Home » Modeling » GMF (Graphical Modeling Framework) » problem with nested figure
problem with nested figure [message #161225] Mon, 19 November 2007 06:12 Go to next message
Originally posted by: ali.akar.geensys.com
--------------050008020108000101040205
I'm trying to create nested figures without using a compartment, the
problem is when creating the child figure in the diagram, I dont have
the control over their resizing and their positioning.
I'm working on the mindmap.ecore and trying to have the same behavior of
the diagram described in the tutorial without using compartment.
any help will be appreciated!
thx in advance.
P.S. see attached picture.
Content-Type: image/bmp;
name="mindmap.bmp"
Content-Disposition: inline;
filename="mindmap.bmp"
Qk2qrQUAAAAAADYAAAAoAAAAmQEAAC8BAAABABgAAAAAAHStBQAAAAAAAAAA AAAAAAAAAAAA
////////////////////////////////////////////////////AP////// ////////////
/////////////////////////////////wD///////////////////////// ////////////
//////////////8A////////////sbW1sLCwsLCwsLCwsLCwsLCwsLCwsLCw sLCwsLCwsLCw
sLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCw sLCwsLCwsLCw
sLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsbW1//////////// ////////AP//
/////////7CwsL76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76 +r76+r76+r76
+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76 +r76+r76+r76
+r76+r76+r76+r76+r76+r76+rCwsP///////////////////wD///////// //+wsLC++vq+
+vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq+ +vq++vq++vq+
+vq++vqwsLD///////////////////8A////////////sLCwvvr6vvr6vvr6 vvr6vvr6vvr6
vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6 vvr6vvr6vvr6
vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6 sLCw////////
////////////AP///////////7CwsL76+r76+r76+r76+r76+r76+r76+r76 +r76+r76+r76
+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+rCwsP////////////// /////wD/////
//////+wsLC++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq+ +vq++vq++vq+
+vq++vq++vq++vq++vq++vqwsLD///////////////////8A//////////// sLCwvvr6vvr6
vvr6sLCw////////////////////AP///////////7CwsL76+r76+r76+r76 +r76+r76+r76
+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+rCw sP//////////
/////////wD///////////+wsLC++vq++vq++vq++vq++vq++vq++vq++vq+ +vq++vq++vq+
+vq++vq++vq++vq++vq++vq++vq++vq++vq++vqwsLD///////////////// //8A////////
////sLCwvvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6 vvr6vvr6vvr6
vvr6vvr6vvr6vvr6vvr6sLCw////////////////////AP///////////7Cw sL76+r76+r76
+rCwsP///////////////////wD///////////+wsLC++vq++vq++vq++vq+ +vq++vq++vq+
+vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vqwsLD/ ////////////
//////8A////////////sLCwvvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6 vvr6vvr6vvr6
vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6sLCw//////////////////// AP//////////
/7CwsL76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76 +r76+r76+r76
+r76+r76+r76+r76+rCwsP///////////////////wD///////////+wsLC+ +vq++vq++vq+
+vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq+ +vq++vq++vqw
sLD///////////////////8A////////////sLCwvvr6vvr6vvr6vvr6vvr6 vvr6vvr6vvr6
vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6sLCw//// ////////////
////AP///////////7CwsL76+r76+r76+r76+r76+r76+r76+r76+r76+r76 +r76+r76+r76
+r76+r76+r76+r76+r76+r76+r76+r76+rCwsP///////////////////wD/ //////////+w
sLC++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq+ +vq++vq++vq+
+vq++vq++vq++vqwsLD///////////////////8A////////////sLCwvvr6 vvr6vvr6vvr6
vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6 vvr6vvr6sLCw
////////////////////AP///////////7CwsL76+r76+r76+r76+r76+r76 +r76+r76+r76
+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+rCwsP////// ////////////
/wD///////////+wsLC++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq+ +vq++vq++vq+
+vq++vq++vq++vq++vq++vq++vq++vqwsLD///////////////////8A//// ////////sLCw
vvr6vvr6vvr6sLCw////////////////////AP///////////7CwsL76+r76 +r76+r76+r76
+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76+r76 +r76+rCwsP//
/////////////////wD///////////+wsLC++vq++vq++vq++vq++vq++vq+ +vq++vq++vq+
+vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vqwsLD///////// //////////8A
////////////sLCwvvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6 vvr6vvr6vvr6
vvr6vvr6vvr6vvr6vvr6vvr6vvr6sLCw////////////////////AP////// /////7CwsL76
+r76+r76+rCwsP///////////////////wD///////////+wsLC++vq++vq+ +vq++vq++vq+
+vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq++vq+ +vqwsLD/////
//////////////8A////////////sLCwvvr6vvr6vvr6vvr6vvr6vvr6vvr6 vvr6vvr6vvr6
vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6vvr6sLCw//////////// ////////AP//
Re: problem with nested figure [message #161260 is a reply to message #161225] Mon, 19 November 2007 07:11 Go to previous messageGo to next message
Try using an XYLayout in the parent figure.
