7xcl
QtuQ38Xdbvfzzz9fXFxM7nz33XeHDh1aUVEhCALHcYIg9O7d+5dffiH/eu+9 9/7rX/8SBGHj
xo333ntvS0tLVVVVRkbGxYsXyb9mZmaeOHHi3LlzsbGxra2tgiBoNJqWlpb0 9PS3335bEITM
zMzq6mpBEPr16/fdd9/xPL969eqHHnpIEITz589nZmbW1NTU19fPmTNn4cKF giCcO3cuPz/f
6XQeOnRowoQJbTy0nTt3FhYWPvroo5cvX/b7gA7dq8WLF3/wwQftOsn333// P//5z4if5AUL
FvzlL3/xeDyHDh3q27cvz/OCIBiNxpKSktbW1pdeeikzM1MQBJ7nMzIyrl69 arVa09LSIrJN
v6fol19+sVgsXqertLSU5/kjR47079+f3JOenv7mm2+SKJsgCOvWrbvvvvvI P/38889k+35f
rJ9//pll2WXLlpHh++WXXxYE4aWXXlq5cuWbb76ZlZVlt9v/9a9/kV9g/J7e t99+e9asWQ6H
48yZMwMGDCAvxP33379161aPx3P33Xd///33giA8//zzS5cuFQRBvE5mx44d s2fPDvxfUi52
7tx54MCBH374obS09MKFC1VVVfX19devX7fb7S6Xi+M4t9vd2tra0tLS1NT0 v1+UvL7z/CeH
Lx0qvVRRUVFWVnbgwAG/AxHIh1gUKm/Yvn17G/97xMbGLliw4Pr164IgVFRU NDU1CYIwZcqU
TZs2Cf/9Tly3bt2TTz4pCMJLL7305z//2Ws7VVVVV69e9bpz0qRJf/jDH/7x j38MGTJk3bp1
5E7ft790MPR964mqq6uzsrLI7Xa9xx944IFXX32V5/ndu3erVCoyDvs+UUZG xv/+7//6nqI2
DjuvvfZadHT0Rx99ZLfbMzIyDh8+7PekRbYWvPfee7179yZjstSlS5f69etX WVlps9lmzpy5
YcOGQHvou02/1eHhhx9esGCB1Wolu33u3LlevXpJ/xeRI/JbLGJjY6dMmVJX V7du3TpSEz0e
z9GjR31PtSAIFotl1apVQ4cOXbduncvlIneuWLHi97//Pbk9YsQIMkv23XO7 3R4dHV1fXy8I
AiklP//8c1RU1MaNGx0Ox7Jly2bOnOn3Rbl8+bJWqy0pKRFfFPGF+Oabb4YM GUKeetmyZc8+
+6zgr9j5nTYQgSYno0aNKi0t9XsSQLbaVU+3b99OBuSKioog9TRYXj+0EO2G DRvmzZtns9nm
zJmzZ8+eiooKiqI2b9784IMPpqWlURTFBG6ut2XLlrlz5+p0OqPROHHiRDGb vnz58iFDhmRn
Z9vtdnHlRqfTvf32288880x1dTW558iRIwzDFBYWKhSKBQsWfPHFF62trdu3 by8qKkpJSTEY
DKNHjyaP3Lp1qyAIy5Yt27x588GDB51Op3Q33nrrrSckHA4Hub+4uPi7776b NWvW3Xff/fjj
j9tsNt9D6Li9OnnypNFo7PKT7HK5Pv/88wULFtA0PXr0aI1G88MPP5w4cUKt Vo8cOVKlUhUX
F5NHHj582GazvfLKK8899xzP84cPHw5/m35PUW5ubkxMjNdh5uTk/PTTT/v2 7SPrYT/88ENT
U9PixYtpmg6SPfD7YlEUlZKSsnr16qioqIEDB169elV8/JIlS1JSUlasWBH8 9G7fvn3GjBka
jWbAgAFZWVkURbW2tn711Vd79+79/e9/39jYSBaixo4du379+pUrV5InpSjK aDSGEC6SOeHG
qgNi+t1OyC/Ziy++SC7oTEtLczqd//nPfxobG33j11u3bq2oqFi6dOnRo0fJ m0LKaDT26dPH
d+OHDh3atGlTVlbW4sWLyT1eb38pv289kXSYJdryHud5fteuXffdd59CoZg4 caJarQ70RKSW
e+1Su4admTNnzps3T6vVmkwmcqfvSYtsLfDdYfHHJ0yYkJqaGhUVNXfuXPHH fffQd5u+1aG1
tfU///nPk08+GR0dHWS3/RYL8k9vvPFGcnLyoEGDyJPSNJ2fn++7hTVr1gwc ODAxMfHIkSOL
Fy9mWTbQ+fG751qttqCgYPLkyYcPHxZLSUpKyiOPPKLRaB5++OG9e/e63W7f F+XDDz8cN27c
yJEjg78oIt9i53faQASanPTICgJSbaynjN//c5IYrdCu/vput/u9995LTU2d OHEiRVGJiYnv
vvvuihUrOI4TwydBtLS0iA9Tq9XkM0GKosR3o9duTJw4ccaMGUuWLPH9cZVK 5Xa7OY67fPmy
bz+E6urq9PR08jnavHnzvDohFBcXjxo1SvyrSqUSb584cWL9+vVZWVmPPvqo TqfzexQdtFcD
Bw4k8Y+uPckcx0mfiGyhrq7O7+HodDpyOHPmzMnJyYnINoOcItGVK1cKCwuf ffbZESNGiE+h
UqlumjD2+2IFOTkKhWLDhg35+fkLFy703YJ4en1fbqvV2tLSMnny5ISEhDlz 5pBr3caPH3/0
6NHnn39+6NChp06dUqlUtbW1gwYNCr7P3Q5N02Jen2EYnufRX1/+xJIQWn99 8a36xz/+8fjx
40uXLk1PT/d9WHV19fz584uKiiiK0mq1bdz4ww8/PHv27Ly8vE8//XTWrFm+ b38pv289kTjM
itryHm9ubm5qavLqTuP3iXJycj777LMnnnhC+sh2DTu+d/qetMjWgpycnJqa mpKSkoKCghB+
3O+dvtWB53mPx3PTF91vsZA+xU3nKvfdd19ZWdn777+fmpo6bdq04A/2ezg7 d+7csGHD7Nmz
V61atWjRIq/HR0dHMwzj90Vp+39pyl+x8zttEPmdnPTICgJSJI5PbguCEKie RrgPz5dffjlo
0KAjR46UlJSUlJT84x//2LhxI8/z999//7///W/S0IDEFhMSEnzjmHPnzt25 cydFUU6nc+/e
vXPnzr3pM7722mslJSXl5eUURY0dO/batWtXrlyhKGrbtm3FxcXR0dETJkzY v3+/zWazWq1i
V5Pi4uKDBw/m5eUVFhYWFhZKZ/MURWVlZY2QICWttLR0zpw5/+///b8//vGP X3311e23397J
e1VYWEguwenak6zT6e6+++4dO3ZQFHXlyhWz2VxUVFRUVPTLL79cuXJFEARx daewsNBsNpP1
qsLCwqSkpPC36fcU2Ww2r1DmN998k5OTs2TJktjYWNI6trCwUKPRbN26laIo nud5nvd7cvy+
WMFPTk5OzvLly996660gp3fChAnbt2/nef78+fPHjx+nKMpgMAwbNuz06dPk QMhiv8Viyc3N
3bJli9VqJftQVlY2ZsyYm75A3ReW9m81H3/88XPPPXfXXXc5nU6yei19JxYX F5eUlIwaNaqw
sNB3UVb8EV8JCQnr1q1bvHhxdXW179tf+ix+33qitLQ0Ui+ld970Pa7X64cN G0b6onz55Zfk
o2C/T7R06dL9+/eLH3LW1taeO3cuhGFHyvekRbYWjBo1qqCgYM2aNeTkezwe EhafO3fu/v37
nU6nIAjbtm1rSykR+VYHrVY7ffr0devWkdfL7XbHx8dbLBavz7f9FotAzyL2 UJJKTU1du3bt
Rx99tH379jFjxojdbBITE8lHzVu2bCGjtF8ul8vtdj/++OMrVqzYt28fudNq tZJPkL7++usp
