Home » Archived » BIRT » refresh/update a chart continuously
refresh/update a chart continuously [message #160793] Sun, 14 May 2006 11:38 Go to next message
Originally posted by: fcheng.us.ibm.com
Suppose the data is being updated continuously (every 0.1 second or some
small interval), is it possible to refresh the chart every time the data is
updated?
I guess we could just create a new chart every time. But the chart would
keep flashing which would be annoying.
Any solution/idea?
Re: refresh/update a chart continuously [message #160876 is a reply to message #160793] Mon, 15 May 2006 04:38 Go to previous message
Hi Feng,
Yes it's possible, you don't need to recreate a chart everytime. You can
reuse the same chart, update the data, and then call "refresh" (not build),
and then render. Refresh will skip layout computations (not needed if you
only change the data).
There is an example in org.eclipse.birt.chart.examples :
SwingLiveChartViewer
David
"Feng Cheng" <fcheng@us.ibm.com> wrote in message
news:e47isp$9hb$1@utils.eclipse.org...
> is updated?
> Any solution/idea?
> Thanks
Previous Topic:fonts in PDF
Next Topic:birt $NO-RB$ org.eclipse.birt.chart.device.swt.SwtRendererImpl
Current Time: Sun Jul 27 06:26:50 EDT 2025
Powered by FUDForum. Page generated in 0.03245 seconds
