Home » Archived » BIRT » Birt URL Run command without render
Birt URL Run command without render [message #160676] Fri, 12 May 2006 13:39 Go to next message
Originally posted by: ekelly.curamsoftware.com
Is it possible to invoke the run action from a web browser and having the
report files saved in the specified (PDF/HTML) format without the return
render stream. In effect an invocation from the viewer to the engine for a
runTask only and not a runAndRenderTask. => the generation phase without
the presentation phase.
Also, A reference to the generated ReportDocument is to be stored in a
list at the browser for a presentation url action at a later stage. Eg. A
URL download command would be useful where report engine phase
2(presentation) is performed and the output sent to the browser.
Is there any easy way to do this at present?
Any help appreciated, Thanks
Re: Birt URL Run command without render [message #161608 is a reply to message #160676] Tue, 16 May 2006 16:02 Go to previous messageGo to next message
This is possible doing it yourself with your own servlet and report engine
api. Another option is to specify the __document parameter to save to the
document wherever you want.
Jason
"Eoin" <ekelly@curamsoftware.com> wrote in message
news:776e8ede68e110eac0c394573bc1e933$1@www.eclipse.org...
Re: Birt URL Run command without render [message #162072 is a reply to message #160676] Wed, 17 May 2006 18:07 Go to previous message
Originally posted by: sam.morrison.altres.com
What are you using to call the URL? You could write a little wrapper
app, I am using PHP, to call the URL and get the render as a binary dump
that you can save wherever you want. I am using curl, but there are many
ways to do this. This also makes it very easy to wrap any authentication
requirements you have around the process.
sam
> the report files saved in the specified (PDF/HTML) format without the
> return render stream. In effect an invocation from the viewer to the
> engine for a runTask only and not a runAndRenderTask. => the generation
> phase without the presentation phase.
> A URL download command would be useful where report engine phase
Previous Topic:How to set list-property parameters for a DataSet using DE API
Next Topic:how can i write jdbc statments in BIRT
Current Time: Fri Jul 18 17:55:27 EDT 2025
Powered by FUDForum. Page generated in 0.09440 seconds