U6ZQAV6UnTt3kosx2tJi2LfY+Z02UEEnJ/X19YMHD77pc0HPEKSe0m5/Qu6v v379+scee0z8
68yZM1taWvbu3Tt//ny9Xt+vX7/hw4eTD0N/97vfLVq0SNp+kaKoBx988OLF i3l5eRkZGWPH
jh0yZMhNnzEhIeHNN98kQ7NSqXzllVdGjBhRUFDwwgsvkMZV48ePHzZsWFZW VmFh4cCBA8lP
TZs27YknnkhPT7/rrrtuu+22pqam4M9itVqXLVv2hz/8Ydu2beQzuM7fq0mT Ju3YsYPjuLaf
5F//+tf/+te/vPo8hHmSKYpavnz5n/70p9GjR48YMWL16tVKpTI+Pv7FF1+8 4447cnJyxBWF
lJSUf//73zNmzLjjjjtuv/128SKqcLbp9xSNGzfuwIED0o1PnTq1srIyLy/v 73//+5AhQ5Yt
W6ZQKF5//fXHH3988ODB2dnZ9fX1kydPbmhoKCoqkn7K7/fFuqk//OEPQ4cO DXJ6Fy9efPHi
xb59+z799NPiZXmbNm368MMPBwwYUFhYSK4JW7FiRV5eXlFR0cyZM0nOeOvW reJFwz2GOKSI
gwy5AXLm+zKF1l9/yZIl8+fPHzlypMlk2rBhwy+//CJ9J77wwgsqlSotLe2u u+7y7R2+YsWK
VatWBdryPffcc8899/zmN7+ZMmWK19uf+u/B0PetJ3XvvfeKV4uKbvoef/HF F1etWmUymX78
8Udx+db3ie6+++4333zz3nvvHTly5IgRIyZNmnTq1KnQhh2R70mLbC1QKBQf f/yx1WrNyMgY
P358//79ybEMHjy4qKiItE8oKytrV0Mhv9Vh+fLlX3/9dWZm5oABA7Zv356c nDx79uyCggIy
sxf5Fgu/T2G32+Pj4wP9L01LS/vnP/+5efPmL7/8kmRsZs2aRS7w+Pbbb8XX 2ld1dXV2dvb4
8ePfffddac/rlStXFhYWrlmzhrS+8X1RsrKynnrqqUGDBo0YMUJMpQbhW+z8 ThuCTE527959
xx134PutezbfYdlvPVVcu3bN94dPnTqVlpbGsuxVi6faKlRdd6tdTY9Pu/kc N7jm5maNRiN+
+tbS0sIwjO9HjU1NTVqtti0fQfrl8XgaGxu9VpGtVqtvpJvjuOvXrxsMhtCe qPP36uuvvz5z
5sz//M//BHkir5PsdrtbWlpI/zipME8yRVFms9lgMEhTNA5a8zxOAAAgAElE QVSHg2VZrw+P
BEGor69PSkpqywpuG7fpdYr+9re/zZ49OyMjw2trFoslNjaW4ziXy0V+W+B5 vqGhQfoqXLt2
zfdU+32x2sXv6fX7cjc0NMTExIif4TidTp7no6KiKIp67733tFrtvHnzQt6N TrNr1y7yv06n
02k0Gq1Wq1arVSoVee1IYsfj8ZDP3z/67nyrKiE1jukTozDGKjmOIzOzrj4I CEYsCuIbubS0
dPLkySFsqqWlJSoqiqbp5uZmcWiSvhNbWloEQfB9s7SL79vfazD0euuJOI5b uHDh2rVrg++A
73tcEAS73e6b7fR9IkEQrly5EhsbK/2qozCHHd+TFvFa0NLSUlNTYzKZvIbo 1tZW3822hd/q
UF9fn5iYKD4FCUf5Tlh9i4WvJUuWrF27tl37Y7PZ2vKhSkNDg/hVa8eOHZsz Z05ZWZnFYomJ
iZEei++LQj6bCv49a1K+8wG/dcSXy+V65JFH1q9fT6oJdCPtqqeHDx/Oy8sj /+sEQQhUT4Pl
9RmGUSqpduX1g/MaDgK9oxISEsJ5FqVS6Ttc+n1vsCzbORN9KkJ7NXHixH79 +gV/Iq+TzDCM
31E4zJNMUVRycrLXPX7DiAqFwveRYW7T6xQNGDDAd6JPURSJz7IsKwYuaZr2 ehX8nmq/L1a7
+D29fl9ur+/mlFbc0aNHZ2dnh7Mb8iTtr0/y+jRNI68vc2JRCC2vLyWO/NKh SfpObFeCJRDf
t7/XYBjoa3FZln3zzTcdDkfwGZXve1yhUPi9iMv3iRQKhe/lCmEOO74nLeK1 IDo6un///l53
arXadsXQpfxWB6+TEGj3blpW3G739OnT27s/bfy/5/c/j+/XCftuTfrbV1v4 zgfa+Dtwa2vr
mjVrMNHv8ZRKpTjEkfyh33qK+trN9MjJX5hIN/qeB681QJdo+7IryBbDMG2J yoRv2LBhMvzG
w5iYmDA/GYOehHH7u0Yk5Lw+AEBw0ry+x6PweDw8z/sdiEA+xKIgruuHltcH AIBIIcOy9K9+
62nArBv6YwBAR8MiQjeCogAAIFtB6mnAvD5J/EQ2rw8AgLx+dyQWhfDz+gAA EBHSbvpB8voR
7q8PANBG+AJdAACA8AWvp8Hy+gTy+gAQQTzPkyGFxArFIHhX7xcEI1YE6T1d uD8AAEDa55Pb
N66C81NPg63rY34PABGHVfzuC0UBAEA+2lhPO6q/vt1ur6io6NOnj2/HWfmz 2WxOpzNQ92XZ
+v77781ms++XTcptm3JWUVHRt2/frt6LHk6a12dZlud5aeIQ5CmC/fUBACAi vKpnoHoa+bx+
dXX1tGnThg8f/swzzwwZMiQlJSXiT+EXz/PkxrFjx0wmUzjb+Z//+R+lUvny yy/HxcX17ds3
KSkp+FfVRpxarf7b3/4m/tVkMtXU1Nz0p44cObJt2za//3T48GGlUllSUkL+ WllZmZOT05Y9
CbJN+YjUS09R1K5du7Zv3x6JnQIAAADoepHvrz9//vzc3NzPP/+cfHl1Wyap 4bt48eKvfvWr
6upqiqKGDh164sSJkDf1wgsvFBQUkO8XnDZt2gcffHD+/Pm8vLwlS5a0cX4c PoVCsXLlyhkz
ZmRlZUVws4sWLfr55599vxO+W9u4cePu3bs//PBDKuyXnqKohQsXjh8/Picn J8zfGSAIaX99
jqOQ1+8W0F8fAEBuPB4Px3FkWA4xrx+CI0eOfPfdd0uWLCETfYqievfuTVGU 3W5ftGiRyWQy
mUziivXixYvXr18/efLk1NTU1157jdw5dOjQzz//PD8/Pzs7e8+ePeTO7du3 5+XljRkzhkzp
KIrau3fvbbfdlpmZmZub63A4fvvb39bX1+fn52/evPns2bP33HMPediePXsG Dx5sMpnGjx9/
6dIliqLOnDlTVFS0ceNGk8lUWFhYWVnpdQgff/zxI488Ir0nPT09Njb23Llz 5GdXr17du3fv
1tbWS5cuTZgwwWQy5eXl7d692++O2Wy2Bx54YODAgY8++mhtbS1FUTzP/+Y3 v7n99tuzs7Ov
X79OUdTXX389duzYwYMHv/jii2QjCoVi0aJFixcv9voVy/dwKIpatWpVv379 8vPzDx48KD7y
z3/+84ABA6ZOnXr06FFyT2FhoVqtfumll7yON+RtOhyOzMxM33r/+uuvZ2Rk 5Obmzpkzh6Io
v2ep7S+974FIz3BZWdnKlSt3796dn59/4cIF6Uu/Zs0a8v9t4cKFdrudoqiN Gzc+/fTTTz31
VJ8+fR588EFybisqKqZMmTJs2DDy5btKpXLu3LlffPEFBZ0IKXAAAIAQeGXs /dZTmvFHktdX
