the mnemonic 's' in menu "Run" is not unique since M9 [message #160563] |
Tue, 25 May 2004 09:29  |
Originally posted by: map.obiecta.com
the mnemonic 's' in menu "Run" is not unique since M9. the key sequence
(Alt-r,s,2) is one of the most useful in our team (-> Run, Run As, 2. Java
Application).
The menu "Run" has two concurrent 's' mnemonics. Who knows a workaround?
Who kann tell me where to address this issue to the developers of eclipse?
thanks in advance,
map
Re: the mnemonic 's' in menu "Run" is not unique since M9 [message #160599 is a reply to message #160563] |
Tue, 25 May 2004 11:02   |
> Application).
> thanks in advance,
Right. I tripped over that too. The old key sequence was
Alt-r, s, 2
With M9 (on WinXP at least), the popup menu does not pop up
automatically when there are more than one menu items for the same
letter, so you also have to hit the arrow key:
Alt-r, s, s, ->, 2
And unfortunately, there are no keyboard shortcuts for any of these Run
As (or Debug As) actions, so we can't set them up that way either.
John
FUDForum. Page generated in 0.14651 seconds
