Home » Eclipse Projects » Subversive » cannot override and update any more
cannot override and update any more [message #15065] Thu, 03 April 2008 10:51 Go to next message
nothing happens on selecting resources in the synchronize view and
executing 'override and update'. An error gets added to the log.
This with 3.4M5 and 3.4M6 and svn team provider 0.7.0.v20080321
Error - Unhandled event loop exception
java.lang.ClassCastException:
org.eclipse.team.svn.core.svnstorage.SVNLocalFile incompatible with
org.eclipse.team.svn.core.resource.IResourceChange
org.eclipse.team.svn.ui.synchronize.update.action.UpdateActi on.splitByPegRevision(UpdateAction.java:134)
org.eclipse.team.svn.ui.synchronize.update.action.OverrideAn dUpdateAction.getOperation(OverrideAndUpdateAction.java:96)
org.eclipse.team.svn.ui.synchronize.action.AbstractSynchroni zeModelAction.getSubscriberOperation(AbstractSynchronizeMode lAction.java:78)
org.eclipse.team.ui.synchronize.SynchronizeModelAction.runOp eration(SynchronizeModelAction.java:114)
org.eclipse.team.ui.synchronize.SynchronizeModelAction.run(S ynchronizeModelAction.java:96)
org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEv ent(BaseSelectionListenerAction.java:168)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:582)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:499)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:410)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :83)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1145)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3346)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2982)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2375)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2339)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 05)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:478)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:473)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:362)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:79)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:618)
Re: cannot override and update any more [message #15071 is a reply to message #15065] Thu, 03 April 2008 10:54 Go to previous messageGo to next message
Edoardo Comar wrote:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=225578
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: cannot override and update any more [message #15088 is a reply to message #15071] Fri, 04 April 2008 10:59 Go to previous message
Originally posted by: alexander.gurov.polarion.org
Hello Edoardo,
Thank you for reporting this issue. Fix will be available in the next
Subversive build at the end of this week.
Previous Topic:How to browse deleted directories?
Next Topic:Single, project-spanning commits?
Current Time: Sat Jun 07 15:09:47 EDT 2025
Powered by FUDForum. Page generated in 0.02798 seconds