iuHatjzl2bNne/fuPXToUK/7P/roo2vXrp08efLbb79du3Yt+ULpurq61atX //Wvf923b9/K
lStdLhdFUeXl5W+//faOHTuefvpp8luBIAhPPvnk7t27d+3a9cwzz5CHPfro o4899tjFixdP
nz6t1WrfeuutxMTEn3766f77729tbRVn8I8++ug///nPixcvTpo06U9/+hNF Ua2trYcOHTp/
/nxpaWm/fv02bdok3c+amhqPxyPmUD0ez9mzZ5ctW6bRaH71q1+Rn9VoNJWV lWq1euXKlXfd
ddeFCxfWr1//2GOPkfPrtWObNm1KTEw8c+aMyWT6v//7P4qiDhw4UFpa+uOP P547d45czLBq
1arf//73paWlzz33nLgnf/nLXy5fvrxhwwbp7vkezoULF959992SkpJdu3aJ v1+dP3/+s88+
O378+HPPPffss8+SO5VK5caNG1999dXTp09HZJtqtXrLli1emd3y8vJnn332 o48+Onv2LPnF
zO9ZauNL7/dApGfYZDItX7580qRJP/30U//+/cWX/vLly2+88cY333xTWlra 3Ny8efNmiqKu
X7++bt26wsLCsrKyw4cPk0TThg0bcnJyjh079uWXX5Ltm0wm6W84EHFe/fXF 0QbkzPdlQl4f
AKBr+Q7L/utpZJ810Prcli1bHnjgAZ1Op9PpJk6c+PHHH5Op2/Lly4cMGUJR lN1ut1qt5HLY
N954Izk5edCgQW+88QZFUYcPH7bZbK+88gpFUTzPHz58WK1WNzU1LV68WJyJ +nXkyBGGYQoL
CymKWrBgQW5ubmtrK0VRKSkpq1evpihq4MCBV69elf7IyZMnjUaj+NedO3de v3592rRpP/74
I0n1GI3GpUuXUhTlcrk+//zzU6dO0TQ9evRojUbzww8/KBQKrx3bunWrVqtd unRpZWVlY2Pj
8uXLBw8eXFdXN3/+/FdffTUtLY2iqOLi4scff9xqtT700EPiU+t0urfffnve vHlkvTnQ4Wzf
vr2oqIhcFDF69Ggyj9+6dasgCMuWLeN5/uDBg06nk2xh6NChS5cuXbRokfjx SDjb1Gg0+fn5
Xuf8ww8/HDdu3MiRIymKYhjG71kaPXp0G1963yc9fvx4W176LVu2TJgwITU1 laKouXPnvvvu
u4sWLaIoaubMmfPmzaMoymQykZd+7Nix06dPj4+Pf+aZZ7RaLXmJwwwCQduR RQR05gEAAAhH
kHoaMK8vtr5uV14/JyenpqampKSkoKBAen9LS4tGoyG31Wo1yVRQFMWyrHQX pXeK91RXV+t0
OhIImTNnTk5OztmzZ1Uq1U1XlaRPqlKp3G43x3GBnpQYOHCg9AKDqVOnfvDB B9IHiFNMjuM4
jvM6KJVK5bVj1dXV8+fPLyoqoiiKTCWTkpJOnTr117/+ddiwYfv27RsyZMjy 5ctvv/32Z599
9uuvv37vvffEn504ceKMGTOWLFkS5HAuX74cFxfndRTV1dXp6enkjM2bN086 LV6xYsWnn376
j3/8I4LblOI4jhxmkLNEbrfxpfd6Uo7j2vvSB3/S8ePHHz169Pnnnx86dOip U6dUKlVtbe2g
QYOCbx/Cgbx+dyQWBeT1AQBkQlo9Q8nrh5agHTVqVEFBwZo1a8gKusfjIXGI uXPn7ty5k6Io
p9O5d+/euXPntn2bhYWFZrOZLD8XFhYmJSUVFhZqNJqtW7dSFMXzPM/z8fHx FotFXMAmxo4d
e+3atStXrlAUtW3btuLi4ujo6ODPlZaWRr7i56Z7pdPp7r777h07dlAUdeXK FbPZXFRU5Ltj
xcXFJSUlo0aNKiwsJKvgLS0t8fHxq1evnjBhAomRWCyWSZMmbdq0SQypi157 7bWSkpLy8vJA
hzNhwoT9+/fbbDar1So2kCkuLj548GBeXh45Y9KLcdVq9YYNG8iqefjbJNcb SN1///07d+4k
uX+32+33LN303Ip8n9T3DCckJJALIaTmzp27f/9+p9MpCMK2bduC/H+zWCy5 ublbtmyxWq3k
PJSVlY0ZM6btOwnhQ16/W8DLBAAgc34Hav8xnpD76ysUio8//vixxx7LyMgY MGDA5cuXBwwY
sG3btgcffPCTTz7Jy8traGiYOXMmCW+0UUpKyr///e8ZM2ZkZmZyHPeXv/xl 0qRJr7/++sKF
C1etWuVwOA4ePNirV6/Zs2cXFBS8/PLLYpdPpVL5yiuvjBgxwmQymc3mjz/+ uC1Pd++99374
4YcPPPDATR+5fPnyOXPmrF279uLFi6+++ipZbPbasRdeeOHhhx9OS0sbOHBg fHz8p59+un37
9j/+8Y8mk4nn+fvvv5+iqIkTJyqVSp7nV61a5fUUCQkJb775JlnY9ns448eP //TTT7OyspKT
k8eOHWuz2SiKmjZt2hNPPJGenj58+PDGxsb9+/dLtzlmzJgnnniCXCYbzjbV anV8fLzb7Zau
smdlZT311FODBg0aNGhQXFzc3r17/Z6lNvJ90oSEBK8zPHny5BdffLGoqOj9 998Xf3Dw4MFF
RUUmkykuLi45OZkEwPxasWLFnj17DAbDzJkz+/fvLwjC1q1bxd+FoCOIeX2a phmG4Xm+I/KE
EFnorw8AIDdiN30yxQ9UTxXNzc2+P1xaWpqWlqZWqyubuarrnqrrbrWrafE9 t7f96VtaWmpq
akwmkzTs0dTUpNVqxXBFuwiCUF9fn5SUJFYanucbGhqSkpKk24+NjfWqQB6P p7GxUfqw4DiO
W7hw4dq1a2NiYtryeLPZbDAYpIfpu2MtLS2CIIgb5HneYrGQCwCI5ubmmJiY ttROv4djtVp9
95bjuOvXrxsMho7b5pIlS9auXeu7QafT2draKg0C+Z6ltvM9EN8zfO3aNd8j dTgcra2t0vPs
l9Pp5Hk+KiqKoqj33ntPq9WSTD+03a5duzQajUaj0el0Go1Gq9Wq1WqVSsWy LJkdKhQK0hqM
47iPv7/QqkpIjWNS45SpcYzL5aqsrBw8eHBXHwQEIxYF8Z6TJ09OmjSpC3cJ AKDnaVc9LSkp
EdvhCIIQqJ4G66/PcVwI/fWJ6Ojo/v37e92ZkJDQro1IKRSK5ORk6T00TXtN T/1uX6lUtn2i
T1EUy7Jvvvmmw+Fo41zfa6/87phXdoimaa8J6E3noyK/h+N3V1mWbctEP+Rt ut3u6dOn+90g
+W8qvcf3LLWd74H4nmG/R6rVaqUXDwQi3dXRo0dnZ2eHuqfQJtK8vtuNvH73 IBYF5PUBAGSC
XEZFbgfJ6+Nzcz98r0wFXwzDFBcXd/VeRBgm+p0MHXgAAADCF6SeRjivDwAQ nFd/ffKNFsjr
yxzy+gAAcuNVPQPV0wh/by4AQNuhtQsAAEDIxDIapJ4Gy+uH0F8fACA437y+ 2+1GXl/mxKKA
vD4AgEyQkZncvlFV/dRTrOsDAAAAAPRMyOsDQKeS5vVZlkV//W4BeX0AALnx SucHqqcB1/Ux
uQeAjoZwYDeCogAAIFuh5PVJLhN5fQCILOT1uyOxKCCvDwAgE9Ju+sjrA4Ds iCsIWDAGAAAI
WfB6Giyvz7Is8voAEFliXp9hlAzD8DyP/vryJxYF6T1duD8AAEDTtFg9BUEI VE+DresjtwMA
