loading attribute values from external file [message #160205] |
Wed, 14 November 2007 05:54  |
Originally posted by: t.kitamura07.gmail.com
Hello, first of all I'm sorry for my bad english.
I'm newbie and trying to create a GUI using GMF for my thesis. I want to
know how I can load attribute values of objects in the domain model from
existing external file and save it back after the modifying. Objects must
have values which are already defined out of the GUI (but it isn't
constant) and must be able to be modified. I have to only call a method in
java to load/save the value, but I don't know where I should write it.
I've tried to change set-, get- methods in Impl files but it didn't work
and I couldn't find any answers in the web. If someone could give me
hints, suggestions or any other responses, I would be very glad.
Information about useful web sites or literature would be also
appreciated. Thank you.
best regards,
Tomoko
Re: loading attribute values from external file [message #160225 is a reply to message #160205] |
Wed, 14 November 2007 06:14   |
Tomoko,
You posted the same question to the EMF newsgroup. If you must post to
multiple groups (keep in mind that doing so will tend to annoy people),
please use a single posting addressed to both the groups, not two
separate postings.
> to know how I can load attribute values of objects in the domain model
> from existing external file and save it back after the modifying.
> Objects must have values which are already defined out of the GUI (but
> it isn't constant) and must be able to be modified. I have to only
> call a method in java to load/save the value, but I don't know where I
> should write it. I've tried to change set-, get- methods in Impl files
> but it didn't work and I couldn't find any answers in the web. If
> someone could give me hints, suggestions or any other responses, I
> would be very glad. Information about useful web sites or literature
> would be also appreciated. Thank you.
> best regards,
> Tomoko
FUDForum. Page generated in 0.06080 seconds
