Connection Anchor for Connection [message #160633] |
Thu, 15 November 2007 06:45 |
Originally posted by: marsha.rohrer.swisscom.com
I have the following construct in my ecore model: I have a EClass
PredecessorRelation, the EClass PredecessorRelationCondition is linked
through an aggregation. The PrececessorRelationCondition itself is the
generalisation of the two EClasses SimpleCondition and ResultCondition.
On the editor this construct is visualized with a parent figure which
represents the PredecessorRelation. That figure contains a BodyFigure
(Compartment) where the SimpleCondition or the ResultCondition may be
placed. This figure construct is linked through connections with other
figures of the editor. To be able to use the same connection for both
characteristics of the PredecessorRelationCondition I define the
assotiations from this class.
This works fine but has the little side-effect, that the polyline doesn't
stop at the figure for the PredecessorRelation but goes to the BodyFigure
that holds the childelements. Now how can I define that the connection
anchor for that link is the parent figure?
Thanks for your help
Marsha
FUDForum. Page generated in 0.03153 seconds