ACIUBQAA+WjjQjz66wNAp5Lm9T0ehTjadPV+QTDorw8AIDde1TNQPUVeHwAA AACgZ0J/fQDo
VNL++iLk9WUO/fUBAOSGjMxkWBYEIVA9xbo+AHQxRAQBAABC4LUW77eeIq8P AJ3Kt78+8vry
h7w+AIDc+PbXR14fAOSFTBwREQQAAAhHkHoaMK/PMAzy+gAQccjrd0diUUBe HwBAJqTVM5S8
PkI7ANA5MNp0C3iZAABkDnl9AOh64pDidrtJXp/neeT1ZQ55fQAAuRHT+WSW HqieBsvrI7cD
ABEnLhxghOl28JIBAMhHG+tpsP76SqVSqRSQ1weACKJpWszrMwzD8zzy+vIn lgTk9QEAZIJc
RkVuC4IQqJ6iDw8AdBksIgAAAIQvSD1FXh8AOtV/99dXoL9+t4C8PgCA3HhV T/TXBwDZwSIC
AABAyMQyGqSeBsvro78+AESctL8+yevTNI28vsyJRQF5fQAAmVAqlSzLktsk r++3nmJdHwAA
AACgZ0JeHwA6lTSv7/Eo0F+/W0BeHwBAbnzz+u3rr4/QDgB0NCwidCMoCgAA shVKXp8kfpDX
B4DIQl6/OxKLAvL6AAAyIe2mj7w+AMgOvkAXAAAgfMHrabC8PoG8PgBEEM/z ZEghsUL01+8W
xIogvacL9wcAANxut1g9b1wF187++pjfA0DEYRW/+0JRAACQjzbWU/TXB4BO Jc3rsyzL87w0
cQjyhP76AABy41U9A9VT5PUBAAAAAHom9NcHgE4l7a/PcRTy+t0C+usDAMiN x+PhOI4MyyHm
9QEAOgGWEgAAAELglbH3W0+R1weATuXbXx95fflDXh8AQG58++v7raeorwDQ ZcjEsYOWEm7N
jwsUCoUgCFidAQC4pQSppwHz+mLra+T1ASCCOiGvLwhCfX19Q0OD1Wq12+1O pzOCG5ctjUYT
FRUVExOTmJiYlJRERfSXKLEoIK8PACAT0uoZJK8fcF0fk3sA6BwRHG0EQWho aKiurm5paUlK
SsrKyoqNjdVoND1+nVsQBKfTabFYGhsbL168WFtbazQa9Xp9BA8cRQEAQOaQ 1weArifm9Wma
Jnl9hvE/ELULGeAqKyvNZnNcXNygQYPUavWtE2hRKBQajUar1SYnJ2dkZFRU VFRWVra2tqal
pVGRWOBHXh8AQG7EdD6pgIHqabD6eisUSADoKhEfYaqqqurr63v37p2SkkLT NM/z1I38emSf
SLbIIatUqszMzJqamrq6OoVCkZqaGqntoygAAMiHWN2CV7pg/fU5jkNeHwAi S5rXd7sjk9cX
BKGxsbG+vj4+Pl6v1/M8T2a9xC0yQ/UapRMTE1tbW81ms0qlCj/MIxYF5PUB AGSCXEZFboeS
1wcA6GgRmYWTRmNms5llWYPBoFAoeJ6XdiTokqWKs2fPitfIdiZysCS5ZDAY 7Ha72WyOj4+n
afoW+Z0HAOAWFGSER14fADqVV399j8cTZn99QRDq6upcLldycjLLsuKkNnhD zy+++MJms91/
//0hP29wZWVlCoWiV69eHbR9v8gUX/yTZdn4+Hiz2dzU1NSrV69whnHk9QEA 5Maregaqp/je
XADoMhFZced5vrm5Wa1WsywrDS8G+RGr1VpXV9fY2Gg2m8PfgQgixxLmRsRj J9N9tVrd3Nws
DTUBAEDPIFa9EPP66K8PABHnm9d3u90h5/UFQXC73U1NTYmJiYIg2O326Oho mqapGx8giFfo
Sn/qzJkzOTk5Npvt9OnTBoOBbGfPnj1NTU2tra3z5s1Tq9XSx2/evHnUqFE/ /vijy+UqKioi
zW2OHTtWWlpKUZTRaPzVr37FsizHcXv37q2rq4uLi3O5XCRcxHHcvn37rl27 lpKSUlBQoNPp
/B4Iz/Pnz58/fvz48OHDY2NjQzgP1I3Ls8SGDHa7XRAElUrV0NDgcrmkq/Lt JRYF5PUBAGSC
jMzk9o2q6qeeIq8PAN2bIAgOh0Or1ZKZbktLC4nxKJVKQRBomvZquykIwunT p4uLi+12+969
e4cPH84wTHV19bVr12bMmEGGS4fDIX0Ki8Vy8uTJiRMnXrly5ejRowaDwWq1 njhx4p577lGr
1QcOHDh9+nROTs7Zs2c5jps1a1ZLS8uePXtcLpfD4Th79izDMLNmzTpx4sTJ kydvu+023/0v
Kys7deqU0WgsLi7WaDRez97GkyBeqEDWaHieJ3dqtVqHw4H1GgCAWxPy+gDQ qaR5fZZlw+yv
L66dk7m+2LmfTPf9jl2VlZVarTY2NjYmJkalUlVWVvbv3z8pKcnhcBw4cKCg oCA6Otr3ie68
886YmBiDwXDmzBmGYa5cuWI0GuPi4iiKysrKOnfu3KBBg65evZqZmanRaDQa TXx8PBlFy8vL
GYYpKSmx2WxOp3PEiBHSzVZUVBw6dCgtLW3q1KlarVa8v6qq6tKlS+JfBw4c aDAYDh48KC7h
6HS6/Px837NBfr0hnYjIXxmG4TjOK23fXsjrAwDIjVc6v9399TG5B4COFqnF ZpZlPR6PWq0W
BEGpVCp8SB989uxZt9u9bds2iqJomj579mxOTo5Op5s/f/6xY8e2bt06ffr0 xMREr6dgGEb8
FYKmabfbTa4DJv/kdrtpmrZarWq1mtxJURR5pN1uz8rKMhqN4kakmzUajQMG DLhw4cKlS5cG
DhwoTqANBoNGoxEfFhcXR9N0bm6ueMZ8NyU9mWQ/PR4PTdOtra3hf1UZhaIA ACBjoeT1SS4T
eX0AiKyOyOurVCq73S79otxAE3273V5dXf3QQw+xLEtRlM1me//9969fvx4V FaVSqQoKCiwW
S11dne9c34vJZPr666/dbrdSqbxy5YrJZKIoKjU1taKiIj09/fr169euXSN3 pqWlmc3mYcOG
+V0IZ1l22LBheXl5p06d+uSTTwYMGEBm/FFRUVFRUV4PDt7B0yunJCaXyJkh v42Ek9cnRQF5
fQAAmZB200deHwBkp409c25KoVDodDqbzZaUlEQC6+KklkyvpXn98+fPZ2Vl iZfexsTE9OvX
79y5c4mJiYcPH46LixMEITs722vJnLqxSE+2Q9N0UlKS0WjctGmTWq3WarVj xoyhaTovL++b
b755//33k5KSyNdX0TQ9atSovXv3vv/++3q9XqVSTZkyxfcQ1Gp1fn7+4MGD S0tLS0tLhw8f
3t6TIB4jmZGT/Sd5HpvNptPpsCoPANBTBa+nwfL6LMsirw8AkSUutzOMkmEY nufD6a9PBji9
Xn/16lXSc4aiKDLTlXbjEUewUaNGeW1hxowZ5MaAAQNaW1ulyRnR7373O3Kj b9++CxYsILcn
TJhAVlDEH0lKSpozZ47L5SK7QbAse++997pcLoqipPf7Ylm2oKCgPUf//xM/ LVGpVKT1EPmT
4ziLxWI0GlmWDT+vTz4MEe8JbVMAABARNE2L1ZNcvea3ngarr8jtAIDMkTXs xMREs9lcV1eX
np4ufoVWexcpSMuadj07y7LS6S/h1a8zyJ0RJO2pT1oPkTZEVVVVLMvq9Xpy GUOYz+LV0QgA
ALpQGwdk9NcHgE4lzet7PApxtAlngwqFIiEhoa6uLiYmJiUlhSR5yL+STpS+ mZwehhyjeK0C
