Re: Update from within wtp-all-in-one-sdk-1.0-linux-gtk effects only emf [message #161564 is a reply to message #161458] |
Wed, 22 February 2006 03:04   |
On Tue, 21 Feb 2006 15:04:24 -0500, Johannes Wolfgang Woger <jwwoger@chello.at> wrote:
> an update from within wtp-all-in-one-sdk-1.0-linux-gtk, which is
> eclipse 3.1.1 platform does not include an update to eclipse 3.1.2
> Is this behaviour intended?
> Wolfgang
This should work, but it is a funtion of the base Eclipse itself, not WTP.
And, its a little different than the process of updating WTP.
If you already have 3.1.1 installed (via the all in one zip), you should be able to use simply the
Update Manager choice of "check for updates of existing features". And ... that should find updates
for 3.1.2 Eclipse, and EMF update. It would not find any for GEF or JEM as those did not change.
It also would not find for WTP 1.0.1, for different reasons. I will be publishing directions for that soon.
If you find it does not work, you might help contribute by doing some "pure" tests (a fresh 3.1.1
install first) then try the "check for updates to existing features". If that does not work, its bug-worthy.
FUDForum. Page generated in 0.04855 seconds
