cannot override and update any more [message #15065] |
Thu, 03 April 2008 10:51  |
nothing happens on selecting resources in the synchronize view and
executing 'override and update'. An error gets added to the log.
This with 3.4M5 and 3.4M6 and svn team provider 0.7.0.v20080321
Error - Unhandled event loop exception
java.lang.ClassCastException:
org.eclipse.team.svn.core.svnstorage.SVNLocalFile incompatible with
org.eclipse.team.svn.core.resource.IResourceChange
org.eclipse.team.svn.ui.synchronize.update.action.UpdateActi on.splitByPegRevision(UpdateAction.java:134)
org.eclipse.team.svn.ui.synchronize.update.action.OverrideAn dUpdateAction.getOperation(OverrideAndUpdateAction.java:96)
org.eclipse.team.svn.ui.synchronize.action.AbstractSynchroni zeModelAction.getSubscriberOperation(AbstractSynchronizeMode lAction.java:78)
org.eclipse.team.ui.synchronize.SynchronizeModelAction.runOp eration(SynchronizeModelAction.java:114)
org.eclipse.team.ui.synchronize.SynchronizeModelAction.run(S ynchronizeModelAction.java:96)
org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEv ent(BaseSelectionListenerAction.java:168)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:582)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:499)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:410)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :83)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1145)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3346)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2982)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2375)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2339)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 05)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:478)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:473)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:362)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:79)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:618)
FUDForum. Page generated in 0.04165 seconds