mfHX1tbW1dX16tWLpmmPxxPO12mhvz4AgNx4Vc9A9RR5fQDo9hiGMRgMDoej vLxcqVT27t27
q/eo69XU1JSXl8fGxhoMhoj04QEAgO4I/fUBoFNJ++uLwpyMkmXsvn37VlVV Xbx40W63p6Wl
+U3e3wqcTmdlZWV1dXVMTExqampUVFQ4SX0C/fUBAOSGjMxkWCbRzXbn9QEA OkH4EUGFQsEw
jFarTU1NNZvN1dXVtbW1BoNBr9fHxsZqNJoev1ohCILT6bRYLI2NjdeuXeN5 Xq/X9+rVKyIT
fQAAkCev4d1vPUVeHwA6lW9//TDz+uJmFQqFSqVKTk7W6XSNjY319fUVFRUc x5EeOCISZ/fd
Qve9n4z1DMOoVCqtVqvT6fR6vU6nI21/pCH7kCGvDwAgN7799ZHXBwB5EXvm RGpT5NtkGYaJ
iopyuVwcx5FrUsllqdJZsvitW77z5m50v3ib9CMibTFZllWpVORUYEUfAOBW EKSeBszrMwyD
vD4ARFxH5PWlxB7zpNnwLfKxpDjKk/m9+N0Ckdq+WBSQ1wcAkAlp9Qwlr38r VEcAkIPIjjbi
V9tSt/B8tCNWZ1AUAABkDnl9AOh64pDidrtJXp/n+fDz+tChkNcHAJAbMZ1P ZumB6mmw75dB
bgcAIk6aMu/aPYH2wksGACAfbaynwfrrK5VKpVJAXh8AIogEyklen2EYnucj m9eHjiCWBOT1
AQBkglxGRW6TS9T81tMe/r3xACBnWEQAAAAIX5B6irw+AHSq/+6vr4hUf33o UMjrAwDIjVf1
DFRPsa4PAF0GiwgAAAAhE8tokHoaLK+P/voAEHHS/vokr0++/aqr9wuCEYsC 8voAADJBvj+R
3CZ5fb/1FOv6AAAAAAA9E/L6ANCppHl9j0eB/vrdAvL6AABy45vX91tPA35u jtAOAHS0Dl1E
uDVXKBQKhSAIHTGAoygAAMhWKHl9kvhBXh8AIqsT8vqCIJjN5oaGBqvVarPZ WltbI7hx2VKr
1TqdLiYmJjExMTk5mYro7FwsCsjrAwDIhLSbfpC8Pq6HA4Cu0RFfoCsIwrVr 16qrq61Wa1JS
kslkio2N1Wg0PX61QhAEp9NpsVgaGxsvXLhQW1trNBoTExN7/IEDAEDwehos r08grw8AEcTz
PBlSSKwwUv31yRhVVVVlNpvj4+Ozs7PVajUJtNwiyXKGYRITE/V6fVpaWkVF RVlZmdVqTU1N
pSLx25RYEaT3hLlNAAAIh9vtFqvnjavg/NTTYOv6mN8DQMR13EpzVVVVfX19 nz59UlJSaJrm
eZ66kV/voGeUG3LIKpUqMzOzpqamtraWoigy3Y+IDroSAAAAQtDGARn99QGg U0nz+izL8jwv
TRyGRhCExsZGi8WSlJSUnJxM0zQlGQRvkeFLOhGnabVWPtoAACAASURBVLpX r14ej+f69eux
sbF6vT7Mk4D++gAAcuNVPQPVU/TXB4DujcSBzGYzwzAGg0GhUIgxIfEB4Wtp aTl69GikHtYR
pAfL87xCoTAYDCzLms1mckK67iUCAIAug/76ANCpxCHF4/FwHBV+Xl8QBLPZ 3NLSkpycTCb6
ZO1Z+qdfHo/nnXfeycnJufPOO2/6LC0tLaWlpcOGDauvr9+xY8eCBQuCPyzU owkLGajFPxUK
RXR0tNlsrq2tJScn5C2jvz4AgNx4PB6O48iwLATO62NdHwC6WJhLCTzPNzc3 q9VqlmWF9vT2
KSsrUyqV586da9e01WAwzJ8/P8R9bb/Gxsb2/oh47IIgsCyrVqubm5tJlB8A AHoSr2Lnt54i
rw8Ancq3v344eX3yEYHNZtPr9Uql0uVyqVQqMa8vXpjrdwQ7c+ZMUVHRgQMH ysvL+/fvT1GU
1Wrdt2+fzWbT6XTTp0/32m2KomiabmhoOHDgwOzZsymK2rRpU0FBwZEjR1wu 17hx4/r27Ss+
zGaz7dixY+LEiXFxcaEdmriTDQ0NI0eONBqNwc8DeV5yQsjnGy6XS6lURkVF NTY20jStVCpD
HsmR1wcAkBvf/vp+6yn66wNAl7lpzKYtBEFwOBxarZbM7FtaWmiaJr9LCIJA pr++T2GxWJqa
mlJSUrKzs0tLS0mzmuPHj8fExEyaNIlsU/r41tZWcqfdbrdYLORfLRbLyZMn i4uLy8vLjx49
mpSURB5msVi++uqr4cOHq1Qqr+201+23397U1PTzzz//8MMPw4cPT0lJCXQS xPwSyV6SjL5C
odBqtQ6HAzlMAIAeLEg9DZjXF1tfI68PABEU2by+IAgcx9lsNpZlpWMcmfcH GfvOnj2bmZnp
drszMjKOHz/e0tISHR3du3fv3bt3q1SqoUOHtvGjhjvuuEOr1SYkJJw+fVrc pb1795pMpn79
+gX5wUOHDonZIZ1ON3z48KqqqsuXL4sPGDBggMFgoCgqISFh/PjxjY2Nhw8f VigUY8aM8f2s
QDxSctTSLBPLsjabjWQ6Q/61SiwKyOsDAMiEtHoGyesHLGaY3ANA5wh/tGFZ 1uPxqNVqQRBI
UsWL1+N5nr9w4YJOp9u+fTtFUWq1+sKFC/n5+WlpabNmzfrxxx8/+eSTefPm SWMqJBdE07R4
g9zPMIz0TnKDdL8JPrfOzc0VM/Qsy9I0bTAYNBqN+IC4uDjxWex2+/nz5zmO Gzp0aHx8vN/N
Sk8j+WTD4/HQNN3a2hpmS1Pf7QMAgAwhrw8AXU+cf9M0TfL6DON/IGoLElaJ jo52uVw6nY5s
n8y5A030KYq6dOmSXq8XE/kXLlw4fPjwyJEjOY5LSkqaMmXKO++843A44uPj xR8hv0IwDCPe
EO+X3qlUKmmanjRp0ldffXXw4MGioqJAe+6bxomNjY2NjfW60263Hzt2rLq6 +rbbbrvzzjuD
D8XiZyY8z/M8T35VsFqtMTEx5CQjrw8A0GOI6XwyxQ9UT4PVV8zvAaDjRGqE USgUOp3OZrMl
JSWRwDqZ6FM35qO+ef0zZ87k5eWJq+ZZWVnffvvt1atXy8vLKysrNRpNZmam Xq+X/kigdX36
Buq/1/WnTp36n//858iRIwUFBeEc3eHDh/v161dYWHjTWT55AInZkN0glyuQ S40jcrZRFAAA
5EMa1wzy0Wuw/vocxyGvDwCRJc3ru90RyOt7PJ7o6OirV68ajUaWZSlJzxwy 9fdd3ffqscMw
zOLFiymK6tevn9vtJq0qvZ4oOTn54Ycflt6gKOq3v/0tudGnT5+HHnpI+q9q tToirTknTZrU
xkeSs+p11BzHNTQ0GI1GjyesT2jFooC8PgCATJDLqMjtUPL6AAAdLfx1YrKG rdfryTdGZWRk
iFephja19Z3ldwvikYqth0gbosrKSpZlExISwmm4CQAAMhdkhEdeHwA6lTgL J4OMx+MJp78+
dSOok5KSUltbq9frU1JSxK/OJU8nJtd7MHKM4gewZMZfW1tL+opGRUV59Slq L+T1AQDkxqt6
BqqnWNcHgC4TqXAgwzAGg8Fut5eXlyuVyt69e0dks91aTU1NeXl5bGyswWCI SB8eAACQG/Fi
rRDz+uivDwAR55vXd7vdIef1xW0qlcqUlJSqqqpffvnl+vXrffv2lfavvKU4 nc6Kiorq6uqY