On 11/19/07 6:12 AM, in article fhrr3b$pl5$1@build.eclipse.org, "Ali Akar"
<ali.akar@geensys.com> wrote:
> Hello,
> thx in advance.
Re: problem with nested figure [message #161283 is a reply to message #161225] Mon, 19 November 2007 08:10 Go to previous messageGo to next message
Originally posted by: martin.tauber.t-online.de
Ali,
If you are using nested Figures, the layout and size of the child figure
are determened by the layout manager used by the parent.
so you should start looking at the methods
org.eclipse.draw2d#setLayoutManager and at the layout managers (Children
on LayoutManager)
Martin
Ali Akar wrote:
> Hello,
> thx in advance.
Re: problem with nested figure [message #161381 is a reply to message #161283] Mon, 19 November 2007 10:31 Go to previous messageGo to next message
thx Richard and Martin,
when I use an XYlayout as a layout manager for the parent figure and I
set the property 'Affixed Parent side' for the child node to South,
north or ..., the diagram presents an unexpected behavior, I can just
create the Topic figure in the top left corner of the editor with no
possibility to resize or move it.
moreover, without the XYlayout (no layout manager specified) the
children are created attached on the desired side of the parent but no
way to resize them.
I'm asking if there is somethings I missed
any idea ??
thx in advance.
Martin Tauber a écrit :
> Ali,
> on LayoutManager)
> Regards
> Martin
> Ali Akar wrote:
>> Hello,
>> of the diagram described in the tutorial without using compartment.
>> thx in advance.
Re: problem with nested figure [message #161420 is a reply to message #161381] Mon, 19 November 2007 10:51 Go to previous messageGo to next message
Well, perhaps I misunderstood what you're trying to achieve.
If you use an XYLayout for the parent rectangle, inner rectangles will be
able to be positioned wherever you'd like within the rectangle. I'm
assuming you'll have inner rectangles with labels to display within the
parent. Or...?
Using the side affixed option is for creating port-like children to the
outside edge of a rectangle, normally. You can look at the UML2 Tools
diagram definition files for examples of both, actually. They are a good
source of example figure definition and mappings.
Best,
Rich
On 11/19/07 10:31 AM, in article fhsa7p$jgq$1@build.eclipse.org, "Ali Akar"
> Hello,
> way to resize them.
> any idea ??
> thx in advance.
>> Ali,
>> on LayoutManager)
>> Regards
>> Martin
>> Ali Akar wrote:
>>> Hello,
>>> thx in advance.
Re: problem with nested figure [message #161441 is a reply to message #161420] Mon, 19 November 2007 11:23 Go to previous messageGo to next message
I attached a figure to what I'm trying to achieve,
Process is the toplevel node while threads and ports are child nodes. I
want to create thread inside process with the possibility to move and
resize them, this is done by using the xylayout manager, but for Port
when the 'Affixed parent side' is different to NONE, I cant create more
than one Process that located in the top left of the editor with no
control on it.
can you tell me where can I find the UML examples plz
thx in advance,
Ali
> parent. Or...?
> Best,
> Rich
>> Hello,
>> way to resize them.
>> any idea ??
>> thx in advance.
>>> Ali,
>>> on LayoutManager)
>>> Regards
>>> Martin
>>> Ali Akar wrote:
>>>> Hello,
>>>> thx in advance.
Re: problem with nested figure [message #161449 is a reply to message #161441] Mon, 19 November 2007 11:34 Go to previous message
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.mdt/org .eclipse.uml2too
ls/plugins/org.eclipse.uml2.diagram.def/?root=Modeling_Proje ct
On 11/19/07 11:23 AM, in article fhsdaj$5ae$1@build.eclipse.org, "Ali Akar"
> control on it.
> thx in advance,
> Ali
>> parent. Or...?
>> Best,
>> Rich
>>> Hello,
>>> way to resize them.
>>> any idea ??
>>> thx in advance.
>>>> Ali,
>>>> on LayoutManager)
>>>> Regards
>>>> Martin
>>>> Ali Akar wrote:
>>>>> Hello,
>>>>> thx in advance.
Re: problem with nested figure [message #161494 is a reply to message #161420] Mon, 19 November 2007 11:34 Go to previous message
--------------070300010707080707050403
here is the figure !!!
Richard Gronback a
Previous Topic:mapping editor
Next Topic:Custom LayoutProviders
Current Time: Sun Jul 13 13:12:30 EDT 2025
Powered by FUDForum. Page generated in 0.05073 seconds
