Home » Eclipse Projects » GEF » how to detect the behavior of delete a model from a LogicDiagram( logic example)
how to detect the behavior of delete a model from a LogicDiagram( logic example) [message #160243] Fri, 03 December 2004 00:39 Go to next message
Originally posted by: hitdemo2002.yahoo.com.cn
in GEF's example-logic i want to add some extrally function to deletion
action ,that is to say: when delete a model from a logicdiagram (or delete
a
figure from diagram), i can notified. and i can add some number to a
array(or some other function).
for implements this function ,does i must code a new deleteaction and
replace "IWorkbenchActionConstants.DELETE" with thest new action
or i can use some existed function such as performRequest in some
editpart??
Re: how to detect the behavior of delete a model from a LogicDiagram( logic example) [message #160288 is a reply to message #160243] Fri, 03 December 2004 02:13 Go to previous messageGo to next message
> delete a
> editpart??
You can probably use performRequest or something similar to send
notificatoin of deletes. Depends on what you are listening too. You
could listen to the parent container, or the child being deleted itself.
Its up to you.
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber."
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: how to detect the behavior of delete a model from a LogicDiagram( logic example) [message #160311 is a reply to message #160288] Fri, 03 December 2004 03:09 Go to previous messageGo to next message
> Its up to you.
i have added a performRequest() to the xxxeditpart,
public class xxxeditpart extends LogicEditPart {
public void performRequest(Request req) {
System.out.println("come
in。。。。&#1229 0;。。。。 ");
if (req.getType() == RequestConstants.REQ_DELETE) {
System.out.println(" deleting。。。。& ;#12290;。。。。 ");
but i found that above code only took effect at the time of double click
the xxxeditpart. it can't notified of deletion,resize,move etc,why?
Re: how to detect the behavior of delete a model from a LogicDiagram( logic example) [message #160336 is a reply to message #160311] Fri, 03 December 2004 09:41 Go to previous messageGo to next message
>> itself. Its up to you.
What do you mean by took effect? Do you mean the only time that method
was called was during double click?
Also you should still be using .equals() rather than instance equality.
Respectfully,
CL Gilbert
and a robber."
Re: how to detect the behavior of delete a model from a LogicDiagram( logic example) [message #160344 is a reply to message #160243] Fri, 03 December 2004 10:22 Go to previous messageGo to next message
Originally posted by: gaslade.yahoo.com
Probably the simplest thing to do would be to remove the existing delete
action ( if there is one ) and then replace it with a custom delete action.
For example, your editor probably has a createActions() method if it is
based on the logic example ( which everyones is ) and the first thing
this method probably does is call super. After super has been called you
can do the following....
protected void createActions() {
super.createActions();
ActionRegistry registry = getActionRegistry();
IAction action;
IAction deleteAction =
registry.getAction(GEFActionConstants.DELETE);
if (deleteAction != null) {
registry.removeAction(deleteAction);
action = new MyDeleteAction(this);
registry.registerAction(action);
getSelectionActions().add(action.getId());
Guy
> delete a
> editpart??
Re: how to detect the behavior of delete a model from a LogicDiagram( logic example) [message #160447 is a reply to message #160336] Fri, 03 December 2004 20:26 Go to previous messageGo to next message
> Respectfully,
> CL Gilbert
> and a robber."
what i mean is:
when i delete xxxeditpart use "del" key for popmenu, xxxeditpart's
performRequest
could't be called,because there were no print out message "come
in.........."
if i double click xxxeditpart , above mothod was called,so i was confused
by this method.
System.out.println("come in...........");
System.out.println("deleting..........");
Re: how to detect the behavior of delete a model from a LogicDiagram( logic example) [message #160615 is a reply to message #160311] Mon, 06 December 2004 12:06 Go to previous message
PerformRequest is used for things which do not necessarily execute a
Command. For example, direct edit may go into an editing mode, but if the
user presses ESC, nothing happens. For actions which should simply execute
immediately, if executable, getCommand is the API of choice.
"hitdemo2002" <hitdemo2002@yahoo.com.cn> wrote in message
news:cop6v3$g6g$1@www.eclipse.org...
> > Its up to you.
in&#12290;&#12290;&#12290;&#12290;&#1229 0;&#12290;&#12290;&#12290;&#12290; ")
System.out.println(" deleting&#12290;&#12290;&#12290;&#12290;& ;#12290;&#12290;
&#12290;&#12290;&#12290;");
Previous Topic:Automatic graph layout of links only
Next Topic:EditDomain
Current Time: Thu Nov 06 12:05:37 EST 2025
Powered by FUDForum. Page generated in 0.04510 seconds