mJiUlBSlUkm+VyucbYpFAXl9AACZICMzuX2jqvqpp1jsAYBuj/S71Gg0qamp dXV11dXVtbW1
SUlJer0+NjZWo9H0+BSiIAhOp9NisTQ2NtbX1/M8n5CQkJKSotVqw2m1CQAA 3R3y+gDQqaR5
fZZlw+yvLxIEgWEYlmXVanViYmJDQ0Nzc3NNTQ3HcS6Xy2sH/C5yd9/7yfjM MIxKpdJqtfHx
8YmJiTqdTqVSkRMb/gCOvD4AgNx4pfPb3V8fk3sA6GgRDAeK813yFV1RUVEu l4vjOLfbTb5Y
ivrvWTK57Xfe3I3uF2+L303GsizLsmSWL37PQESgKAAAyFYoeX2Sy0ReHwAi qyPy+l7bp2ma
ZVnypby3yPAldhol83vSZT+CBy4WBeT1AQBkQtpNH3l9AJAd6bJ0BDcrfpEW dQvnTLAGDwBw
6wheT4Pl9VmWRV4fACJLzOszjJIsvYfZXx86gVgUpPd04f4AAACJbpLbgiAE qqfBvl/mVvjg
GwAA2ghFAQBAPtq4EI/++gDQqaR5fY9HIY42Xb1fEAz66wMAyI1X9QxUT3v4 98YDAAAAANyy
0F8fADqVtL++CHl9mUN/fQAAuSEjMxmWyffHtzuvDwDQCRARBAAACIHXWrzf eoq8PgB0Kt/+
+sjryx/y+gAAcuPbXx95fQCQF/EboLp6RwAAALqxIPU0YF6fYRjk9QEg4pDX 747EooC8PgCA
TEirZ5C8fsD6itAOAHSODhptbs1BTKFQCILQEaszt+b5BADoRpDXB4CuJw4p breb5PV5no9s
Xl8QhPr6+oaGBqvVarfbnU5nBDcuWxqNJioqKiYmJjExMSkpiYpoOAp5fQAA uRHT+WSWHqie
BvvcHLkdAIg4ceGgg9aeGxoaqqurW1pakpKSsrKyYmNjNRpNjx/NBEFwOp0W i6WxsfHixYu1
tbVGo1Gv10f2wHv8aQQA6Eak9TTIonyw/vpKpVKpFJDXB4AIomlazOszDMPz fETy+mSYq6ys
NJvNcXFxgwYNUqvVHRdokRuFQqHRaLRabXJyckZGRkVFRWVlZWtra1paGhWJ ObpYEpDXBwCQ
CXIZFbktCEKgeorr4QCgy0R2Fl5VVVVfX9+7d++UlBSapnmep2622tHDkENW qVSZmZk1NTV1
dXUKhSI1NbWr9wsAADpWkHqKvD4AdKr/7q+viEh/fUEQGhsb6+vr4+Pj9Xo9 z/Nk1kvcCuv6
lM8lWYmJia2trWazWaVShR/mQV4fAEBuvKpnoHqKdX0A6DIRWUQgH1yazWaW ZQ0Gg0Kh4Hle
2mn4llqqIAdLkksGg8Fut5vN5vj4eBKd6uq9AwCASBJzqiHm9dFfHwAiTtpf n+T1aZoOJ68v
CEJdXZ3L5UpOTmZZVpzUhvlFXT/++ONPP/3EsqxKpRo4cGB+fn7Ie9hpyKAv /smybHx8vNls
bmpq6tWrVzjDuFgUkNcHAJAJpVLJsiy5TZa9/NZTfG8uAHRvPM83Nzer1WqW ZSPb5CcjI2PR
okXFxcWHDx+2Wq3hb7BziMdOpvtqtbq5uVkaagIAgFsH8voA0KmkeX2PRxFm f33Sp7+pqSkx
MVEQBLvdHh0dTdM0deMDBPEK3dD2k+f56OhohULBcRz5pWLPnj0cx5lMphEj RtA0febMmcbG
Ro7jysvL+/btO3To0H379rW2thYVFZEeOMeOHSstLaUoymg0/upXv2psbDxy 5Mi0adMoinK5
XJ999tns2bOtVqvXZkPYW+rGhcjkNs/zdrtdEASVStXQ0OByuaSr8u2FvD4A gNz45vXb118f
oR0A6GiRyus7HA6tVktmui0tLSTGo1QqBUGgaTq0tptut9tms5WWll68eDEj I0OtVjscjkOH
Dg0cODA9PX3Xrl3Jycm9evWy2Wy//PLLuHHjRowYsWnTJrvdPmnSpLKysuPH jxsMBqvVeuLE
iXvuuUetVh84cOD06dPZ2dn19fU1NTXx8fFnz57V6/Uul8t3syGcBPFCBbJG w/M8uVOr1Toc
jvBPNYoCAIBshZLXJ4kf5PUBILIim9cnk1qO48hcn6BpWuziH/LYRdO0xWK5 cuVKU1PT3Xff
zTCMx+OprKzUaDRms9nlctXU1BiNRpqm09PT+/XrR1GUVqvNz8/X6XTx8fGX Ll1iGObKlStG
ozEuLo6iqKysrHPnzg0aNCg7O7usrGzUqFHnz5+/8847FQqF72ZDPhvk1xvS iYj8lWEYjuO8
0vbtJRYF5PUBAGRC2k0/SF4ffXgAoGtEMFvPsqzH41Gr1YIgkO978hLCNhUK RUpKyoQJE7Zt
21ZSUnLnnXe2trZyHNevXz+1Wp2VlRUVFSX+RiGmhsRfMyiKomna7XaTy4Up imIYxu120zSd
m5v75Zdf9u/fXxCEXr16ORwO382GsMPSRR2yDx6Ph6bp1tbW8L+qDAAAZCt4 PQ2W1yeQ1weA
CBLXm0msMMz++iSvr1Kp7Ha79Ityw5zoS40dO/ajjz7q169f3759DQZDY2Pj 8OHD2/izJpPp
66+/drvdSqXyypUrJpOJoqiEhASdTrdv376BAwdSFKXVatu7Wb+kR0rOMLmH nBnya0aYeX1p
Rh95fQCAruV2u8XqeeMquHb218f8HgAiLuKBQIVCodPpbDZbUlISCayLk1qS Mwktry8u2MfG
xhYWFu7fv3/+/PmTJk3atWvXuXPnNBpNv379RowYIV3XpyiKvoHcTkpKMhqN mzZtUqvVWq12
zJgx5J9yc3MPHTqUk5ND/uq72fburXiM5PJZslmS57HZbDqdLiKnPbQzCQAA HaGNAzL66wNA
p5Lm9VmW5XlemjhsL7Ikodfrr169SnrOUBQlTrWlT9feLRcUFIi3hwwZMmTI EIqiYmNjf/3r
XzscDpVKRX6RuP3228WHLVy4kNzIysrKysoitydMmECWXjQajfjI4cOHS1fx k5OTvTbbXuIH
sCqVirQeIn9yHGexWIxGI8uyYeb10V8fAEBWvKpnoHqKECcAdGNkDTsxMdFs NtfV1aWnpytu
fIVWxy1SREVFtevxLMuKX3cSwc1KiUcqth4ibYiqqqpYltXr9eQyhpC3DwAA 3RT66wNAp5L2
1+c4Ksy8PnUjWJKQkFBXVxcTE5OSkkKSPORfSSfK0K527UbIMYrXKpAZf21t bV1dXa9evWia
Jn2XQ94++usDAMiNx+PhOI4MyyHm9QEAOkH4SwkMwxgMBofDUV5erlQqe/fu HZEd69ZqamrK
y8tjY2MNBgP68AAA9EheH9j6rafI6wNAp5Lm9Ul//XDy+gRZxu7bt29VVdXF ixftdntaWpo0
H39LcTqdlZWV1dXVMTExqampUVFR4ST1CeT1AQDkxre/PvL6ACAvYrY+/O0w DKPValNTU81m
c3V1dW1trcFg0Ov1sbGxGo2mx69WCILgdDotFktjY+O1a9d4ntfr9b169YrI RB8AAGQuSD0N
mNcXW18jrw8AERTxvL64WYVCoVKpkpOTdTpdY2NjfX19RUUFx3Eul0v6SBJn 991C972fDO4M
w6hUKq1Wq9Pp9Hq9TqcjXYmkIfuQiUUBeX0AAJmQVs9Q8vqY3ANA54jIaCPO d8k3hEdFRblc
