Home » Archived » BIRT » Is it possible to intergrate birt with SWT?
Is it possible to intergrate birt with SWT? [message #160746] Sat, 13 May 2006 06:42 Go to next message
Originally posted by: xy.gmail.com
at org.eclipse.birt.report.viewer.ViewerPlugin.getResourceStrin g(Unknown
Source)
org.eclipse.birt.report.viewer.ViewerPlugin.getFormattedReso urceString(Unkno
wn Source)
org.eclipse.birt.report.viewer.utilities.WebappAccessor.getW ebappPath(Unknow
n Source)
at org.eclipse.birt.report.viewer.utilities.WebappAccessor.star t(Unknown
Source)
at org.eclipse.birt.report.viewer.utilities.WebViewer.startWebA pp(Unknown
Source)
at org.eclipse.birt.report.viewer.utilities.WebViewer.display(U nknown
Source)
at ReportViewer.previewReport(ReportViewer.java:85)
at ReportViewer.createContents(ReportViewer.java:76)
at ReportViewer.<init>(ReportViewer.java:55)
at ReportViewer.main(ReportViewer.java:35)
public class ReportViewer extends Shell {
private Browser browser;
private String reportName =
" D:/eclipse/workspace/MyBirtPlugin/src/DynamicReport.rptdesig n ";
* Launch the application
* @param args
public static void main(String args[]) {
try {
Display display = Display.getDefault();
ReportViewer shell = new ReportViewer(display, SWT.SHELL_TRIM);
shell.open();
shell.layout();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
} catch (Exception e) {
e.printStackTrace();
* Create the shell
* @param display
* @param style
public ReportViewer(Display display, int style) {
super(display, style);
createContents();
* Create contents of the window
protected void createContents() {
setText("SWT Application");
setSize(500, 375);
setLayout(new GridLayout());
final Composite composite = new Composite(this, SWT.NONE);
final GridData gridData = new GridData(GridData.FILL_HORIZONTAL |
GridData.VERTICAL_ALIGN_BEGINNING);
gridData.heightHint = 37;
composite.setLayoutData(gridData);
browser = new Browser(this, SWT.NONE);
final GridData gridData_1 = new GridData(GridData.FILL_BOTH);
browser.setLayoutData(gridData_1);
//showReport();
previewReport();
private void previewReport() {
try {
WebViewer.startup(browser);
System.setProperty("RUN_UNDER_ECLIPSE", "true");
DtpManifestExplorer.getInstance().getExtensionManifests();
//WebViewer.display("C:/IANA/2005/Birt/RCP/testBirt/testSampleDB.rptdesign ",
WebViewer.HTML,false);
WebViewer.display(reportName , WebViewer.HTML, browser);
//logger.error(e);
protected void checkSubclass() {
// Disable the check that prevents subclassing of SWT components
Re: Is it possible to intergrate birt with SWT? [message #161190 is a reply to message #160746] Mon, 15 May 2006 17:00 Go to previous messageGo to next message
What version of BIRT are you using?
Jason
"xy" <xy@gmail.com> wrote in message news:e44d7g$msb$1@utils.eclipse.org...
> java.lang.NullPointerException
> Source)
> at
> wn Source)
> at
> n Source)
> Source)
> Source)
> Source)
> * @param args
> try {
> shell.open();
> shell.layout();
> display.sleep();
> * Create the shell
> * @param display
> * @param style
> createContents();
> setSize(500, 375);
> //showReport();
> previewReport();
> try {
> //logger.error(e);
Re: Is it possible to intergrate birt with SWT? [message #161248 is a reply to message #161190] Mon, 15 May 2006 22:03 Go to previous messageGo to next message
Originally posted by: xy.nil.net
Birt 2.0.1
"Jason Weathersby" <jweathersby@actuate.com> д
Re: Is it possible to intergrate birt with SWT? [message #161614 is a reply to message #161248] Tue, 16 May 2006 17:29 Go to previous message
Can you try just using
Also verify you have all the plugins that the WebViewer requires.
Jason
"xy" <xy@nil.net> wrote in message news:e4bbsi$t8f$1@utils.eclipse.org...
> Birt 2.0.1
Previous Topic:Group Total in Group Header
Next Topic:birt problem
Current Time: Fri Jul 18 17:14:19 EDT 2025
Powered by FUDForum. Page generated in 0.07848 seconds
