Home » Language IDEs » ServerTools (WTP) » websphere 6.0 for webtools
websphere 6.0 for webtools [message #160882] Wed, 15 February 2006 14:48 Go to next message
Hi, I'm trying to set up eclipse with webtools to work with websphere 6.0 app server. I'm having some problems though. I've tried about every suggested combo of web tools and its dependancies, and none of it solves this problem. Currently I am running a clean Eclipse 3.2 with the following:
wtp-sdk-1.5M4.zip
emf-sdo-xsd-SDK-2.2.0M4.zip
JEM-SDK-1.2M1.zip
GEF-SDK-3.2M4.zip
When I try to create a websphere 6.0 server through
window->preferences->servers->runtime, Once I click next, nothing happens. An
error is created in the log.
org.eclipse.jst.server.generic.ui.internal.GenericServerRunt imeWizardFragment.enter(GenericServerRuntimeWizardFragment.j ava:99)
org.eclipse.wst.server.ui.internal.wizard.TaskWizard.switchW izardFragment(TaskWizard.java:292)
org.eclipse.wst.server.ui.internal.wizard.TaskWizardPage.set Visible(TaskWizardPage.java:92)
org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:1043)
org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog. java:1026)
at org.eclipse.jface.wizard.WizardDialog$4.run(WizardDialog.jav a:1016)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1014)
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:753)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:345)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:607)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:914)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3285)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2905)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:808 )
at org.eclipse.jface.window.Window.open(Window.java:786)
org.eclipse.wst.server.ui.internal.RuntimePreferencePage.sho wWizard(RuntimePreferencePage.java:354)
org.eclipse.wst.server.ui.internal.RuntimePreferencePage$2.w idgetSelected(RuntimePreferencePage.java:133)
org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPrefer encesAction.java:66)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:492 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:530)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:480)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:392)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1762)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1726)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:397)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:109)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: websphere 6.0 for webtools [message #162192 is a reply to message #160882] Mon, 27 February 2006 10:50 Go to previous message
This is a JVM issue. Previously we were running 1.4.1. While debugging we noticed that the xml wasn't being parsed correctly. There had been some changes to those classes, and once we upgraded our JVM to 4.1.2 we were getting websphere to install properly.
Previous Topic:WTP1.0.x and .deployables
Next Topic:Can't configure JBoss 4.0.x
Current Time: Sun Jul 27 01:42:20 EDT 2025
Powered by FUDForum. Page generated in 0.04268 seconds