Lo7jyCSVXJYqnSWL37rlO2/uRveLt0k/ItLGlGVZlUpFTkUEV/RRFAAAZA55 fQDoemJen0zK
eZ5nGP8DUWjEHvMkvHiLfCwpfnpL5vfidwtEavvI6wMAyI2YzidlLlA9DVZf Mb8HgI7TQSMM
2SyZ7N6y89EOPbcAACAHXp9UB3pYsP765ONv5PUBIIKkeX23O2J5fehQYlFA Xh8AQCbIZVTk
dpC8fg//fhkAkDOsEwMAAIQvSD1FXh8AOpVXf32PxxN+f33oaMjrAwDIjVf1 DFRPsa4PAF0G
4UAAAICQiWU0xLw++usDQMT55vXdbjfy+jInFgXk9QEAZIKMzOT2jarqp55i XR8AAAAAoGdC
Xh8AOpU0r8+ybMT760NHQF4fAEBuvNL5geppwHV9TO4BoKMhHNiNoCgAAMhW KHl9kstEXh8A
Igt5/e5ILArI6wMAyIS0m36QvD4+NweAriH9wr8O3f4thXx7ItbgAQBuHcHr abC8PsuyyOsD
QGSJeX2GUTIMw/N8xPvrC4JgNpsbGhqsVqvNZmttbY3gxmVLrVbrdLqYmJjE xMTk5GQqor9E
iUVBek+kNg4AACGgaVqsnoIgBKqnwerrrbkqBgDdlyAI165dq66utlqtSUlJ JpMpNjZWo9H0
+NUKQRCcTqfFYmlsbLxw4UJtba3RaExMTIzsgeMTAwAA+WjjgIz++gDQqaR5 fY9HIY424W+W
oqiqqiqz2RwfH5+dna1Wq0mg5RZJljMMk5iYqNfr09LSKioqysrKrFZramoq FYkFfvTXBwCQ
G6/qGaieIq8PAD1EVVVVfX19nz59UlJSaJrmeZ66kV/v6l3rJOSQVSpVZmZm TU1NbW0tRVFk
ug8AALcm9NcHgE4l7a8vCjOvLwhCY2OjxWJJSkpKTk6maZqSLGbfIsOXNGBD 03SvXr08Hs/1
69djY2P1en2YJwH99QEA5IaMzGRYFgQhUD3Fuj4AdLEw193JBUlms5lhGIPB oFAoeJ4nY584
AkZmR7sDcrBk3m8wGOx2Owk10TR9i/zOAwBw6/Aa2P3WO+T1AaBT+fbXDzOv T7rutLS0JCcn
+0702zXBXbt2rU6n4ziud+/eY8aMiY+Pb/s+yGEmLU70qRu7FB0dbTaba2tr yckJecvI6wMA
yI1vf32/9TTg9+YCAHS0EKbjvnieb25uVqvVLMuG37N/+vTpjzzyiFKpPHbs WBt/pLm5+Z13
3gnt6TqCeOyCILAsq1arm5ubSZQfAAB6pCD1NGBen2EY5PUBIOIim9cnHxHY bDa9Xq9UKl0u
l0qlEvP64oW5bR/BaJpmWTY2NtZms5HtlJeXf//992q1eujQodnZ2RRFVVRU HDlyxOl09u/f
f9SoUd98843D4fjoo4+GDx+ek5Pz888/nzx5kqIoo9FYVFTEsuzp06cbGhps NpvT6Zw5c6bv
BsNHDpOmaXJCyOcbLpdLqVRGRUU1NjbSNC3GOkMgFgXk9QEAZEJaPUPJ6yO0 AwCdI/y8vsPh
0Gq1ZGbf0tJCsulKpVIQBDL9bfsc98qVK6dPn7548eK4ceMcDocgCPv37582 bZpKpdqyZUuf
Pn2USuUPP/wwePDg9PR08tQFBQVfffXVjBkzKIqqq6s7fvz4tGnTNBrN/v37 T506lZuba7PZ
zpw5M3HixD59+tjtdt8NhnP44kkQ80ske8nzPLlTq9WSAwn/KcLfTwAA6DjI 6wNA1xOHFLfb
TfL6PM+HnNcXBIHjOJvNxrKsdEJP5v0hZISuXLly7dq1wYMHk6+eNZvNHMed OHGCunFhQO/e
vVNTU7///nuO4/r37+/145cvXzYajdHR0RRFZWRknD9/Pjc3l6Ko9PT0Pn36 BNpgaMcuJR4p
OWpplollWZvNxnFcOJ/QIq8PACA3YjqfjPmB6mmwz82R2wGAiAs/Uu+LZVmP x6NWq8mHmAof
bd9UQUGBw+HYsWNHRkZGTEyMw+FgWdZkMlEUZTKZSEOb/Pz85OTkI0eOXL16 9a677iJRH/Kn
2+1mGIbcZhjG4/GQDxkUCgW50+8GI3ISpCsy5EnJs7e2tobZ0lSEogAAIB/S ehpkUT5Yf32l
UqlUCsjrA0AEiXNfEivkeT7MvD7P89HR0S6XS6fTURRFZtXis7R37FIqlamp qQMHDty3b9/M
mTONRiOZnaekpIiPcblcGRkZ8fHxn332GcMwUVFRLpeLoiiGYbKzs3ft2kW2 U1VVlZWVRab+
NE2TY/S7wdraWoVC0atXL5fLVVFR0bdvX5VKJd7ZrrNB8DzP8zz5LcJqtcbE xHil7dtLLAnI
6wMAyAQZ2MltMvKjvz4AyEtEFhEUCoVOp7PZbElJSSSwLvaSJ/PRduX1ybx8 9OjRmzdv/vnn
n0eOHFlcXLx9+/a4uDie50ePHt23b98vvviCLKKMHj2apuno6OisrKxPPvlk 9OjR6enpqamp
H3zwgUql0mq1Y8aMEXeGzLxjYmJ8N3j8+HGlUllcXGyz2Xbt2vXQQw9pNBrx zrbstniMJGZD
notcrmCz2XQ6HdZrAAB6sCCDPPL6ANCp/ru/viLM/vpkO9HR0VevXjUajSzL UjeGPJqmydS/
7av7Tz75JLnBsuyCBQvIbZPJlJmZKV7+S1HUfffd19rayrKsGL8pLi52Op0q lUqhUIwbN+7O
O+8kmSLyr8OHD5c+i+8Gp06dSv7JYDA89dRT5LZ4Z9tPBZncS4+a47iGhgaj 0ejxhPUJLfL6
AABy41U9A9VTrOsDQJcJfxGBrGHr9XryjVEZGRniVaoRDB+Sjw6k92g0Gq/H aLVa8TbLsuS3
jrZvMPw9JDfE1kOkDVFlZSXLsgkJCeE03AQAAHkSP9QNMa+P/voAEHHiLFzM 64tZ9tCQoE5K
Skptba1er09JSRG/Opc8nZhc78HIMYpjPZnx19bWNjU1paSkREVFefUpai+x KCCvDwAgE0ql
UlxXInl9v/UU6/oA0O0xDGMwGOx2e3l5uVKpjEgXy+6upqamvLw8NjbWYDBE qg8PAAB0O8jr
A0Cnkub1PR5FmP31xW0qlcqUlJSqqqpffvnl+vXrffv29Y3Z3CKcTmdFRUV1 dXVMTExKSopS
qSTfqxXONpHXBwCQG9+8fvv66yO0AwAdLVKLCAqFgmEYjUaTmppaV1dXXV1d W1ublJSk1+tj
Y2M1Gk2PH9AEQXA6nRaLpbGxsb6+nuf5hISElJQUrVYbTqtNqR5/DgEAuq9Q 8vok8YO8PgBE
VsTz+oQgCAzDsCyrVqsTExMbGhqam5tramo4jiPN76U74HdM7L73k/GZYRjS 6DM+Pj4xMVGn
06lUKnJiwx/AxaKAvD4AgExIu+kjrw8AshPZL9AV57tkpCPfb8VxnNvtJl8s Rf33LJnc9jtv
7kb3i7dJPyLy2w7LsmSWL7b2BwCAHix4PQ2W1yeQ1weACCLZcbICQS4KCqe/ vi/SgoZlWfKh
wS0yfImdRsn8nnTZj+CBixVBek+kNg4AACFwu91i9bxxFVw7++vfCgUSADpZ R680S7+k9pbN
