Home » Language IDEs » C / C++ IDE (CDT) » Running and debugging an MPI application
Running and debugging an MPI application [message #160638] Sun, 18 December 2005 02:31 Go to next message
Originally posted by: berend.chalmers.se
I have been developing a managed make (eclipse takes care of the
makefile) project which is built upon MPI (Message passing interface,
for parallel applications). I currently run and debug my application
outside of eclipse/CDT, because I need the mpi script to run the
application,
$ mpirun -np 1 Debug/Application
1. Is there a way to run this application from within eclipse?
2. Is there a way to use the gdb debugger, at least for single processor
runs?
Many thanks,
Berend.
Re: Running and debugging an MPI application [message #160896 is a reply to message #160638] Wed, 21 December 2005 10:22 Go to previous messageGo to next message
Check out the new Parallel Tools Project http://eclipse.org/ptp -
which is built on top of CDT.
We have just released v1.0 of the MPI development tools,
which will locate MPI artifacts in your code, and provide content
assist, help, etc.
Click on the "download" link at http://eclipse.org.ptp on the left side.
The setup and configuration instructions
(installing Eclipse and CDT, so you're beyond that)
will appear on the website shortly, and v1.0 of the rest of PTP will be
following soon as well. The PTP MPI tools help plug-in, within
Eclipse, helps in setting up the CDT project to use the tools.
Ask further questions in the PTP newsgroup; we'll probably see them
sooner. (I'm cross-posting this reply to there.)
The base PTP download is coming soon. Meanwhile it's available from CVS.
The base PTP Help includes information on running and debugging the MPI
application with PTP...
....Beth
Berend van Wachem wrote:
> application,
> runs?
> Many thanks,
> Berend.
Re: Running and debugging an MPI application [message #1806076 is a reply to message #160638] Thu, 02 May 2019 07:03 Go to previous message
You can create custom Makefile instead of using Makefile automatically generated by Eclipse.
1) Disable automatically generated Makefile : Properties -> C/C++ Build -> Generate Makefiles automatically -> untoggle
2) Create empty makefile and put inside :
all: OpenMPI.exe
mpirun -np 4 ./OpenMPI.exe
OpenMPI.exe: hello.c
mpicc hello.c -o "OpenMPI.exe"
clean:
rm -f hello.o OpenMPI.exe
3) Build and run again
Previous Topic:Serious crashes in the latest version of the CDT on Ubuntu 16.04, Linux Mint and others
Next Topic:Can you tell me what is your developing environment ?
Current Time: Fri Jul 18 20:56:35 EDT 2025
Powered by FUDForum. Page generated in 0.03671 seconds