mXTQSW7XNxADAECHauOAjP76ANCppHl9lmV5npcmDkGe0F8fAEBuvKpnoHra w79fBgAAAADg
loX++gDQqaT99TmOinheHzoC+usDAMiNx+PhOI4My0Hy+ljXB4AuhqUEAACA EHhl7P3WU+T1
AaBT+fbXR15f/pDXBwCQG9/++sjrA4C8iJ0iu3pHAAAAurEg9TRgXl9sfY28 PgBEEPL63ZFY
FJDXBwCQCWn1DCWvj8k9AHQOjDbdAl4mAACZQ14fALqemNenaZrk9RnG/0AE 8oG8PgCA3Ijp
fDLFD1RPg+X1Mb8HgI6DEabbwUsGACAf4ip+8ME5WH99juOQ1weAyJLm9d1u 5PW7B7EoIK8P
ACAT5DIqchv99QFAjrBODAAAEL4g9RR5fQDoVF799T0eD/rryx/y+gAAcuNV PQPVU6zrA0CX
QTgQAAAgZGIZDVJPg+X10V8fACLON6/vdruR15c5sSggrw8AIBNkZCa3b1RV P/UU6/oAAAAA
AD0T8voA0KmkeX2WZdFfv1tAXh8AQG680vnt7q+PyT0AdDSEA7sRFAUAANkK Ja9PcpnI6wNA
ZCGv3x2JRQF5fQAAmZB200deHwBkp41f+AcAAABBBK+nwfL6LMsirw8AkSXm 9RlGyTAMz/Po
ry9/YlGQ3tOF+wMAADRNi9VTEIRA9TTYuj5yOwAAIEJRAACQjzYuxKO/PgB0 Kmle3+NRiKNN
V+8XBIP++gAAcuNVPQPVU+T1AQAAAAB6JvTXB4BOJe2vL0JeX+bQXx8AQG7I yEyGZUEQAtVT
rOsDQBdDRBAAACAEXmvxfusp8voA0Kl8++sjry9/yOsDAMiNb3995PUBQF7I xBERQQAAgHAE
qacB8/oMwyCvDwARh7x+dyQWBeT1AQBkQlo9Q8nrI7QDAJ0Do023gJcJAEDm kNcHgK4nDilu
t5vk9XmeR15f5pDXBwCQGzGdT2bpgeppsLw+cjsAEHHiwgFGmG4HLxkAgHy0 sZ4G66+vVCqV
SgF5fQCIIJqmxbw+wzA8zyOvL39iSUBeHwBAJshlVOS2IAiB6in68ABAl8Ei AgAAQPiC1FPk
9QGgU/13f30F+ut3C8jrAwDIjVf1RH99AJAdLCIAAAD8f+3dPXLcRhoGYKAH IC2zbJkOHFg6
ge6iKyh24OPsTTbzBZSpXE6cOHS2qqWpP640AHqDLnXB84MaDYczjfHzRGO6 KcE1rH7h5otv
9pZjdCJPp/r65usDBzeer5/6+iEEff3C5VDQ1wcoxGKxaNs2vU59/Y156lwf AADOk74+cFTj
vn7f1+brz4K+PkBp1vv6XzZfX2kHeGgOEWZEKAAUa5++fmr86OsDh6WvP0c5 FPT1AQoxnqav
rw8UxwfoAsD9TefpVF8/0dcHDmgYhrSlpFqh+fqzkBNh/JUTXg8AXdfl9Pz8 FNwXztd3fw8c
nFP8+RIKAOXYMU/N1weOatzXb9t2GIZx45Ayma8PUJqV9NyWp/r6AABwnszX B45qPF9/uaz0
9WfBfH2A0vR9v1wu07a8Z18f4AgcJQDAHlY69hvzVF8fOKr1+fr6+uXT1wco zfp8fX19oCzp
xtFRAgDcx0Sebu3r59HX+vrAAenrz1EOBX19v83tKgAACDZJREFUgEKM03Of vr6be+A47Daz
4G0CKJy+PnB6ua8fQkh9/abZvBFRDn19gNLkdn66xd+Wp1N9fff3wMOxw8yO twygHPkUf3pz
npqvv1wu9fWBwxr39btOX38ecijo6wMUIj1GlV6brw+UyDkxANzfRJ7q6wNH tTJfv+978/XL
p68PUJqV9NyWp871gZNRDgSAveUYncjTqb6++frAwa339buu09cvXA4FfX2A QqSdOb3+nKob
8tS5PgAAnCd9feCoxn39tm3N158FfX2A0qy08794vr6be+ChKQfOiFAAKNY+ ff3Uy9TXBw5L
X3+Ocijo6wMUYjxNX18fKM6OH/gHAEyYztOpvn7btvr6wGHlvn7TLJqmGYbB fP3y5VAYf+WE
1wNACCGnZ4xxW55Onevr7QCQCQWAcux4EG++PnBU475+39d5tzn1dTHFfH2A 0qyk57Y81dcH
AIDzZL4+cFTj+fqZvn7hzNcHKE3amdO2HGPclqfO9YETUxEEgD2snMVvzFN9 feCo1ufr6+uX
T18foDTr8/X19YGypBtHFUEAuI+JPN3a12+aRl8fODh9/TnKoaCvD1CIcXru 09dX2gGOw24z
C94mgMLp6wOnl7eUrutSX38YBn39wunrA5Qmt/PTXfq2PJ3q6+vtAAeXDw7s MLPjLQMox455
OjVff7FYLBZRXx84oBBC7us3TTMMg75++XIk6OsDFCI9RpVexxi35ak5PMDJ OEQAgPubyFN9
feCo/j5fvzZffxb09QFKs5Ke5usDxXGIAAB7yzE6kadTfX3z9YGDG8/XT339 EIK+fuFyKOjr
AxRisVi0bZtep77+xjx1rg8AAOdJXx84qnFfv+9r8/VnQV8foDTrff0vm6+v tAM8NIcIMyIU
AIq1T18/NX709YHD0tefoxwK+voAhRhP09fXB4rjA3QB4P6m83Sqr5/o6wMH NAxD2lJSrdB8
/VnIiTD+ygmvB4Cu63J6fn4K7gvn67u/Bw7OKf58CQWAcuyYp+brA0c17uu3 bTsMw7hxSJnM
1wcozUp6bstTfX0AADhP5usDRzWer79cVvr6s2C+PkBp+r5fLpdpW96zrw9w BI4SAGAPKx37
jXmqrw8c1fp8fX398unrA5Rmfb6+vj5QlnTj6CgBAO5jIk+39vXz6Gt9feCA 9PXnKIeCvj5A
IcbpuU9f3809cBx2m1nwNgEUTl8fOL3c1w8hpL5+02zeiCiHvj5AaXI7P93i b8vTqb6++3vg
4dhhZsdbBlCOfIo/vTlPzddfLpf6+sBhjfv6XaevPw85FPT1AQqRHqNKr83X B0rknBgA7m8i
T/X1gaNama/f9735+uXT1wcozUp6bstT5/rAySgHAsDecoxO5OlUX998feDg 1vv6Xdfp6xcu
h4K+PkAh0s6cXn9O1Q156lwfAADOk74+cFTjvn7btubrz4K+PkBpVtr5Xzxf 38098NCUA2dE
KAAUa5++fupl6usDh6WvP0c5FPT1AQoxnqavrw8UZ8cP/AMAJkzn6VRfv21b fX3gsHJfv2kW
TdMMw2C+fvlyKIy/csLrASCEkNMzxrgtT6fO9fV2AMiEAkA5djyIN18fOKpx X7/v67zbnPq6
mGK+PkBpVtJzW57q6wMAwHkyXx84qvF8/Uxfv3Dm6wOUJu3MaVuOMW7LU+f6 wImpCALAHlbO
4jfmqb4+cFTr8/X19cunrw9QmvX5+vr6QFnSjaOKIADcx0Sebu3rp5mdl219 0XRfX4RqOTz4
ZQL/AIt6+PoiXDT1ZduEEPJuc+rrYkp+m/T1AQoxbuen4fob83RzvoYQhmGo quq
Previous Topic:Content of Compartments
Next Topic:Figure with two Anchors
Current Time: Sun Jul 27 06:15:15 EDT 2025
Powered by FUDForum. Page generated in 0.07201 seconds
